  <title>R-pod Owners Forum : Pre-Travel &amp; Post Travel Checklists</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Pre-Travel &amp; Post Travel Checklists</description>
  <pubDate>Sun, 25 Oct 2026 20:20:23 +0000</pubDate>
  <lastBuildDate>Sat, 17 Aug 2024 11:33:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=16030</WebWizForums:feedURL>
   <title>Pre-Travel &amp; Post Travel Checklists : This is a good use for the expanded...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16030&amp;PID=153766#153766</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 16030<br /><strong>Posted:</strong> 17 Aug 2024 at 11:33am<br /><br /><div>This is a good use for the expanded search function.</div><div><br></div><div>Click on search, then you will see the option for the advanced search. That will allow you to expand the search to more than the default 6 month limit. There have been checklists on the forum in the past. Hopefully, this will help you locate them.</div><div><br></div>]]>
   <pubDate>Sat, 17 Aug 2024 11:33:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16030&amp;PID=153766#153766</guid>
   <title>Pre-Travel &amp; Post Travel Checklists : Hi...New to RV&amp;#039;ing and picking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=16030&amp;PID=153765#153765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13630" rel="nofollow">FOADIAC</a><br /><strong>Subject:</strong> 16030<br /><strong>Posted:</strong> 17 Aug 2024 at 9:18am<br /><br />Hi...New to RV'ing and picking up our 1st R-Pod 202 in 2 weeks. Former US Navy Ship Engineer used to using checklists. In the past my checklists were built on trial, error or mistakes. Instead of starting from scratch and building my own from error &amp; mistakes, I was wondering if anyone had a source or had built their own I could use as a jump off point? I'm gonna build two; TV &amp; Trailer versions. Print/laminate go thru them prior to underway and after unhitching. Any suggestions would be appreciated.<div><br></div><div>VR/Mikey</div><div><br></div><div>2022 R-Pod 202/Club Chair version</div><div>2023 F-150 XLT 3.5L&nbsp;</div><div><br></div>]]>
   <pubDate>Sat, 17 Aug 2024 09:18:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=16030&amp;PID=153765#153765</guid>
