  <title>R-pod Owners Forum : What is this under the RPod?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : What is this under the RPod?</description>
  <pubDate>Sun, 25 Oct 2026 17:06:31 +0000</pubDate>
  <lastBuildDate>Tue, 21 May 2024 15:54:14 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15964</WebWizForums:feedURL>
   <title>What is this under the RPod? : +1. Auto-reset breakers. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153494#153494</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15964<br /><strong>Posted:</strong> 21 May 2024 at 3:54pm<br /><br />+1. Auto-reset breakers.<br>]]>
   <pubDate>Tue, 21 May 2024 15:54:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153494#153494</guid>
   <title>What is this under the RPod? : I believe those are auto-reset...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153491#153491</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 15964<br /><strong>Posted:</strong> 20 May 2024 at 4:44pm<br /><br />I believe those are auto-reset breakers to protect against over current.]]>
   <pubDate>Mon, 20 May 2024 16:44:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153491#153491</guid>
   <title>What is this under the RPod? : Under the 2020 RPod 190 near where...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153490#153490</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8357" rel="nofollow">GCRicker</a><br /><strong>Subject:</strong> 15964<br /><strong>Posted:</strong> 19 May 2024 at 7:10pm<br /><br />Under the 2020 RPod 190 near where the battery cutoff switch is, it appears that the red wire coming from the battery goes to this component.&nbsp; Is there a fuse between the battery and the Converter/fuse panel?<div><br></div><div><img src="uploads/8357/IMG_8736-2.JPG" height="480" width="400" border="0" /><br></div>]]>
   <pubDate>Sun, 19 May 2024 19:10:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15964&amp;PID=153490#153490</guid>
