  <title>R-pod Owners Forum : Reversed Polarity</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Reversed Polarity</description>
  <pubDate>Sun, 25 Oct 2026 17:04:53 +0000</pubDate>
  <lastBuildDate>Sun, 12 May 2024 22:26:46 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15960</WebWizForums:feedURL>
   <title>Reversed Polarity : I am guessing that the battery...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153483#153483</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15960<br /><strong>Posted:</strong> 12 May 2024 at 10:26pm<br /><br />I am guessing that the battery was connected backwards At a minimum&nbsp; it blew the two reverse-polarity protection fuses in the power panel. At worst it could have messed up some systems, including the converter. You won't know until you get the polarity correct on the connections and replace the two 40A fuses. Then you can troubleshoot to see what else might have been messed up.<div><br></div><div>Keep us posted. I hope it will turn out well for you.</div>]]>
   <pubDate>Sun, 12 May 2024 22:26:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153483#153483</guid>
   <title>Reversed Polarity : Could you please supply us with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153481#153481</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15960<br /><strong>Posted:</strong> 11 May 2024 at 9:17pm<br /><br />Could you please supply us with more information.&nbsp; Hard to make advice or suggestions with the six words given.&nbsp; Thank you Annie.<br>]]>
   <pubDate>Sat, 11 May 2024 21:17:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153481#153481</guid>
   <title>Reversed Polarity : What to do about reversed polarity...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153480#153480</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5762" rel="nofollow">Annie</a><br /><strong>Subject:</strong> 15960<br /><strong>Posted:</strong> 11 May 2024 at 9:57am<br /><br />What to do about reversed polarity]]>
   <pubDate>Sat, 11 May 2024 09:57:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15960&amp;PID=153480#153480</guid>
