  <title>R-pod Owners Forum : Replacing kitchen sink in RPod 179</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Replacing kitchen sink in RPod 179</description>
  <pubDate>Fri, 23 Oct 2026 04:55:45 +0000</pubDate>
  <lastBuildDate>Sat, 11 Nov 2023 13:51:26 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15887</WebWizForums:feedURL>
   <title>Replacing kitchen sink in RPod 179 : Seems that way doesn&amp;#039;t it?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153051#153051</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5789" rel="nofollow">JimBinOC</a><br /><strong>Subject:</strong> 15887<br /><strong>Posted:</strong> 11 Nov 2023 at 1:51pm<br /><br />Seems that way doesn't it? The 179 has served us well but a Lance 2075 will be a nice upgrade. We traded a 2013 Nissan Frontier in for a 2023 Silverado 1500 turbo-diesel that can tow up to 9,000 lbs. The new truck tows the R-Pod like it's not even there.]]>
   <pubDate>Sat, 11 Nov 2023 13:51:26 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153051#153051</guid>
   <title>Replacing kitchen sink in RPod 179 :   Originally posted by JimBinOC...We...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153045#153045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 15887<br /><strong>Posted:</strong> 10 Nov 2023 at 7:29pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by JimBinOC</strong></em><br /><br />...We will probably upgrade to a bigger trailer in the next few years anyway.</td></tr></table><div><br></div><div>That's pretty much the norm around here.</div>]]>
   <pubDate>Fri, 10 Nov 2023 19:29:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153045#153045</guid>
   <title>Replacing kitchen sink in RPod 179 : Thanks for the reply. I chickened...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153040#153040</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5789" rel="nofollow">JimBinOC</a><br /><strong>Subject:</strong> 15887<br /><strong>Posted:</strong> 09 Nov 2023 at 6:18pm<br /><br />Thanks for the reply. I chickened out and decided to only replace the faucet. The Elkay sink isn't that much bigger than the stainless steel undermount sink that came with the trailer. We will probably upgrade to a bigger trailer in the next few years anyway.]]>
   <pubDate>Thu, 09 Nov 2023 18:18:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153040#153040</guid>
   <title>Replacing kitchen sink in RPod 179 : I am pretty sure I put clamps...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153039#153039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15887<br /><strong>Posted:</strong> 09 Nov 2023 at 3:42pm<br /><br />I am pretty sure I put clamps on all edges. I think the screws were long enough to allow placing them on the cleats. Unfortunately, I can't look as I no longer have the 179. As for the flexible tailpiece, look in the plumbing section of your local Lowe's or Home Depot. I am pretty sure you can find a flexible tailpiece at one of them.]]>
   <pubDate>Thu, 09 Nov 2023 15:42:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153039#153039</guid>
   <title>Replacing kitchen sink in RPod 179 : This post is directed at StephenH....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153038#153038</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5789" rel="nofollow">JimBinOC</a><br /><strong>Subject:</strong> 15887<br /><strong>Posted:</strong> 09 Nov 2023 at 1:23pm<br /><br />This post is directed at StephenH. While I'm at it, thank you StephenH for your many helpful podmod posts, so many of which I have added to our 2016-1/2 179.<div><br></div><div>I am about to replace the tiny sink in our Pod with the same Elkay unit you installed but I have some questions before I start cutting up the countertop.</div><div><br></div><div>Were you able to install the sink clamps along the front and back of the sink or did the cabinet cleats get in the way?&nbsp;</div><div><br></div><div>How many clamps did you end up using?</div><div><br></div><div>The link you provided for the flexible tailpiece no longer seems to work. Do you remember which brand it was and where you got it?</div>]]>
   <pubDate>Thu, 09 Nov 2023 13:23:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15887&amp;PID=153038#153038</guid>
