  <title>R-pod Owners Forum : R202 Slide out bound up....</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : R202 Slide out bound up....</description>
  <pubDate>Sun, 25 Oct 2026 18:23:39 +0000</pubDate>
  <lastBuildDate>Fri, 13 Oct 2023 20:45:19 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15865</WebWizForums:feedURL>
   <title>R202 Slide out bound up.... : Not sure this may help:Schwintek...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152926#152926</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10795" rel="nofollow">pedwards2932</a><br /><strong>Subject:</strong> 15865<br /><strong>Posted:</strong> 13 Oct 2023 at 8:45pm<br /><br />Not sure this may help:&nbsp;<a href="http://www.rpod-owners.com/forum_posts.asp?TID=15666&amp;KW=&amp;PID=151533&amp;title=schwintek-inwall-slideout#151533" target="_blank">Schwintek In-Wall Slideout - R-pod Owners Forum (rpod-owners.com)</a><div>I had a similar problem on my r189.....there is a control unit that is at the back of the slide and the manuals show how to troubleshoot.&nbsp; It does not take much resistance for it to get out of synch.</div>]]>
   <pubDate>Fri, 13 Oct 2023 20:45:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152926#152926</guid>
   <title>R202 Slide out bound up.... : Sometimes you need to just go...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152905#152905</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15865<br /><strong>Posted:</strong> 08 Oct 2023 at 10:17pm<br /><br />Sometimes you need to just go ahead and take it to a repair shop. This sounds to me like one of those times. I am guessing that it is a Schwintek. If so, this may help:<div><br></div><div><a href="https://www.youtube.com/watch?v=zm16iYOpY80" target="_blank">https://www.youtube.com/watch?v=zm16iYOpY80</a><br></div>]]>
   <pubDate>Sun, 08 Oct 2023 22:17:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152905#152905</guid>
   <title>R202 Slide out bound up.... : Had a great trip to Washington...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152904#152904</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12257" rel="nofollow">timirey</a><br /><strong>Subject:</strong> 15865<br /><strong>Posted:</strong> 08 Oct 2023 at 9:52pm<br /><br />Had a great trip to Washington Beach this past weekend.&nbsp; Spectacular weather with friends for three nights.&nbsp; When we arrived the slide out didn't track properly going out to set up the dinette.&nbsp; The front side tracked more quickly than the rear slide.&nbsp; Putting the slide in required someone outside pushing it to help it get in or we never would have been able to get home.&nbsp; Now home and it won't move in or out. I have done a bunch of research on youtube and it sounds like the fault switch likely has shut down the motor. The motor itself may have come loose with a failed set screw or it needs lube (which I had no idea but should have known). Only have used the trailer maybe a dozen times since we bought it new... I watched a repair video online and it looks like it might be more than what I want to tackle. Any thoughts, comments or advise is welcome! -Tim]]>
   <pubDate>Sun, 08 Oct 2023 21:52:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15865&amp;PID=152904#152904</guid>
