  <title>R-pod Owners Forum : 2016 Rpod 179</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : 2016 Rpod 179</description>
  <pubDate>Wed, 23 Sep 2026 14:11:50 +0000</pubDate>
  <lastBuildDate>Wed, 30 Aug 2023 20:55:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15830</WebWizForums:feedURL>
   <title>2016 Rpod 179 : Thank you very much. I was hoping...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152665#152665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13114" rel="nofollow">Papadoc</a><br /><strong>Subject:</strong> 15830<br /><strong>Posted:</strong> 30 Aug 2023 at 8:55pm<br /><br />Thank you very much. I was hoping to hear that. ]]>
   <pubDate>Wed, 30 Aug 2023 20:55:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152665#152665</guid>
   <title>2016 Rpod 179 : We plug an 80W Zamp into the Zamp...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152664#152664</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9690" rel="nofollow">poohbill</a><br /><strong>Subject:</strong> 15830<br /><strong>Posted:</strong> 30 Aug 2023 at 8:22pm<br /><br />We plug an 80W Zamp into the Zamp solar connector on our '16. It has all the circuitry needed to plug and play.<div><br></div><div>I have no idea why it would not be advised to pull in the slide out when connected to the truck - we do it all the time, as the last thing before departure. Sliding it out is the first thing we do after backing into a new spot so we can get a good reading on lateral level and decide whether to raise one or the other wheel. Sliding it out shifts the balance about half a bubble, so if a ramp is needed under one wheel, we keep the truck running and connected for the back and forth.</div>]]>
   <pubDate>Wed, 30 Aug 2023 20:22:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152664#152664</guid>
   <title>2016 Rpod 179 : Hello. I bought a used Rpod 179,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152660#152660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=13114" rel="nofollow">Papadoc</a><br /><strong>Subject:</strong> 15830<br /><strong>Posted:</strong> 30 Aug 2023 at 3:55pm<br /><br />Hello. I bought a used Rpod 179, 2016 model and am adding solar panels for off grid camping. 2 questions.<div>1. Do I have to have a charge protector if plugging the solar output directly into the solar outlet on the Rpod? I know I would need one if connecting directly to the battery.</div><div>2.if the battery is fully charged and and the trailer is still connected with a 7-point plug to the truck is it safe to use battery power to open and close the slide out? The manual advises against it and I don’t have a manual crank.</div><div>Thank you in advance for your help. I consider myself to be somewhat of an electrical idiot.</div><div><br></div><div>Papadoc</div>]]>
   <pubDate>Wed, 30 Aug 2023 15:55:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15830&amp;PID=152660#152660</guid>
