  <title>R-pod Owners Forum : Propane hose from regulator to block180</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Propane hose from regulator to block180</description>
  <pubDate>Sat, 30 May 2026 13:55:38 +0000</pubDate>
  <lastBuildDate>Fri, 01 Sep 2023 18:17:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15829</WebWizForums:feedURL>
   <title>Propane hose from regulator to block180 : I also had problems with squirrels...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152673#152673</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 15829<br /><strong>Posted:</strong> 01 Sep 2023 at 6:17pm<br /><br /><div>I also had problems with squirrels chewing the propane hose. After getting a new hose, I wrapped it with metal tape used by air conditioning companies to attach/repair/install duct work. so far it has worked to keep them from chewing the hose.</div><div><br></div><div>My local propane provider said that "some" companies can make custom hoses made from flex metal-I haven't found one in my local area yet.</div><div><br></div><div>Travel often and safe <br></div><div><br></div><div>Vann<br></div>]]>
   <pubDate>Fri, 01 Sep 2023 18:17:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152673#152673</guid>
   <title>Propane hose from regulator to block180 : When I purchased a lockable box...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152668#152668</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15829<br /><strong>Posted:</strong> 31 Aug 2023 at 2:44am<br /><br />When I purchased a lockable box for two batteries at HF I had to get a longer hose because of rerouting the line.&nbsp; Went to a business that sells propane to homes.&nbsp; They built one for me in about 5 minutes, the price was very reasonable.<br>]]>
   <pubDate>Thu, 31 Aug 2023 02:44:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152668#152668</guid>
   <title>Propane hose from regulator to block180 : I would remove the damaged hose,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152662#152662</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7876" rel="nofollow">seafans</a><br /><strong>Subject:</strong> 15829<br /><strong>Posted:</strong> 30 Aug 2023 at 5:07pm<br /><br />I would remove the damaged hose, measure and check the size.&nbsp; E trailer might have a hose made from mr heater.&nbsp; Or do a yahoo search for a local company that custom make propane hoses. They are not that special.&nbsp; Very low pressure.&nbsp;&nbsp;<span>7.5 to 8" wc</span> . And this sounds high.&nbsp; <br>]]>
   <pubDate>Wed, 30 Aug 2023 17:07:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152662#152662</guid>
   <title>Propane hose from regulator to block180 : Does anyone know what the length...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152659#152659</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5358" rel="nofollow">xfitpanther</a><br /><strong>Subject:</strong> 15829<br /><strong>Posted:</strong> 30 Aug 2023 at 1:47pm<br /><br />Does anyone know what the length and size of the propane hose between the regulator and the block under the camper? Or what one to get?  Dang squirrels. I'd prefer if they're going to chew them, to chew the one between the tank and regulator. Lol&nbsp;&nbsp;&nbsp;&nbsp;rpod 180]]>
   <pubDate>Wed, 30 Aug 2023 13:47:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15829&amp;PID=152659#152659</guid>
