  <title>R-pod Owners Forum : Remove stereo head unit in RPOD 192</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Remove stereo head unit in RPOD 192</description>
  <pubDate>Sun, 25 Oct 2026 19:27:06 +0000</pubDate>
  <lastBuildDate>Sat, 19 Aug 2023 21:55:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15819</WebWizForums:feedURL>
   <title>Remove stereo head unit in RPOD 192 : One of the first modification...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152589#152589</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7876" rel="nofollow">seafans</a><br /><strong>Subject:</strong> 15819<br /><strong>Posted:</strong> 19 Aug 2023 at 9:55pm<br /><br />One of the first modification I did was replace the receiver unit in my 192.&nbsp; Mostly after I discovered the USB port does not read,only for charging.&nbsp; There is a panel inside the cabinet behind the receiver that needs to be removed, 4 screws I think so.&nbsp; Then you can trace out all of the wires.&nbsp; The front panel on the receiver snaps off.&nbsp; Be careful not to crack it.&nbsp; Then you have access to the screws.&nbsp; If all you want to do is check the wires the receiver does not need to be removed.&nbsp; There are no connections from the TV to the receiver.&nbsp; Have to use the output on the TV to input on the receiver some how.<br>]]>
   <pubDate>Sat, 19 Aug 2023 21:55:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152589#152589</guid>
   <title>Remove stereo head unit in RPOD 192 : If you have the iRV Technologies...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152587#152587</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11535" rel="nofollow">Rpod-Couple</a><br /><strong>Subject:</strong> 15819<br /><strong>Posted:</strong> 19 Aug 2023 at 7:36pm<br /><br />If you have the iRV Technologies radio, the mounting screws are hidden behind two black plastic vertical covers. One on right and other on left side. They are held on by magnets. You can pull these off to get to the screws behind them.]]>
   <pubDate>Sat, 19 Aug 2023 19:36:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152587#152587</guid>
   <title>Remove stereo head unit in RPOD 192 : I want to remove the stereo head...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152582#152582</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12622" rel="nofollow">Grinkle192</a><br /><strong>Subject:</strong> 15819<br /><strong>Posted:</strong> 19 Aug 2023 at 3:16pm<br /><br /><div>I want to remove the stereo head unit from its wall mount inside my RPOD 192 and I can't figure out how to do that.&nbsp; I am getting worried that it might be mounted at the factory before the cabinets have been completely built, and after the cabinets are completed there is no easily reversible way to remove the stereo.&nbsp; Does anyone know?</div><div><br></div><div>I want to make sure the TV outputs are hooked up properly to the back of the head unit, I can't get the TV audio to play on the stereo, is my motivation.<br></div>]]>
   <pubDate>Sat, 19 Aug 2023 15:16:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15819&amp;PID=152582#152582</guid>
