  <title>R-pod Owners Forum : Gray Dump Valve Broke</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Gray Dump Valve Broke</description>
  <pubDate>Mon, 26 Oct 2026 01:23:01 +0000</pubDate>
  <lastBuildDate>Mon, 22 May 2023 12:44:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15705</WebWizForums:feedURL>
   <title>Gray Dump Valve Broke : I recently replaced both gate...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151889#151889</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12719" rel="nofollow">abikerider</a><br /><strong>Subject:</strong> 15705<br /><strong>Posted:</strong> 22 May 2023 at 12:44pm<br /><br />I recently replaced both gate valves on my 172 with the same setup. It was not easy but there should be enough flex in the plastic to get it in there. I was also thinking about removing the pipe from the tank outlet and was wondering the same thing about the stuff the used to seal the connection. Maybe you can have someone pull apart the two halves while you stick the new valve in there? It took me a few tries to get it in there with the gaskets lined up.]]>
   <pubDate>Mon, 22 May 2023 12:44:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151889#151889</guid>
   <title>Gray Dump Valve Broke : If you need to cut the pipe going...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151868#151868</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15705<br /><strong>Posted:</strong> 19 May 2023 at 6:40pm<br /><br />If you need to cut the pipe going into a fitting and need to reuse the fitting, there are reamers/cutters that plumbers use to get the old plastic pipe out of a fitting. &nbsp;I was watching someone use one the other day. &nbsp;I had never seen a bit like that before. &nbsp;It was attached to a large drill motor with a right angle adapter. &nbsp;I have no idea what these reamer/cutters cost. &nbsp;It may be more economical to get a plumber who works a lot with abs pipe to give you a hand. &nbsp;]]>
   <pubDate>Fri, 19 May 2023 18:40:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151868#151868</guid>
   <title>Gray Dump Valve Broke :  Why not just replace the han...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151867#151867</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15705<br /><strong>Posted:</strong> 19 May 2023 at 4:38pm<br /><br />Why not just replace the handle?<div><a href="https://amaz&#111;n.com/Waste-Valve-Handle-Replacement-Extensi&#111;n/dp/B089YWNDHL/" target="_blank">https://amazon.com/Waste-Valve-Handle-Replacement-Extension/dp/B089YWNDHL/</a><br></div><div>Edit:</div><div>This one is metal:</div><div><a href="https://www.amaz&#111;n.com/Valterra-T1003-6MNVP-Bladex-Carded-Handle/dp/B006JRJA0Y/" target="_blank">https://www.amazon.com/Valterra-T1003-6MNVP-Bladex-Carded-Handle/dp/B006JRJA0Y/</a><br></div>]]>
   <pubDate>Fri, 19 May 2023 16:38:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151867#151867</guid>
   <title>Gray Dump Valve Broke :              Normal   0 ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151865#151865</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 15705<br /><strong>Posted:</strong> 19 May 2023 at 3:13pm<br /><br /><!--if gte mso 9> <o:OfficeSettings>  <o:AllowPNG/> </o:OfficeSettings><!--><!--if gte mso 9> <w:Word>  <w:View>Normal</w:View>  <w:Zoom>0</w:Zoom>  <w:TrackMoves/>  <w:Trackatting/>  <w:Punctuati&#111;nKerning/>  <w:ValidateAgainstSchemas/>  <w:SaveIfInvalid>false</w:SaveIfInvalid>  <w:IgnoreMixed>false</w:IgnoreMixed>  <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>  <w:D&#111;notPromoteQF/>  <w:LidThemeOther>EN-US</w:LidThemeOther>  <w:LidThemeAsian>X-NONE</w:LidThemeAsian>  <w:LidThemeComplex>X-NONE</w:LidThemeComplex>  <w:Compatibility>   <w:BreakWrappedTables/>   <w:SnapToGridInCell/>   <w:WrapTextWithPunct/>   <w:UseAsianBreakRules/>   <w:D&#111;ntGrowAutofit/>   <w:SplitPgBreakAndark/>   <w:EnableKerning/>   <w:D&#111;ntFlipMirrorIndents/>   <w:OverrideTableStyleHps/>  </w:Compatibility>  <m:mathPr>   <m:mathFont m:val="Cambria Math"/>   <m:brkBin m:val="before"/>   <m:brkBinSub m:val="&amp;#45;-"/>   <m:smallFrac m:val="off"/>   <m:dispDef/>   <m:lMargin m:val="0"/>   <m:rMargin m:val="0"/>   <m:defJc m:val="centerGroup"/>   <m:wrapIndent m:val="1440"/>   <m:intLim m:val="subSup"/>   <m:naryLim m:val="undOvr"/>  </m:mathPr></w:Word><!--><!--if gte mso 9> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="false"    DefSemi="false" DefQat="false" DefPriority="99"    LatentStyleCount="376">  <w:LsdExcepti&#111;n Locked="false" Priority="0" Qat="true" Name="Normal"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Qat="true" Name="ing 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="9" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="ing 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index 9"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 7"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 8"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Name="toc 9"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="er"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footer"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="index ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="35" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="capti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of figures"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="envelope return"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="footnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="line number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="page number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote reference"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="endnote text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="table of authorities"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="macro"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="toa ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Bullet 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List Number 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="10" Qat="true" Name="Title"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Closing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Signature"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Semi="true"     UnhideWhenUsed="true" Name="Default Paragraph Font"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="List C&#111;ntinue 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Message er"/>  <w:LsdExcepti&#111;n Locked="false" Priority="11" Qat="true" Name="Subtitle"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Salutati&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Date"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text First Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Note ing"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Text Indent 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Block Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Hyper"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="FollowedHyper"/>  <w:LsdExcepti&#111;n Locked="false" Priority="22" Qat="true" Name="Str&#111;ng"/>  <w:LsdExcepti&#111;n Locked="false" Priority="20" Qat="true" Name="Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Plain Text"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="E-mail Signature"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Top of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Bottom of "/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Web"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Acr&#111;nym"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Address"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Cite"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Code"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Definiti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Keyboard"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Preatted"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" le"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" r"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name=" Variable"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Normal Table"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="annotati&#111;n subject"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="No List"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Outline List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Simple 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table ic 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Colorful 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Columns 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Grid 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 4"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 5"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 7"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table List 8"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table 3D effects 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table C&#111;ntemporary"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Elegant"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Professi&#111;nal"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Subtle 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 2"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Web 3"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Ballo&#111;n Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Name="Table Grid"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Table Theme"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Placeholder Text"/>  <w:LsdExcepti&#111;n Locked="false" Priority="1" Qat="true" Name="No Spacing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" Name="Revisi&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Priority="34" Qat="true"     Name="List Paragraph"/>  <w:LsdExcepti&#111;n Locked="false" Priority="29" Qat="true" Name="Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="30" Qat="true"     Name="Intense Quote"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="60" Name="Light Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="61" Name="Light List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="62" Name="Light Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="63" Name="Medium Shading 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="64" Name="Medium Shading 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="65" Name="Medium List 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="66" Name="Medium List 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="67" Name="Medium Grid 1 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="68" Name="Medium Grid 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="69" Name="Medium Grid 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="70" Name="Dark List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="71" Name="Colorful Shading Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="72" Name="Colorful List Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="73" Name="Colorful Grid Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="19" Qat="true"     Name="Subtle Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="21" Qat="true"     Name="Intense Emphasis"/>  <w:LsdExcepti&#111;n Locked="false" Priority="31" Qat="true"     Name="Subtle Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="32" Qat="true"     Name="Intense Reference"/>  <w:LsdExcepti&#111;n Locked="false" Priority="33" Qat="true" Name="Book Title"/>  <w:LsdExcepti&#111;n Locked="false" Priority="37" Semi="true"     UnhideWhenUsed="true" Name="Bibliography"/>  <w:LsdExcepti&#111;n Locked="false" Priority="39" Semi="true"     UnhideWhenUsed="true" Qat="true" Name="TOC ing"/>  <w:LsdExcepti&#111;n Locked="false" Priority="41" Name="Plain Table 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="42" Name="Plain Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="43" Name="Plain Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="44" Name="Plain Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="45" Name="Plain Table 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="40" Name="Grid Table Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="Grid Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="Grid Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="Grid Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="Grid Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="Grid Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="Grid Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="Grid Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="Grid Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="Grid Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="Grid Table 7 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46" Name="List Table 1 Light"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51" Name="List Table 6 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52" Name="List Table 7 Colorful"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 1"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 2"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 3"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 4"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 5"/>  <w:LsdExcepti&#111;n Locked="false" Priority="46"     Name="List Table 1 Light Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="47" Name="List Table 2 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="48" Name="List Table 3 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="49" Name="List Table 4 Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="50" Name="List Table 5 Dark Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="51"     Name="List Table 6 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Priority="52"     Name="List Table 7 Colorful Accent 6"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Menti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Smart Hyper"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Hashtag"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Unresolved Menti&#111;n"/>  <w:LsdExcepti&#111;n Locked="false" Semi="true" UnhideWhenUsed="true"     Name="Smart "/> </w:LatentStyles><!--><!--if gte mso 10> /* Style Definitions */ table.MsoNormalTable	{mso-style-name:"Table Normal";	mso-tstyle-rowband-size:0;	mso-tstyle-colband-size:0;	mso-style-noshow:yes;	mso-style-priority:99;	mso-style-parent:"";	mso-padding-alt:0in 5.4pt 0in 5.4pt;	mso-para-margin-top:0in;	mso-para-margin-right:0in;	mso-para-margin-bottom:8.0pt;	mso-para-margin-left:0in;	line-height:107%;	mso-pagination:widow-orphan;	font-size:11.0pt;	font-family:"Calibri",sans-serif;	mso-ascii-font-family:Calibri;	mso-ascii-theme-font:minor-latin;	mso-hansi-font-family:Calibri;	mso-hansi-theme-font:minor-latin;	mso-bidi-font-family:"Times New Roman";	mso-bidi-theme-font:minor-bidi;	mso-font-kerning:1.0pt;	mso-ligatures:standardcontextual;}<!--><p ="Ms&#111;normal">This is the second time I’ve managed to break the plastichandle on the Gray Dump valve.<span style="mso-spacerun:yes">&nbsp; </span>On theR172 both Black and Gray are plumbed to the “exit”. <span style="mso-spacerun:yes">&nbsp;&nbsp;</span>I’ve loosened the black and gray hangerstraps, pulled out the old gray valve, and now I'm to where I can’t get the new onein without turning the gaskets in or out of shape.<span style="mso-spacerun:yes">&nbsp; </span>Just can’t get a 1” clearance so I’m thinkingof dropping the pipe connection at the gray tank, place the new dump valve,reinstall the pipe at the tank.<span style="mso-spacerun:yes">&nbsp; </span>At the tank thereis a hose clamp and some type of soft caulk or putty.<span style="mso-spacerun:yes">&nbsp; </span>Does anyone know what the putty is, or maybea better way to attack this sucker?</p><p ="Ms&#111;normal">Added note, R172 doesn't have anyplace to cut the pipe and install a union. Elbows, valve fittings, Everything are jammed together.<br></p>]]>
   <pubDate>Fri, 19 May 2023 15:13:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15705&amp;PID=151865#151865</guid>
