  <title>R-pod Owners Forum : Replacing 7 Pin Plug</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Replacing 7 Pin Plug</description>
  <pubDate>Mon, 26 Oct 2026 00:02:09 +0000</pubDate>
  <lastBuildDate>Tue, 23 May 2023 10:09:37 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15704</WebWizForums:feedURL>
   <title>Replacing 7 Pin Plug : For another ~~ $15 you can get...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151898#151898</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 23 May 2023 at 10:09am<br /><br />For another ~~ $15 you can get the <a href="https://www.amaz&#111;n.com/Trailer-Harness-C&#111;ntrol-10-14AWG-C&#111;nnector/dp/B07G8QHWD1/ref=asc_df_B07G8QHWD1?tag=bngsmtphsnus-20&amp;linkCode=df0&amp;hvadid=79920869053501&amp;hvnetw=s&amp;hvqmt=e&amp;hvbmt=be&amp;hvdev=c&amp;hvlocint=&amp;hvlocphy=&amp;hvtargid=pla-4583520395744729&amp;th=1" target="_blank">whole enchilada</a>.]]>
   <pubDate>Tue, 23 May 2023 10:09:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151898#151898</guid>
   <title>Replacing 7 Pin Plug : I found this one on Amazon that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151890#151890</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12719" rel="nofollow">abikerider</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 22 May 2023 at 12:48pm<br /><br />I found this one on Amazon that says it is waterproof. I haven't installed it yet.<div>https://www.amazon.com/gp/product/B0BJ1Z26MQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1</div>]]>
   <pubDate>Mon, 22 May 2023 12:48:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151890#151890</guid>
   <title>Replacing 7 Pin Plug : +2 to GlueGuy, You might find...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151863#151863</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6578" rel="nofollow">SC for Huskers</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 19 May 2023 at 10:05am<br /><br /><div>+2 to GlueGuy,&nbsp; You might find what you need on amazon,</div><div><br></div><div>https://www.amazon.com/s?k=7pin+trailer+wiring+harness&amp;crid=R62BKJFFJKL0&amp;sprefix=7pin+%2Caps%2C574&amp;ref=nb_sb_ss_ts-doa-p_3_5</div><div><br></div><div>I've replaced mine with a 7 foot cord.&nbsp; There should be a junction box under and near the front of the camper.&nbsp; <br></div>]]>
   <pubDate>Fri, 19 May 2023 10:05:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151863#151863</guid>
   <title>Replacing 7 Pin Plug : +1 to GlueGuy. Trying to rewire...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151862#151862</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 19 May 2023 at 9:51am<br /><br />+1 to GlueGuy. &nbsp;Trying to rewire a new 7 pin plug from the existing cable is going to introduce an unsealed connection that is a weak point for the entire cable and can let in water and other corrosive stuff. &nbsp;]]>
   <pubDate>Fri, 19 May 2023 09:51:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151862#151862</guid>
   <title>Replacing 7 Pin Plug : I would replace the entire cord...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151861#151861</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 19 May 2023 at 9:40am<br /><br />I would replace the entire cord as an integrated unit.]]>
   <pubDate>Fri, 19 May 2023 09:40:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151861#151861</guid>
   <title>Replacing 7 Pin Plug : Thank you Both! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151860#151860</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12907" rel="nofollow">DD08</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 19 May 2023 at 8:15am<br /><br />Thank you Both!&nbsp;]]>
   <pubDate>Fri, 19 May 2023 08:15:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151860#151860</guid>
   <title>Replacing 7 Pin Plug : Always disconnect the NEGATIVE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151859#151859</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7876" rel="nofollow">seafans</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 18 May 2023 at 8:31pm<br /><br />Always disconnect the NEGATIVE side first.&nbsp; That way if the wrench inadvertently touches the frame it will not cause and ark.&nbsp; And always connect the positive first, for the same reason. <br>]]>
   <pubDate>Thu, 18 May 2023 20:31:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151859#151859</guid>
   <title>Replacing 7 Pin Plug : Disconnect the battery positive...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151858#151858</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8268" rel="nofollow">Ben Herman</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 18 May 2023 at 6:21pm<br /><br />Disconnect the battery positive side]]>
   <pubDate>Thu, 18 May 2023 18:21:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151858#151858</guid>
   <title>Replacing 7 Pin Plug : Hello All,Maybe a very silly question....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151857#151857</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12907" rel="nofollow">DD08</a><br /><strong>Subject:</strong> 15704<br /><strong>Posted:</strong> 18 May 2023 at 4:06pm<br /><br />Hello All,<div><br></div><div>Maybe a very silly question. But the 7 pin plug on the trailer end seemed to have been dragged on the ground and the pins wont connect to my truck anymore. I'm going to just snip the plug off and replace. Have no problems doing that through some tutorials but I have a silly question.</div><div><br></div><div><br></div><div>Is there any power or battery switch I need to turn off in the trailer so I don't potentially shock myself when cutting off the trailer plug end?&nbsp;</div>]]>
   <pubDate>Thu, 18 May 2023 16:06:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15704&amp;PID=151857#151857</guid>
