  <title>R-pod Owners Forum : A/C cutting off</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : A/C cutting off</description>
  <pubDate>Sun, 25 Oct 2026 21:46:54 +0000</pubDate>
  <lastBuildDate>Sat, 06 May 2023 07:15:20 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15672</WebWizForums:feedURL>
   <title>A/C cutting off : Finally a reply. Thanks for answering....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151740#151740</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12886" rel="nofollow">Slickdog</a><br /><strong>Subject:</strong> 15672<br /><strong>Posted:</strong> 06 May 2023 at 7:15am<br /><br />Finally a reply. Thanks for answering. I was leaning toward the t-stat but been down that rabbit hole before 'parts changing' before finally Forest Gumping my way into a solution. I'll need to research how to test a start capacitor. I've replaced them before on my home a/c unit but it was obvious they were bad, they were swelled up.<br /><br />Thanks again, I'll let you know how what I figure out.]]>
   <pubDate>Sat, 06 May 2023 07:15:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151740#151740</guid>
   <title>A/C cutting off : First thing to try is a replacement...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151738#151738</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11092" rel="nofollow">KirkH</a><br /><strong>Subject:</strong> 15672<br /><strong>Posted:</strong> 05 May 2023 at 6:42pm<br /><br />First thing to try is a replacement therostat.&nbsp; Next thing to check would be the start capacitor on the roof.&nbsp; Test it with an electrical meter.<br>]]>
   <pubDate>Fri, 05 May 2023 18:42:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151738#151738</guid>
   <title>A/C cutting off : Hello All,  Hope someone can help...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151578#151578</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12886" rel="nofollow">Slickdog</a><br /><strong>Subject:</strong> 15672<br /><strong>Posted:</strong> 21 Apr 2023 at 2:01pm<br /><br />Hello All, <br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Hope someone can help with this problem. We just returned from a 2 week trip and only needed to run the a/c a couple of hours on a few days. The last time we ran it on 'low fan/cool' it would shut off, fan and compressor. Breaker not tripped.  Would have to turn off at thermostat and restart without problem, but then it would shut off again, I suspect when temp reached. I understand this is normal in 'auto' mode but not in 'fan/cool' mode. <br /><br />I'm pretty handy just not a great diagnostician. Any advice would be greatly appreciated. TY]]>
   <pubDate>Fri, 21 Apr 2023 14:01:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15672&amp;PID=151578#151578</guid>
