  <title>R-pod Owners Forum : 2021 R-pod 196 dust cap rubber seal</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : 2021 R-pod 196 dust cap rubber seal</description>
  <pubDate>Mon, 26 Oct 2026 05:34:24 +0000</pubDate>
  <lastBuildDate>Wed, 22 Mar 2023 09:44:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15637</WebWizForums:feedURL>
   <title>2021 R-pod 196 dust cap rubber seal : Great thank you </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151329#151329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11479" rel="nofollow">Jrfich</a><br /><strong>Subject:</strong> 15637<br /><strong>Posted:</strong> 22 Mar 2023 at 9:44am<br /><br />Great thank you]]>
   <pubDate>Wed, 22 Mar 2023 09:44:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151329#151329</guid>
   <title>2021 R-pod 196 dust cap rubber seal :                 What you describe...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151328#151328</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15637<br /><strong>Posted:</strong> 22 Mar 2023 at 9:39am<br /><br />            What you describe is normal.&nbsp; You may want to compare the cap you purchased with the one that you already have on the other wheel to make certain they are identical.&nbsp; If so, be patient with the one you purchased, get it good and warm if it is cold outside (let it sit in some hot water for a minute to soften the rubber), it should slide in the groove quite easily.]]>
   <pubDate>Wed, 22 Mar 2023 09:39:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151328#151328</guid>
   <title>2021 R-pod 196 dust cap rubber seal : I have a r-pod 196. I went to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151325#151325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11479" rel="nofollow">Jrfich</a><br /><strong>Subject:</strong> 15637<br /><strong>Posted:</strong> 22 Mar 2023 at 8:05am<br /><br />I have a r-pod 196. I went to grease the bearings and noticed there was no rubber cap on one side covering the zerk fitting. I bought a new rubber cap but cant install it as the serk fitting sticks out a little bit past <br />the dust cap. Is this normal? I bought  this camper new in 2021.]]>
   <pubDate>Wed, 22 Mar 2023 08:05:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15637&amp;PID=151325#151325</guid>
