  <title>R-pod Owners Forum : Frames and axels</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Warranty, Service and Recall Bulletins : Frames and axels</description>
  <pubDate>Sat, 07 Nov 2026 05:08:21 +0000</pubDate>
  <lastBuildDate>Sun, 04 Dec 2022 12:43:37 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15519</WebWizForums:feedURL>
   <title>Frames and axels : It&amp;#039;s the axle imposing stress...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150230#150230</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 04 Dec 2022 at 12:43pm<br /><br />It's the axle imposing stress on the frame at that point. Well understood effect of torsion axles. You can see a finite element analysis showing the high stress location here:<div><br></div><div>https://mechanicalelements.com/trailer-axle-springs-torsion-axle/</div>]]>
   <pubDate>Sun, 04 Dec 2022 12:43:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150230#150230</guid>
   <title>Frames and axels : Thanks for the reply, however...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150182#150182</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 29 Nov 2022 at 2:14pm<br /><br />Thanks for the reply, however the frame has a 3 inch crack horizontally at the point where it attaches to the axel. Also at that point there is a buckling of the steel going vertical the length of the frame at the same spot.. The axel was definitely undersized and that was replaced after it was found to be broken 1 year ago. The crack above the door appeared as the frame started cracking and buckling. The crack is definitely from the frame cracking and downward movement and Forest River has seen this before. There is presently over 40 units waiting to be brought back to the factory for repairs. Who is paying for this, I do not know but Lippert in involved.]]>
   <pubDate>Tue, 29 Nov 2022 14:14:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150182#150182</guid>
   <title>Frames and axels : I have heard of the cracks on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150162#150162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 27 Nov 2022 at 11:26am<br /><br />I have heard of the cracks on the outer and inner walls from several people. The cracks predominately happen over the door, in the top left corner. Although your case may be different,&nbsp;It's possible the cracking has nothing to do with the axle.&nbsp; If you look at the crack, it might be apparent that it was caused by "upward" force. The culprit being the stabilizer jacks. The door opening in the rear leaves a very thin strip between the door, and the rear of the camper. The stabilizer is able to put quite a bit of force lifting the back end of the camper with (for lack of a better term) a "hinging" effect. The rear corner being supported only at the top of the door. I noticed that on mine, the rear passenger area was easy to actually lift that corner with minimal effort. There was plenty of support for downward force, but virtually none for upward force.&nbsp;]]>
   <pubDate>Sun, 27 Nov 2022 11:26:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150162#150162</guid>
   <title>Frames and axels :   I finished installing the new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150160#150160</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 26 Nov 2022 at 6:20pm<br /><br />&nbsp; &nbsp;I finished installing the new leaf springs the springs now have a nice arch and I guess it may have raised the camper about 1 1/2 inches. I feel a lot safer now that the springs will not break and have more clearance for the wheels around the wheel wells it was money well spent. Would like to add the Unijack we just bought worked great and I think it would be a good jack for a r-pod or any small camper.]]>
   <pubDate>Sat, 26 Nov 2022 18:20:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150160#150160</guid>
   <title>Frames and axels : +1. In the meantime you can import...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150147#150147</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 25 Nov 2022 at 8:33am<br /><br />+1. In the meantime you can import foreign manufactured&nbsp; vehicles if they're over 25 years old without them meeting federal standards. Beware your state requirements though. The Japanese ones I'm looking at are very practically designed, fiberglass coach work,&nbsp; high on quality and low on unnecessary frills. They also tend to be well maintained and have low odometer readings. Very robust 4wd diesel truck chassis, don't think bent frames and axles are a problem. But they won't win any races for sure. Don't know about importing towables.&nbsp;<div><br></div><div>Examples:&nbsp;</div><div><br></div><div>https://www.elismotorsjdm.com/rvcamper.html</div>]]>
   <pubDate>Fri, 25 Nov 2022 08:33:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150147#150147</guid>
   <title>Frames and axels : Just as happened with the automotive...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150146#150146</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 25 Nov 2022 at 6:00am<br /><br />Just as happened with the automotive industry, when foreign competitors entered the market with better quality vehicles at lower prices, if we ever get foreign competition coming into our market place, we may see some significant improvement in quality. &nbsp;Some of the Canadian trailer companies are putting out some very nice products, but they are still on the upper end of the price scale. &nbsp;When I was in Spain a few &nbsp;years ago I looked at the offerings there and the build quality was noticeably better and the prices were competitive for under 25' travel trailers. &nbsp;]]>
   <pubDate>Fri, 25 Nov 2022 06:00:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150146#150146</guid>
   <title>Frames and axels : Well, look at it this way. Upgrading...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150144#150144</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 25 Nov 2022 at 2:25am<br /><br />Well, look at it this way. Upgrading leaf springs is cheap and simple and they're easy on the trailer frame. Often you can just add a leaf to an existing spring, not sure if that's possible on Lippert springs. If&nbsp; that's all that's needed to get an inexpensive trailer to survive reasonable usage then I'd go for it. But unfortunately you still have the cabin integrity issues (water leaks and joints coming apart)...<div>&nbsp;</div><div><br></div><div>So I do think the two piece fiberglass RVs (either trailers or motorized) are going to result in a better long termownership experience. That's where I'm heading, in my case motorized this time. I'm looking at old 1980s Toyota mini motorhomes with fiberglas cabins. But I'd have to find a rust free unit, rust was a big problem in vehicles of that vintage. The other options are Chinooks and Xplorers on Ford, Chevy, or Dodge chassis, and Casita or Scamp on the towable RV side. And one other option I'm looking at on the motorized side. 1990s Japanese domestic imported micro motorhomes on 4wd diesel light truck chassis. Right hand drive, manual transmissions with 2 speed transfer cases, what could be more fun than that?&nbsp;</div>]]>
   <pubDate>Fri, 25 Nov 2022 02:25:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150144#150144</guid>
   <title>Frames and axels :   As sure as the sun rises in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150142#150142</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 24 Nov 2022 at 4:32pm<br /><br />As sure as the sun rises in the east, we can count on RV manufacturers building nearly everything they offer to absolute minimal standards. &nbsp;It's all glitter and ting ting to catch the eye of the buyer, but the underlying structure is just barely. &nbsp;We've had good luck with our leaf springs, but we tend to travel relatively light. &nbsp;Since laundromats and food shops are mostly available all over the country, we have little need to pack the trailer to the gills. &nbsp;I'd like to put some shock absorbers on the suspension, but it'd probably void what's left of the Lippert limited axle warranty.]]>
   <pubDate>Thu, 24 Nov 2022 16:32:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150142#150142</guid>
   <title>Frames and axels : I am in the process of replacing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150141#150141</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 24 Nov 2022 at 4:18pm<br /><br />&nbsp; &nbsp;I am in the process of replacing the leaf springs on our Vista 19BFD the factory put 2,000 Lb springs on the axle with a 4,000 lb axle. If you check their website and look at the specifications of a 19BFD the 4,000 Lb leaf springs will not be strong enough and that's why I am replacing them. Broken leaf springs on their Vista and Vintage cruiser trailers were mentioned on Facebook owners forum and upgrading their leaf springs. I am replacing them with 2,500 lb leaf springs the factory 2,000 lb leaf springs were nearly flat from not being able to support the weight within the factory specifications. My experience with owning two FR campers and one Gulf Stream camper they are built with minimum quality and my own opinion they are built for looks not reliability. I agree with offgrid buy a used camper and do not buy new and hopefully the previous owner will have made most of the necessary repairs and upgrades.]]>
   <pubDate>Thu, 24 Nov 2022 16:18:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150141#150141</guid>
   <title>Frames and axels :  LA, great write up. I&amp;#039;d...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150132#150132</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 24 Nov 2022 at 10:01am<br /><br />LA, great write up. I'd only add that Lippert would very likely go beyond the 4 corners of it's written warranty if FR asked, they have to be one of Lipperts largest sales accounts. IOW, if there was a gray area if responsibility between the two companies, FR would very likely win that battle without having to fire much of a shot. That doesn't help the end customer&nbsp; we have zero leverage with either company.<div><br></div><div>As to your other question, without doubt Lippert and FR's engineering staff collaborate closely during the trailer design process, and if FR needs a new design from Lippert, they will get it. For example, I was told by Lippert that the part number on my 179s axle indicated that it was specifically built for that trailer, not generic at all.&nbsp;</div><div><div><br></div><div>&nbsp;</div></div>]]>
   <pubDate>Thu, 24 Nov 2022 10:01:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150132#150132</guid>
   <title>Frames and axels : The axle problem seems to be very...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150123#150123</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 24 Nov 2022 at 7:11am<br /><br />The axle problem seems to be very curious. &nbsp;Presumably, Lippert sells chassis and axles to trailer manufacturers based on the performance and dimension specifications provided by the trailer manufacturer. &nbsp;To our more knowledgable board members: &nbsp;Is this a correct assumption, or does Lippert (and other chassis manufactures) build them as a more fungible product that the trailer builder just picks from a list of chassis and axles that are manufactured generically and sold based on weight capacity, length, and width?<div><br></div><div>If the axle they provide does not meet the dimensional and performance specifications either specified by the trailer builder or as listed in the Lippert specifications, then ultimately they bear responsibility for the failure. &nbsp;If the chassis and axle are built to the trailer builder's specifications and it fails when the trailer is used in a manner that is reasonably foreseeable for a vacation trailer, then it is the trailer manufacturer's responsibility if a failure occurs within the warranty period. &nbsp;If the use of the trailer is unreasonable or constitutes an abuse, then the warranty is void.</div><div><br></div><div>The real question are what constitutes reasonable and foreseeable use, and what is a "subtantial" defect. &nbsp;&#091;The pre-June, 30,2021, warranty language is pretty much irrelevant as the warranty period has already expired, except to the extent the Lippert axle warranty may apply. &nbsp;The Lippert frame warranty, according to their web site, is 1 year.&#093; &nbsp;Under the current "warranty," Forrest River is not responsible for much. &nbsp;<a href="https://www.forestriverinc.com/downloads/TowableWarranty2021.pdf" target="_blank">https://www.forestriverinc.com/downloads/TowableWarranty2021.pdf</a>&nbsp; If the defect is not "substantial," then it's not covered. "Substantial Defects are those defects which prevent the RV from performing its intended use for <b><i>short term</i> </b>recreational camping." &#091;Emphasis added.&#093;&nbsp;Dealer representations about what is covered or not covered by the warranty are specifically disowned by FR. &nbsp;The warranty only applies to the first retail sale of the trailer by an authorized dealer. &nbsp;It is not transferable. &nbsp;If you purchase a trailer that is not the current "model year" then the warranty is 90 days, not 1 year. &nbsp;Also, little stuff, such as door or window adjustments, are only covered for 90 days. &nbsp;Specifically excluded from the warranty: &nbsp;"The chassis including without limitation, any mechanical parts or systems of the <i><b>chassis, frame, axles</b>,</i> tires, tubes, batteries, gauges, or optional generators." &nbsp;&#091;Emphasis added.&#093; &nbsp;Also excluded are road hazard damage and damage from "off road" use. &nbsp;So if you hit a pothole on I-20 in Louisiana, which I am told there are some huge ones, tough luck. &nbsp;The warranty limitations can vary from state to state, but in most states where there is little in the way of consumer protection law, you're screwed unless FR or the dealer feels like being nice to you.</div><div><br></div><div>The warranty overrides the Uniform Commercial Code protections in most states, so the implied warranty of fitness for the intended use doesn't help you. &nbsp;A failure of the product which damages the product leaves you with essentially no remedy, except as specifically stated in the warranty. &nbsp;If there is a design defect in the trailer, such an axle or chassis failure, that leads to an accident, then different rules apply and the manufacturer is responsible for compensation for the injury, but not consequential damages to the trailer.</div><div><br></div><div>If you have a warranty claim, the best you can hope for is that FR wants you to buy another trailer from them someday and might be nice to you. &nbsp;If they deny your warranty claim, even if you are right and they are giving you the proverbial middle finger, there is really not much you can do. &nbsp;Of course, you can sue them, but the attorneys fees would very quickly exceed the value of the trailer. &nbsp;Also, you have to go to Indiana to sue. &nbsp;They chose the forum in their warranty and you can count on Indiana law not being very favorable to consumers with travel trailer warranty disputes.</div><div><br></div><div>Speaking for myself, I would never, ever, buy a new FR travel trailer product again. &nbsp;The warranty is illusory and it isn't worth the extra money you'd spend on a new trailer. &nbsp;If I were to be in the travel trailer market again, I would buy a used one that has been used enough to reveal any structural or other defects. &nbsp;If you can't fully inspect the used trailer for defects yourself, then it's worth hiring an independent trailer mechanic to do a thorough pre-purchase inspection. &nbsp;Also, buying a trailer that is out of warranty and your not being in "privity" &#091;having a contractual relationship&#093; with FR means that the limitations for legal remedies, such as having to sue in Indiana, would not apply in the event someone got hurt using the trailer. &nbsp;As for fixing or replacing the trailer itself, you are on your own.</div><div><br></div>]]>
   <pubDate>Thu, 24 Nov 2022 07:11:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150123#150123</guid>
   <title>Frames and axels : Since the dealer is responsible...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150119#150119</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 24 Nov 2022 at 4:20am<br /><br />Since the dealer is responsible for the lift kit he will be&nbsp; your ally, he wont want FR to blame the lift. He probably got the lift kit from FR or Lippert anyhow. FR needs happy dealers so I don't think you need to worry about the lift part of it. Good luck!]]>
   <pubDate>Thu, 24 Nov 2022 04:20:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150119#150119</guid>
   <title>Frames and axels : Thank you for the response.The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150117#150117</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 23 Nov 2022 at 9:19pm<br /><br />Thank you for the response.&nbsp;<div><br></div><div>The knowledge you have to offer is appreciated. The Axel lifts was installed by the dealer I purchased the trailer from. I hope someone covers the damage. The trailers being 2 years old.&nbsp;</div><div><br></div><div>I will keep you informed as to how FR chooses to handle this.</div>]]>
   <pubDate>Wed, 23 Nov 2022 21:19:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150117#150117</guid>
   <title>Frames and axels : Thank you offgrid for your explanation,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150097#150097</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 21 Nov 2022 at 9:58am<br /><br />&nbsp; Thank you offgrid for your explanation, I think you could have been an engineering professor! I think I will be cautious in driving to avoid big bumps driving fast and be very careful not to overload our camper. I did take it to a scale once when loaded to get an idea where our camper weight was loaded.]]>
   <pubDate>Mon, 21 Nov 2022 09:58:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150097#150097</guid>
   <title>Frames and axels : There is DOT oversight in the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150095#150095</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 21 Nov 2022 at 3:16am<br /><br />There is DOT oversight in the trailer load rating system, just not formal engineering standards for what safety factors need to be assumed when designing the trailer axle and structure&nbsp;&nbsp;<div><br></div><div>As I understand it the DOT requires the manufacturer to post a max trailer weight (dry plus cargo) not to exceed the axle weight rating plus tongue weight (or lowest tongue weight if there is a range). The DOT&nbsp; doesn't mandate what constitutes a reasonable axle or frame weight rating as far as I can tell.&nbsp;</div><div><br></div><div>When I looked into the safety factors (expressed as g forces) engineers use when designing vehicle structures and suspensions I found numbers in the range of 2.5-3 g's for heavy trucks and more like 3-3.5 gs for lighter passenger vehicles, which get thrown around more. I could find general ranges only, the actual numbers used by each vehicle manufacturer are proprietary.&nbsp;<div><br></div><div>When I analysed the axle and frame of my 179 I came up with yield points (loads there you'd expect the steel structural members to begin to fail in bending) at around 2gs or a bit less on a fully loaded trailer.</div><div><div><br></div><div>&nbsp;2gs isnt normal but also isn't all that uncommon when hitting a pothole or curb, for example. You'd&nbsp; notice it when it happened, but you might also think it wasn't that serious an event.&nbsp; If you want you can download&nbsp; an app on your smartphone and use it to record g forces as youre diving around.&nbsp;</div><div><br></div><div>So it isn't very surprising to me that some folks end up with bent franes and axles, while most folks can go through their whole trailer ownership and not have any problems. You likely have to be pretty heavily loaded and then also hit a pothole or curb fairly hard, but perhaps not so hard that you'd expect to have bent something.</div><div><br></div><div>In contrast, 2.5 gs on a heavy truck or 3&nbsp; on a passenger vehicle would be really quite an extreme event. As the driver you would probably expect to have broken something under those conditions.&nbsp;</div><div><br></div><div>&nbsp;I think what's going on is since there isn't a formal&nbsp; standard the RV industry, in the interest of light weight and low price the RV engineers are selecting structural members that provide that 2g ish safely factor, just high enough to prevent a flood of complaints. That's good engineering actually, no engineer anywhere, not even at NASA, will design something to survive all possible conditions, he or she would be quickly looking for alternative employment.&nbsp;</div><div><br></div><div>Engineers without external regulatory requirements design stuff with the safety factors the company has established internally. They also all sign NDAs as a condition of employment so they can't talk about it. They do know what they're doing for sure&nbsp; the engineering involved isn't rocket science by any means.&nbsp;</div><div><br></div><div>So because of the limited DOT oversight, to be able to call out the manufacturers on this issue you would need to show that a reasonable engineer would not select structural members with such low factors of safety. That would be quite difficult because the designs arent wildly out of expectations.</div><div><br></div><div>&nbsp;So what to do as an owner? I think there are 5 choices, listed below in rough order of effectiveness at preventing damage. YMMV.</div><div><br></div><div>Buy a motorized RV built on a truck chassis by a global vehicle manufacturer. You're more likely to get something designed to the 2.5 plus g range that way&nbsp;&nbsp;</div><div><br></div><div>Buy a trailer from a high end long established coachbuilder with a reputation to protect.</div><div><br></div><div>Buy a cheap trailer and reinforce it yourself. Drive carefully.&nbsp;</div><div><br></div><div>Buy a cheap trailer, keep it lightly loaded, and be very diligent about curbs and potholes.</div><div><br></div><div>Buy a cheap trailer, load it up and go banging down bad Forest Service roads at 50 mph. At the end of each season&nbsp; rather than winterize, drop it off at the landfill and buy another one in the spring.</div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div><div><br></div></div></div>]]>
   <pubDate>Mon, 21 Nov 2022 03:16:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150095#150095</guid>
   <title>Frames and axels : I guess without much oversight...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150093#150093</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 20 Nov 2022 at 7:04pm<br /><br />I guess without much oversight the frame manufacturers can put whatever axel they like.]]>
   <pubDate>Sun, 20 Nov 2022 19:04:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150093#150093</guid>
   <title>Frames and axels : Camper specifications are strange...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150092#150092</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 20 Nov 2022 at 6:57pm<br /><br />&nbsp; Camper specifications are strange to me they make no sense. Our Gulf Stream 19BFD Vista Cruiser Has a dry weight of 3,410 lbs. hitch weight 480 lbs. Net caring capacity 1,550 lbs and it has a 4,000 lb axle that is on the label of the axle. If you do the math it makes no sense and when I called the manufacturer they said the wheel hubs can carry more weight. I was concerned about it but I never found anything on the internet of the Vista Cruiser's or Vintage Cruiser's having an axle failure so i just hope and trust the axle never breaks.]]>
   <pubDate>Sun, 20 Nov 2022 18:57:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150092#150092</guid>
   <title>Frames and axels : From your words to you know whos...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150091#150091</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 20 Nov 2022 at 4:00pm<br /><br />From your words to you know whos ear.<div><br></div><div>Thanks for the well worded and engineering point in which you looked at it. I never thought of the r pod as a cheap way of camping as being cheaply manufactured.</div>]]>
   <pubDate>Sun, 20 Nov 2022 16:00:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150091#150091</guid>
   <title>Frames and axels : Agreed, OG. Our 6 year old 179...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150090#150090</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8960" rel="nofollow">gpokluda</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 20 Nov 2022 at 2:45pm<br /><br />Agreed, OG. Our 6 year old 179 with 60K+ miles is still in great shape, but with longer trips for us on the horizon, we knew we would be pushing our luck with the Rpod. This is why we decided to order an Escape 5.0TA late last summer. This week will be our final outing with the 179 for our traditional Thanksgiving camping trip to the warm, southern deserts of New Mexico. The day after Christmas, we leave for Chilliwack, B.C. to pickup the 5.0.&nbsp;<div>As a short haul camper, you can't beat the Rpod for it small size and towability by just about anything with a motor. It is a great choice for the entry level RVer.&nbsp; As a long haul traveler, however, we felt we were rolling the dice on any trip over 300 miles.&nbsp;</div>]]>
   <pubDate>Sun, 20 Nov 2022 14:45:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150090#150090</guid>
   <title>Frames and axels :    To clarify, the 195 has...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150086#150086</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 20 Nov 2022 at 1:48am<br /><br />To clarify, the 195 has a 4400 lb rated axle. That was what was put on it to begin with and that's what you'll have when you get it back.&nbsp; IOW your axle and gross trailer weight ratings wont change. What FR is really saying is that Lippert's original axle wasn't really capable of handling 4400 lbs, and now they will (hopefully) be replacing it with one that is.<div><br></div><div>However, from the way you are describing the damage I don't believe that the failure was in the axle itself. The damage was quite obviously a frame failure. That could well be related to the design of the frame to axle attachment, but I doubt that the axle itself is to blame, or it would be bent. That typically shows up either as one side of the trailer being lower than the other, or one both wheels being de-cambered (wheel tilted inward at the top).&nbsp;</div><div><br></div><div>I suppose it could be that the torsion axle is weak and bottoming out, which in turn is applying a high stress the frame. But that would still be indicative of a marginal frame design. Since Lippert manufactures both the frame and the axle it doesn't really matter, they hold the warranty responsibility either way.&nbsp;</div><div><br></div><div>I just wish FR was more forthcoming regarding these issues, they have a&nbsp; history not only of these types of problems but also of responding to them in this way. They obviously have their customer service folks trained to release the&nbsp; minimum information possible and are treating each incident on a case by case basis, doubtless to avoid&nbsp; broader recalls and lawsuits.</div><div><br></div><div>If you search the history on this forum you'll find many threads on axle, frame, and axle to frame attachment problems and failures. There are no formal engineering standards for design of these systems in travel trailers. Ive analysed the design for my (former) 179 and it would be generous to call it&nbsp; marginal. I reinforced mine as have several other members here. FRs responses have been quite varied as well, ranging from too bad it's your problem to yessir we'll fix it for you right away, sir.&nbsp;</div><div><br></div><div>BTW I don't think any of the major budget trailer manufacturers are going to be any different, this seems to be general industry practice. For this reason I won't own another budget travel trailer. My next RV, if I get another one, will be a class B or C unit built on a motor vehicle chassis. Those are generally&nbsp; built to higher design standards than travel trailers. And I'll get one built by a high quality low volume&nbsp; coachbuilder using a single or 2 piece fiberglass shell, in an attempt to minimize the other two major complaints folks have with their RVs (poor workmanship and water leaks). Those high quality coaches are really spendy so I will buy used, I'd rather have a well cared for high quality used RV than a brand shiny new piece of junk. Of course no matter what&nbsp; RVs are high maintenance&nbsp;&nbsp;</div><div><br></div><div>Sorry if my this offends anyone but I've now owned 6 RVs, all types, looked at many others, and spoken with many owners. That is my opinion of the the RV industry at this point. Rant over....</div>]]>
   <pubDate>Sun, 20 Nov 2022 01:48:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150086#150086</guid>
   <title>Frames and axels : I can only assume that they will...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150081#150081</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 17 Nov 2022 at 3:32pm<br /><br />I can only assume that they will be replacing the axel with a higher rated one.<div><br></div><div>They will be replacing my frame as well as the side wall as well as an interior panel&nbsp;<div><br></div><div>For all that may be in need of the person I contacted.<div>&nbsp;<div>Tina Curtis , She is the r pod warranty administrator. tcurtis@foresrriverinc.com.&nbsp;</div><div><br></div><div>Her number574-535-1546 Ext. 37124</div></div></div></div><div><br></div><div>I hope this helps others</div>]]>
   <pubDate>Thu, 17 Nov 2022 15:32:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150081#150081</guid>
   <title>Frames and axels : follow </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150079#150079</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11194" rel="nofollow">chasl</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 17 Nov 2022 at 12:25pm<br /><br />follow]]>
   <pubDate>Thu, 17 Nov 2022 12:25:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150079#150079</guid>
   <title>Frames and axels : Are they going to replace your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150077#150077</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 16 Nov 2022 at 6:05pm<br /><br />Are they going to replace your axle with one that has a heavier weight rating?&nbsp; Was the original axle rated at 3500 lbs?&nbsp; Thanks<br>]]>
   <pubDate>Wed, 16 Nov 2022 18:05:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150077#150077</guid>
   <title>Frames and axels : After proofreading this after...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150076#150076</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 16 Nov 2022 at 5:14pm<br /><br />After proofreading this after I posted I wanted to make it clear to other owners, Lippert is paying for the frame, outside panel and inside panel of my unit and covering transportation to and from the facility in Illinois.<div><br></div><div>But they have not issued a recall.</div>]]>
   <pubDate>Wed, 16 Nov 2022 17:14:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150076#150076</guid>
   <title>Frames and axels : Hope this helps others,I own a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150075#150075</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12670" rel="nofollow">Scuba Steve</a><br /><strong>Subject:</strong> 15519<br /><strong>Posted:</strong> 16 Nov 2022 at 5:05pm<br /><br />Hope this helps others,<div>I own a 2021 R pod 195. After 1 year I had to have the tongue jack replaced and it fell under the extended warranty. Great</div><div><br></div><div>While it was in for that I found out the axel was busted and that also fell under the extended warranty. Great</div><div><br></div><div>1 year later "now the unit is 2 years old" I realized there was a crack top left of the door on the outside panel of the unit and a bulge on the top right and the door was becoming more difficult to open.</div><div><br></div><div>So I took a look under the unit and the frame under door just behind the axel had a 3 inch crack in it lengthwise and the frame was bending because of this.&nbsp;</div><div><br></div><div>I call r pod warranty and they are aware of the fact that the frame manufacturer "Lippert" put axels on these units that where to small to support the unit. I am in the process of arranging with a transport company to flatbed my unit from NY to Illinois for repairs and Lippert is paying for it.</div><div><br></div><div>So far there is no recall but all owners of these units should be aware of this.</div>]]>
   <pubDate>Wed, 16 Nov 2022 17:05:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15519&amp;PID=150075#150075</guid>
