  <title>R-pod Owners Forum : Rpod single tank regulator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Rpod single tank regulator</description>
  <pubDate>Wed, 23 Sep 2026 16:50:15 +0000</pubDate>
  <lastBuildDate>Mon, 08 Aug 2022 17:41:01 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15423</WebWizForums:feedURL>
   <title>Rpod single tank regulator : I redid the tape and that fixed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149280#149280</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8539" rel="nofollow">Barryb125</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 5:41pm<br /><br />I redid the tape and that fixed the leak. Thanks for your help.]]>
   <pubDate>Mon, 08 Aug 2022 17:41:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149280#149280</guid>
   <title>Rpod single tank regulator : Yes, it&amp;#039;s normal. You will...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149278#149278</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 4:45pm<br /><br />Yes, it's normal. You will see a few threads after it's tightened. You used the yellow tape on the threads before screwing in the threads, right?&nbsp;]]>
   <pubDate>Mon, 08 Aug 2022 16:45:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149278#149278</guid>
   <title>Rpod single tank regulator : I have replaced it and wrapped...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149276#149276</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8539" rel="nofollow">Barryb125</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 4:09pm<br /><br />I have replaced it and wrapped it with gas tape, how tight do those connections fit? Doesn't seem to want to recess completely, I still see some threads, is that normal?<div><br></div><div>Thanks</div><div>Barry</div>]]>
   <pubDate>Mon, 08 Aug 2022 16:09:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149276#149276</guid>
   <title>Rpod single tank regulator : My pigtail developed a leak. You...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149275#149275</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9690" rel="nofollow">poohbill</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 3:52pm<br /><br />My pigtail developed a leak. You might replace it, if you haven't already. Also, doping the connections is always recommended.]]>
   <pubDate>Mon, 08 Aug 2022 15:52:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149275#149275</guid>
   <title>Rpod single tank regulator : Thanks all, replaced the regulator,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149274#149274</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8539" rel="nofollow">Barryb125</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 3:31pm<br /><br />Thanks all, replaced the regulator, now I have a leak and can't figure out why.&nbsp;]]>
   <pubDate>Mon, 08 Aug 2022 15:31:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149274#149274</guid>
   <title>Rpod single tank regulator : The standard single stage regulator...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149273#149273</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 3:24pm<br /><br /><div>The standard single stage regulator made by Camco is item# 17-59013. Cost (2020 price) $ 25.</div><div>If you plan on running a few appliances together then (fridge, HW heater, stove, furnace and outdoor cook stove) you may opt for the two stage model.&nbsp; <br></div><div><br></div><div>I have owned a 177 for over 11 years and have had fridge, inside burners, HW heating up, and furnace all on at the same time and have never had an issue with the single stage regulator.<br></div>]]>
   <pubDate>Mon, 08 Aug 2022 15:24:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149273#149273</guid>
   <title>Rpod single tank regulator : Propane tank regulators for RV&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149271#149271</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 2:12pm<br /><br />Propane tank regulators for RV's and gas grills are pretty fungible. &nbsp;You can buy pretty much any one you want for that general purpose. &nbsp;They are not trailer model or brand specific. &nbsp;Your local RV parts shop or on line sellers have lots of them that will work fine.]]>
   <pubDate>Mon, 08 Aug 2022 14:12:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149271#149271</guid>
   <title>Rpod single tank regulator : Hello All;Another question for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149270#149270</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8539" rel="nofollow">Barryb125</a><br /><strong>Subject:</strong> 15423<br /><strong>Posted:</strong> 08 Aug 2022 at 12:55pm<br /><br />Hello All;<div><br></div><div>Another question for the group. I don't have my 2017 Rpod 178 manual but I need a new propane tank regulator. Can anyone advise me the model number or other specifics so I can order a replacment?&nbsp; Thanks Barry</div>]]>
   <pubDate>Mon, 08 Aug 2022 12:55:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15423&amp;PID=149270#149270</guid>
