  <title>R-pod Owners Forum : pod 178 entry door issue</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : pod 178 entry door issue</description>
  <pubDate>Mon, 26 Oct 2026 05:30:59 +0000</pubDate>
  <lastBuildDate>Sun, 31 Jul 2022 21:43:07 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15407</WebWizForums:feedURL>
   <title>pod 178 entry door issue : If the screws are tight, then...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149170#149170</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 9:43pm<br /><br />If the screws are tight, then as stated in the post above, the hinges might be bent enough to cause the binding. The friction hinges can get stiff enough that the metal will bend.&nbsp;]]>
   <pubDate>Sun, 31 Jul 2022 21:43:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149170#149170</guid>
   <title>pod 178 entry door issue :  With our Vista Cruiser the previous...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149169#149169</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 9:20pm<br /><br />With our Vista Cruiser the previous owner damaged frame of door somehow and the door would jam when trying to close. I used a sledge hammer and a block of wood and hit the hinges to straighten them and the frame of the door opposite the hinge side. The door now is a perfect fit opens and closes with no problem and is air and water tight. Not sure of the problem you are having but this might give you some ideas how to fix it.]]>
   <pubDate>Sun, 31 Jul 2022 21:20:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149169#149169</guid>
   <title>pod 178 entry door issue : Screws were the first thing I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149168#149168</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12409" rel="nofollow">Jackrh</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 7:18pm<br /><br />Screws were the first thing I checked when the issue started. I have had several campers over the years, all fifth wheels, this is the smallest unit we have ever had, so far the most issues also.]]>
   <pubDate>Sun, 31 Jul 2022 19:18:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149168#149168</guid>
   <title>pod 178 entry door issue : It sounds like the screws holding...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149167#149167</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 7:10pm<br /><br />It sounds like the screws holding the hinges to the door are loose. If you can't tighten them, then try removing them, filling the holes then re-drilling and re-installing the screws. It would be a lot less expensive than buying a new door. If you can find some Tri-Flow or other lubricant containing Teflon, that may help. with lubricating the hinges. Neither silicone nor WD-40 do that much good.]]>
   <pubDate>Sun, 31 Jul 2022 19:10:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149167#149167</guid>
   <title>pod 178 entry door issue : If you can find an RV Parts and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149166#149166</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 7:04pm<br /><br />If you can find an RV Parts and Accessory catalogue you will probably find what you are looking for.&nbsp; There are 5 different ones to pick from ranging in price from $ 450 - $600.<br>]]>
   <pubDate>Sun, 31 Jul 2022 19:04:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149166#149166</guid>
   <title>pod 178 entry door issue :  Anyone know where I can buy...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149164#149164</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=12409" rel="nofollow">Jackrh</a><br /><strong>Subject:</strong> 15407<br /><strong>Posted:</strong> 31 Jul 2022 at 5:05pm<br /><br />Anyone know where I can buy a replacement door, somehow, mine is moving side to side within the frame. When closing the door, you can watch the door pull away from the frame. This has caused an adjustment issue. Had to remove the striker plate, just to open and close the door. I have lubricated the hinges several times, It does not help. I just don't know any other way to remedy the issue.]]>
   <pubDate>Sun, 31 Jul 2022 17:05:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15407&amp;PID=149164#149164</guid>
