  <title>R-pod Owners Forum : Leaking propane hose to the regulator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Leaking propane hose to the regulator</description>
  <pubDate>Tue, 27 Oct 2026 05:47:23 +0000</pubDate>
  <lastBuildDate>Fri, 29 Jul 2022 10:45:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15401</WebWizForums:feedURL>
   <title>Leaking propane hose to the regulator :  Yep, the yellow teflon tape...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149140#149140</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 29 Jul 2022 at 10:45am<br /><br />Yep, the yellow teflon tape is one of the gas compatible pipe thread sealants. &nbsp;That's what I used when I replaced the pigtail. &nbsp;Be sure not to use the white tape unless the package data specifically states it is gas compatible. &nbsp;The problem is non-gas compatible sealants, tape or paste, can deteriorate with gas exposure and lead to a leak.]]>
   <pubDate>Fri, 29 Jul 2022 10:45:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149140#149140</guid>
   <title>Leaking propane hose to the regulator : The pipe sealant can also be YELLOW...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149138#149138</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 29 Jul 2022 at 10:02am<br /><br /><div>The pipe sealant can also be YELLOW teflon tape-available at most hardware and big box home stores.</div><div>Travel safe and often</div><div>Vann<br></div>]]>
   <pubDate>Fri, 29 Jul 2022 10:02:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149138#149138</guid>
   <title>Leaking propane hose to the regulator : Oh, and be sure to use gas compatible...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149136#149136</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 29 Jul 2022 at 5:51am<br /><br />Oh, and be sure to use gas compatible pipe thread sealant. &nbsp;]]>
   <pubDate>Fri, 29 Jul 2022 05:51:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149136#149136</guid>
   <title>Leaking propane hose to the regulator : +1 lost again the hose was leaking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149134#149134</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4724" rel="nofollow">Winterpod</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 28 Jul 2022 at 8:28pm<br /><br />+1 lost again the hose was leaking where it was crimped at the fitting<div>Simple to replace</div>]]>
   <pubDate>Thu, 28 Jul 2022 20:28:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149134#149134</guid>
   <title>Leaking propane hose to the regulator : We had the same thing happen and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149133#149133</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6036" rel="nofollow">lostagain</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 28 Jul 2022 at 7:27pm<br /><br />We had the same thing happen and it turned out to be a bad pigtail from the tank to the regulator. &nbsp;Just replaced the hose, the one that fastens onto the tank. &nbsp;It's a part that's easy to find and not expensive. &nbsp;just be sure to get one long enough to have slack in it so it doesn't pull on the fittings.]]>
   <pubDate>Thu, 28 Jul 2022 19:27:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149133#149133</guid>
   <title>Leaking propane hose to the regulator : Grab a couple wrenches of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149132#149132</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 28 Jul 2022 at 7:20pm<br /><br />Grab a couple wrenches of the correct size and see if you can tighten the connection where the leak is occuring.&nbsp; Maybe the connection came loose.&nbsp; Make up a soapy solution and place the bubbles over where you think the leak is coming from to verify the location of the leak.&nbsp; If you cannot find the leak it is possible the valve from the tank itself is leaking and will have to be replaced by a qualified person.<br>]]>
   <pubDate>Thu, 28 Jul 2022 19:20:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149132#149132</guid>
   <title>Leaking propane hose to the regulator : Hello AllJust came back from a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149130#149130</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8539" rel="nofollow">Barryb125</a><br /><strong>Subject:</strong> 15401<br /><strong>Posted:</strong> 28 Jul 2022 at 6:02pm<br /><br />Hello All<div>Just came back from a camping trip and we smelled propane from the Rpod propane tank hose leading to the regulator. Is that something a novice can fix or time to find a shop to repair it?</div><div>Thanks</div><div>Barry</div>]]>
   <pubDate>Thu, 28 Jul 2022 18:02:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15401&amp;PID=149130#149130</guid>
