  <title>R-pod Owners Forum : Replacement Fender?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Replacement Fender?</description>
  <pubDate>Mon, 26 Oct 2026 06:24:13 +0000</pubDate>
  <lastBuildDate>Sun, 22 May 2022 17:19:54 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15279</WebWizForums:feedURL>
   <title>Replacement Fender? : Thanks. I&amp;#039;ll look that one...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148208#148208</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 22 May 2022 at 5:19pm<br /><br />Thanks. I'll look that one up.<div><br></div>]]>
   <pubDate>Sun, 22 May 2022 17:19:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148208#148208</guid>
   <title>Replacement Fender? :  There is something that I&amp;#039;ve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148206#148206</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 22 May 2022 at 12:42pm<br /><br />There is something that I've been looking to coat the running boards on our F150. It's 7 years old, and the clear coat on the running boards is flaking off from sun exposure. I'm also on an F150 board, and what some have started doing is coating them with a DIY bed liner material called Herculiner. That might work well for your fenders.<div><br></div><div>EDIT: I called the local Line-X franchise to see what they wanted to do my running boards, and the guy on the phone quoted me $675. I guess he didn't want to do it.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley19.gif" border="0" alt="Cry" title="Cry" /></div>]]>
   <pubDate>Sun, 22 May 2022 12:42:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148206#148206</guid>
   <title>Replacement Fender? : Truck bed coatings are much more...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148205#148205</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 22 May 2022 at 11:25am<br /><br />Truck bed coatings are much more robust than Plasti-Dip. They are meant to be permanent and to stand up to things being tossed in the bed. I think it would work.&nbsp;]]>
   <pubDate>Sun, 22 May 2022 11:25:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148205#148205</guid>
   <title>Replacement Fender? :   Originally posted by StephenHPerhaps...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148203#148203</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8159" rel="nofollow">poston</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 22 May 2022 at 10:22am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />Perhaps I could find a place to powder-coat them. I think that is what was on the original fenders. I was thinking also of using truck bed coating on the insides since that would be more impact-resistant.</td></tr></table><div><br></div><div>Powder coating would be pretty robust.&nbsp; I'm not sure the truck bed coating would stand up to the abuse.&nbsp; But let us know if you go that route!</div><div><br></div>]]>
   <pubDate>Sun, 22 May 2022 10:22:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148203#148203</guid>
   <title>Replacement Fender? : Perhaps I could find a place to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148200#148200</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 22 May 2022 at 9:23am<br /><br />Perhaps I could find a place to powder-coat them. I think that is what was on the original fenders. I was thinking also of using truck bed coating on the insides since that would be more impact-resistant.<div><br></div><div>I did find one more item that was damaged. The cover for the black water tank flush port was ripped off also. I'll need to find a replacement cover. I may need to replace the whole port. There are some scrapes on the side from the screws when they pulled out. It looks like the tread hit it and it started separating on the back side and then peeled off toward the front. The fenders sure are not sturdy enough to take the impact of the tread.&nbsp;</div><div><br></div><div>The worst thing was that these were Carlisle load range D tires. There was wear and I was going to check them when I got here to our daughter's house. We did not quite make it. We now have new Goodyear Endurance load range D tires. Hopefully, they will be good for a few years.</div>]]>
   <pubDate>Sun, 22 May 2022 09:23:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148200#148200</guid>
   <title>Replacement Fender? :   Originally posted by StephenHThanks....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148195#148195</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8159" rel="nofollow">poston</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 11:37pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />Thanks. From the looks, they are unpainted. Are they aluminum? Did you paint them?&nbsp;</td></tr></table><div><br></div><div>They are aluminum.&nbsp; We were headed out on a trip, so I Plastidipped them with a few coats after scuffing them up.</div><div><br></div><div>No good.&nbsp; The Plastidip adhered to the aluminum, but rocks chipped the heck out of them.&nbsp; I'd said they're 50% Plastidip and 50% bare aluminum now.&nbsp; It's ugly (or rugged, depending on your perspective), but I haven't been motivated to actually paint them.</div>]]>
   <pubDate>Sat, 21 May 2022 23:37:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148195#148195</guid>
   <title>Replacement Fender? : Thanks. From the looks, they are...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148194#148194</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 11:03pm<br /><br />Thanks. From the looks, they are unpainted. Are they aluminum? Did you paint them?&nbsp;]]>
   <pubDate>Sat, 21 May 2022 23:03:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148194#148194</guid>
   <title>Replacement Fender? :   Originally posted by StephenHTI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148193#148193</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8159" rel="nofollow">poston</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 10:09pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />TI almost want to use one of the diamond plate ones that is squared off to have a flat top to use. I'll be weighing options as we travel and likely, not do anything about it until we get home.<div></td></tr></table></div><div><br></div><div>That's what we did.&nbsp; We drove home with "one shoe off, one shoe on" and ordered a pair of the flat-top fenders.&nbsp; We were able to salvage the marker lights off the mangled fender.&nbsp; Required some splicing of wires that were ripped off in the blast.</div><div><br></div><div><img src="https://i.ebayimg.com/images/g/vsEAAOSwwTtfBzR7/s-l1600.jpg" height="278" width="546" border="0" /><br></div>]]>
   <pubDate>Sat, 21 May 2022 22:09:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148193#148193</guid>
   <title>Replacement Fender? : The newer models have a single...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148192#148192</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 7:58pm<br /><br />The newer models have a single unit that sits on top of the fender with amber in front and red in back. Ours has two separate lights, amber and red a few inches above the bottom of the fender. I have no idea where those went. I did not see them on the fender when I found it. As for the fender, it was flattened and tossed into the weeds by a passing vehicle, so there would not have been the opportunity to take measurements. I could take measurements from the other side.<div><br></div><div>I almost want to use one of the diamond plate ones that is squared off to have a flat top to use. I'll be weighing options as we travel and likely, not do anything about it until we get home.</div><div><br></div>]]>
   <pubDate>Sat, 21 May 2022 19:58:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148192#148192</guid>
   <title>Replacement Fender? :   I forget do the newer r-pods...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148190#148190</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 3:21pm<br /><br />&nbsp; I forget do the newer r-pods with fenders have marker lights on their fenders?]]>
   <pubDate>Sat, 21 May 2022 15:21:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148190#148190</guid>
   <title>Replacement Fender? : Had the same problem in 2019....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148189#148189</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5219" rel="nofollow">jimandclare</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 3:14pm<br /><br />Had the same problem in 2019.&nbsp; I worked through the dealer for the new fender.&nbsp; FR requested a photo of the existing fender along with the length, height and depth to match the replacement.&nbsp; There is plywood underneath the fiberglass at that location so I filled the holes with silicon caulk.&nbsp; The new fender covered the holes and it seems fine.&nbsp; One thing to note is that the fender doesn't come with marker lights so that's another item that may need to be purchased also.<div><br></div><div><a href="https://www.amaz&#111;n.com/gp/product/B017WN1JE8/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&amp;psc=1" target="_blank">Trailer Fender Marker Lights</a></div>]]>
   <pubDate>Sat, 21 May 2022 15:14:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148189#148189</guid>
   <title>Replacement Fender? : When it happened to me I had to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148188#148188</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1653" rel="nofollow">Tars Tarkas</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 1:48pm<br /><br /><div>When it happened to me I had to order the fender from the factory and the factory had to ship it to an R-Pod dealer.&nbsp; I don't know, maybe they could have done Camping World.&nbsp; I guess the point is, you probably aren't going to find one locally.</div><div><br></div><div>I don't remember: are the right and left fenders the same?<br></div><div><br></div><div>TT<br></div>]]>
   <pubDate>Sat, 21 May 2022 13:48:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148188#148188</guid>
   <title>Replacement Fender? : Thanks. I was thinking of Bondo...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148187#148187</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 10:11am<br /><br />Thanks. I was thinking of Bondo auto body filler. I like the idea of some fiber.]]>
   <pubDate>Sat, 21 May 2022 10:11:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148187#148187</guid>
   <title>Replacement Fender? :   Originally posted by StephenHAlso,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148186#148186</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 10:06am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />Also, what is the best way to patch/fill the old screw holes? I'm pretty sure a new fender's holes would likely not line up with the existing holes.<br></td></tr></table><div><br></div><div>I would make an epoxy/wood fiber filler that you can pack into the hole. Find an epoxy that is fairly liquid, and mix it with a small batch of wood fiber (AKA saw dust) until it is about the consistency of peanut butter. You just don't want it to run. Then poke it into the holes with anything small that can get into the hole. Once you have it full, tape over it with masking tape or duct tape or whatever tape you have laying around. nce it's cured, you can remove the tape and drill it to accept screws.</div>]]>
   <pubDate>Sat, 21 May 2022 10:06:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148186#148186</guid>
   <title>Replacement Fender? :  I have joined the ranks of those...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148185#148185</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 15279<br /><strong>Posted:</strong> 21 May 2022 at 9:19am<br /><br />I have joined the ranks of those who had a tire blow out on the highway with the accompanying loss of a fender. I found the fender, but it was not reusable as it had landed on the road and someone hit it, sending it off into the weeds. It was mangled beyond use, so it went into the back of the highway safety truck that also picked up the tread that had separated.<div><br></div><div>We are at my daughter's house in South Jordan, Utah for about a week, then we will go to our daughter's house in the Phoenix area for a few days. I checked with Camping World, and was told a fender could be ordered from the factory. We all know what that would mean. I have one back home, but that is in North Carolina. It is one that was not quite right which is why it is at home.</div><div><br></div><div>Does anyone know of a place in the Salt Lake City area or the Phoenix area where I might be able to find a fender? I would like to have one in place before we leave to head back home.</div><div><br></div><div>Edit:&nbsp; Also, what is the best way to patch/fill the old screw holes? I'm pretty sure a new fender's holes would likely not line up with the existing holes.</div>]]>
   <pubDate>Sat, 21 May 2022 09:19:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15279&amp;PID=148185#148185</guid>
