  <title>R-pod Owners Forum : Starlink Mobile?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : General non-pod discussion : Starlink Mobile?</description>
  <pubDate>Sat, 07 Nov 2026 05:05:04 +0000</pubDate>
  <lastBuildDate>Tue, 16 Aug 2022 09:27:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15209</WebWizForums:feedURL>
   <title>Starlink Mobile? : Ok  to clarify , it appears that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149350#149350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15209<br /><strong>Posted:</strong> 16 Aug 2022 at 9:27am<br /><br />Ok  to clarify , it appears that you cannot convert from RV to residential Starlink coverage, even if you are eligible for residential at your location. Also, you cannot convert back to residential from RV once you make the switch. That is being done to protect the residential wait list queue. <br /><br />So if you are in a congested urban area with other internet choices  it's probably better to use one of those at home and just get the mobile Starlink package for travel. You can just turn it off when not travelling. <br /><br />If like me you live in a rural area with no good alternatives to fixed Starlink then if you want Starlink for RV use too you'll need to buy two subscriptions and two sets of hardware ($1200) and $245 per month at this time. Not doing that. ]]>
   <pubDate>Tue, 16 Aug 2022 09:27:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149350#149350</guid>
   <title>Starlink Mobile? : Whether you go fixed plan with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149344#149344</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 15209<br /><strong>Posted:</strong> 15 Aug 2022 at 3:02pm<br /><br />Whether you go fixed plan with roaming or RV plan depends on how soon your fixed area will have coverage. Here in the DFW area, we'll be without coverage until sometime in 2023 according to the Starlink website. If I wanted to travel to a Starlink-serviced area, I'd have to get the RV plan until then.]]>
   <pubDate>Mon, 15 Aug 2022 15:02:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149344#149344</guid>
   <title>Starlink Mobile? : Thanks for the feedback.    Looks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149329#149329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15209<br /><strong>Posted:</strong> 14 Aug 2022 at 10:42am<br /><br />Thanks for the feedback.  <br /><br />Looks like Starlink only charges $25 more a month for the RV package vs fixed location. And you can turn it on and off. But apparently having no fixed service address deprioritizes it in congested areas relative to the fixed package. <br /><br />Might be better to buy the &#091;edit: fixed&#093; plan and add on the &#091;edit: portability&#093; package (cost is the same) if you are going to use it continuously at home too like I do. (sorry I had this reversed initially). I wonder if I could get a second dishy, no way I'm going to climb up and take down my antenna for travelling. <br />]]>
   <pubDate>Sun, 14 Aug 2022 10:42:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149329#149329</guid>
   <title>Starlink Mobile? : I bought the RV package and have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149327#149327</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10877" rel="nofollow">richardb09</a><br /><strong>Subject:</strong> 15209<br /><strong>Posted:</strong> 13 Aug 2022 at 12:18pm<br /><br />I bought the RV package and have used it in a couple locations within a 50 mile radius with no issues.]]>
   <pubDate>Sat, 13 Aug 2022 12:18:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=149327#149327</guid>
   <title>Starlink Mobile? : I finally got my Starlink ground...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=147642#147642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 15209<br /><strong>Posted:</strong> 07 Apr 2022 at 5:32am<br /><br />I finally got my Starlink ground station  a couple weeks ago after a year on the wait-list.  Using it at a fixed location currently but interested if anyone here is using one at more than one location. <br /><br />My current firmware has roaming set to false but the version I had initially had roaming turned on, so it appears to come and go.<br /><br />I'm getting around 150-200 mbps down, 8 up,  with 40-70 msec latency. Downtime negligible so far.  Not bad at all for the middle of nowhere. For those unaware the service plan has no data caps and is $110 per month now. ]]>
   <pubDate>Thu, 07 Apr 2022 05:32:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15209&amp;PID=147642#147642</guid>
