  <title>R-pod Owners Forum : Thermostat upgrade to a programable one possible?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Thermostat upgrade to a programable one possible?</description>
  <pubDate>Mon, 26 Oct 2026 07:18:49 +0000</pubDate>
  <lastBuildDate>Tue, 30 Nov 2021 17:21:11 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15038</WebWizForums:feedURL>
   <title>Thermostat upgrade to a programable one possible? : EasyTouch RV Thermostat 351 is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146264#146264</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11545" rel="nofollow">DaveB1701</a><br /><strong>Subject:</strong> 15038<br /><strong>Posted:</strong> 30 Nov 2021 at 5:21pm<br /><br />EasyTouch RV Thermostat 351 is on order for my '21 171 Pod - the Dometic CT, despite my knowledge of it being 'soft touch', became 'hard press' after only three excursions...junk...]]>
   <pubDate>Tue, 30 Nov 2021 17:21:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146264#146264</guid>
   <title>Thermostat upgrade to a programable one possible? : Thanks for the good info gentlemen....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146020#146020</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11910" rel="nofollow">Elie</a><br /><strong>Subject:</strong> 15038<br /><strong>Posted:</strong> 09 Nov 2021 at 6:39pm<br /><br />Thanks for the good info gentlemen.&nbsp; In the meantime I made a call to Dometic and the tech person on the line told me that there is *absolutely* to way to replace their thermostat with a programable one!&nbsp; You'd think they'll know...<div>I'll check into the model you mentioned and will probable justify its price as a life-or-death appliance :j</div>]]>
   <pubDate>Tue, 09 Nov 2021 18:39:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146020#146020</guid>
   <title>Thermostat upgrade to a programable one possible? : The Micro-Air EasyTouch thermostat...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146014#146014</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 15038<br /><strong>Posted:</strong> 09 Nov 2021 at 3:56pm<br /><br />The Micro-Air EasyTouch thermostat to which Skip refers is a nice alternative to a remote temperature monitor for pets if you pair it with a cellular hotspot or just use campground wifi. I have one as well that I just installed.<div fgid="404394"><br fgid="404400"></div><div fgid="404358"><a href="https://www.microair.net/products/easytouch-rv-thermostat" target="_blank">https://www.microair.net/products/easytouch-rv-thermostat</a></div><div fgid="404443"><br fgid="404449"></div><div fgid="404407">You'll need to pick the one that works with your air conditioner; I have the 352 for the Coleman-Mach AC in my 196.</div>]]>
   <pubDate>Tue, 09 Nov 2021 15:56:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146014#146014</guid>
   <title>Thermostat upgrade to a programable one possible? : Micro air for big bucks has one...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146005#146005</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10453" rel="nofollow">Skip</a><br /><strong>Subject:</strong> 15038<br /><strong>Posted:</strong> 09 Nov 2021 at 12:26pm<br /><br />Micro air for big bucks has one that has an app you can control via Bluetooth or internet, love mine but it is expensive. I wanted to be able to adjust from my bed either air or heat as needed.<div>Easy install but pricey.</div>]]>
   <pubDate>Tue, 09 Nov 2021 12:26:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146005#146005</guid>
   <title>Thermostat upgrade to a programable one possible? : Hi there,I have the rpod 178 2020...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146004#146004</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11910" rel="nofollow">Elie</a><br /><strong>Subject:</strong> 15038<br /><strong>Posted:</strong> 09 Nov 2021 at 11:30am<br /><br />Hi there,<div><br></div><div>I have the rpod 178 2020 and the basic thermostat in it leaves room for improvement such as replacement with a programable one.&nbsp;&nbsp;</div><div><br></div><div>Does anyone have information on this?&nbsp; is it doable?&nbsp;</div><div><br></div><div>Thanks!</div><div><br></div><div>- Elie</div>]]>
   <pubDate>Tue, 09 Nov 2021 11:30:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15038&amp;PID=146004#146004</guid>
