  <title>R-pod Owners Forum : Winterization My RPOD 177</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Winterization My RPOD 177</description>
  <pubDate>Mon, 26 Oct 2026 07:15:29 +0000</pubDate>
  <lastBuildDate>Sat, 23 Oct 2021 21:19:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=15000</WebWizForums:feedURL>
   <title>Winterization My RPOD 177 : make sure the low point drains...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145767#145767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 9:19pm<br /><br /><div>make sure the low point drains are emptied</div><div>Vann<br></div>]]>
   <pubDate>Sat, 23 Oct 2021 21:19:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145767#145767</guid>
   <title>Winterization My RPOD 177 : I used the pigtail under the sink....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145765#145765</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11576" rel="nofollow">Wengerda</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 4:51pm<br /><br />I used the pigtail under the sink.]]>
   <pubDate>Sat, 23 Oct 2021 16:51:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145765#145765</guid>
   <title>Winterization My RPOD 177 : Did you use compressed air or...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145764#145764</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 4:41pm<br /><br />Did you use compressed air or use the pigtail under the sink to suck up the antifreeze to send throughout both water lines?<br>]]>
   <pubDate>Sat, 23 Oct 2021 16:41:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145764#145764</guid>
   <title>Winterization My RPOD 177 : Great. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145763#145763</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11576" rel="nofollow">Wengerda</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 3:52pm<br /><br />Great.]]>
   <pubDate>Sat, 23 Oct 2021 15:52:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145763#145763</guid>
   <title>Winterization My RPOD 177 : +1Main thing is to empty the water...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145762#145762</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 3:21pm<br /><br />+1<div><br></div><div>Main thing is to empty the water lines &amp; have a little pink stuff in the traps. Also the WH should be drained. All of the under-carriage tanks can just be drained; they don't need to be 100% empty.</div>]]>
   <pubDate>Sat, 23 Oct 2021 15:21:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145762#145762</guid>
   <title>Winterization My RPOD 177 : Thanks. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145761#145761</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11576" rel="nofollow">Wengerda</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 1:51pm<br /><br />Thanks.]]>
   <pubDate>Sat, 23 Oct 2021 13:51:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145761#145761</guid>
   <title>Winterization My RPOD 177 : Black and gray tanks can have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145760#145760</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 1:38pm<br /><br />Black and gray tanks can have several gallons in them. Dont sweat it<div><br></div>]]>
   <pubDate>Sat, 23 Oct 2021 13:38:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145760#145760</guid>
   <title>Winterization My RPOD 177 : Question, newbie here.  I winterize...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145757#145757</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11576" rel="nofollow">Wengerda</a><br /><strong>Subject:</strong> 15000<br /><strong>Posted:</strong> 23 Oct 2021 at 10:54am<br /><br />Question, newbie here.  I winterize my R-POD using the hose under the sink and the water pump.  I by passed the water heater too.  After I was done, I forgot to ensure that my black and gray tank was completely empty. I empty both tanks after I winterize the camper. Now do I need re-winterize the POD after opening both tanks.  I did add more pink stuff in the traps after I empty the tanks.  TIA ]]>
   <pubDate>Sat, 23 Oct 2021 10:54:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=15000&amp;PID=145757#145757</guid>
