  <title>R-pod Owners Forum : Furnace Yellow Flame</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Furnace Yellow Flame</description>
  <pubDate>Mon, 26 Oct 2026 04:37:54 +0000</pubDate>
  <lastBuildDate>Fri, 10 Sep 2021 13:08:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14918</WebWizForums:feedURL>
   <title>Furnace Yellow Flame :   Originally posted by jato  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145049#145049</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 10 Sep 2021 at 1:08pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by jato</strong></em><br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by GlueGuy</strong></em><br /><br />A yellow flame indicates not enough oxygen, or too much fuel. I would check air inlets and/or see if there is a way to turn down the fuel.</td></tr></table> <br></div><div><br></div><div>Is it possible GG that there may still be gunk or a pinched line somewhere that would cause this?&nbsp; I had the same issue when I found out my regulator and propane line had the black gooey substance, once replaced the flame was nearly totally blue.</div><div><br></div><div>I agree, yellow indicates lack of oxygen and since the OP still has this issue, especially seeing that he has this problem with the HW flame which is in the open tells me that another line is pinched or there is yet another line that needs to be cleaned out or replaced.<br></div></td></tr></table><div>I suppose that is possible, but the gunk would theoretically be restricting fuel flow and/or contaminating the fuel on its way to the burner. I don't know how long that might last. If you can't find some blockage in the air supply, it would probably be worth a try to blow the line out with compressed air.</div>]]>
   <pubDate>Fri, 10 Sep 2021 13:08:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145049#145049</guid>
   <title>Furnace Yellow Flame : If yellow flame is indicative...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145039#145039</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 09 Sep 2021 at 6:06pm<br /><br /><div>If yellow flame is indicative&nbsp; of low oxygen, then check the outside air intake for mud daubbers or other insect&nbsp; nests. In our area, they are quite invasive and all of our vents have to be covered with insect screening. they can definitely stop up pipes, inlets, openings, etc.<br></div><div>Vann<br></div>]]>
   <pubDate>Thu, 09 Sep 2021 18:06:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145039#145039</guid>
   <title>Furnace Yellow Flame :   Originally posted by GlueGuyA...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145038#145038</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 09 Sep 2021 at 5:34pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by GlueGuy</strong></em><br /><br />A yellow flame indicates not enough oxygen, or too much fuel. I would check air inlets and/or see if there is a way to turn down the fuel.</td></tr></table> <br></div><div><br></div><div>Is it possible GG that there may still be gunk or a pinched line somewhere that would cause this?&nbsp; I had the same issue when I found out my regulator and propane line had the black gooey substance, once replaced the flame was nearly totally blue.</div><div><br></div><div>I agree, yellow indicates lack of oxygen and since the OP still has this issue, especially seeing that he has this problem with the HW flame which is in the open tells me that another line is pinched or there is yet another line that needs to be cleaned out or replaced.<br></div>]]>
   <pubDate>Thu, 09 Sep 2021 17:34:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145038#145038</guid>
   <title>Furnace Yellow Flame : A yellow flame indicates not enough...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145033#145033</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 09 Sep 2021 at 11:05am<br /><br />A yellow flame indicates not enough oxygen, or too much fuel. I would check air inlets and/or see if there is a way to turn down the fuel.]]>
   <pubDate>Thu, 09 Sep 2021 11:05:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145033#145033</guid>
   <title>Furnace Yellow Flame : So I replaced the regulator and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145026#145026</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11567" rel="nofollow">ERS1977</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 08 Sep 2021 at 8:04pm<br /><br />So I replaced the regulator and it definitely helped but there was still an obvious yellow flame so I swapped the propane tank with the one from my BBQ that I purchased new from Costco a couple months ago but that made no difference at all.<div><br></div><div>Here's a pic of the flame from the same basic angle for comparison purposes:</div><div><br><div><img src="uploads/11567/Flame500-after1.jpg" height="375" width="500" border="0" /><br></div><div><br><div><br></div><div>There is still a very visible yellow flame (to the naked eye) but it appears to be from the electrode that provides the spark. So I then took a look at the water heater and it has the same characteristic orange/yellow flame trailing from the electrode:</div><div><br></div><div><img src="uploads/11567/WaterHeater.jpg" height="375" width="500" border="0" /><br></div><div><br></div><div><br></div><div>So maybe what I'm left with is normal...</div><div><br></div><div>I think I'll call it good but will be interested in seeing another furnace with my own eyes...and have an expert confirm it the next time I need some service.</div></div><div><br></div><div><br></div><div>Many thanks for your help, jato. MUCH APPRECIATED!</div><div>Mike</div><div><br></div></div>]]>
   <pubDate>Wed, 08 Sep 2021 20:04:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145026#145026</guid>
   <title>Furnace Yellow Flame :  Right. I don&amp;#039;t know of...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145016#145016</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 08 Sep 2021 at 2:02pm<br /><br /><div>Right.&nbsp; I don't know of a way to properly clean out a regulator once that gunk is inside without doing more harm than good.&nbsp; Anyway, I got a two-stage regulator off EBay with free shipping for around $ 18&nbsp; two years ago.&nbsp; <br></div><div><br></div><div>I was told by those 'in the know' that I should turn off my gas and open the line when not using for a month or more so this doesn't occur.&nbsp; Seeing that this was never done in the first 9 years of ownership I guess it held up pretty well.<br></div>]]>
   <pubDate>Wed, 08 Sep 2021 14:02:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145016#145016</guid>
   <title>Furnace Yellow Flame : Thanks jato,So I went and unscrewed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145013#145013</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11567" rel="nofollow">ERS1977</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 08 Sep 2021 at 1:08pm<br /><br />Thanks jato,<div><br></div><div>So I went and unscrewed the hose from the output side of my regulator and a yellowish liquid spurted out...probably an ounce or so (although liquid looks like its twice the volume when it spills to ground LOL)</div><div><br></div><div>I then removed the hose from the input side of the reg. The hose ends themselves look fine. So I think I'll look for a supplier for the regulator first.</div><div><br></div><div>So it's safe to assume the *no* liquid should ever spurt out of a regulator?....</div><div><br></div><div><br></div>]]>
   <pubDate>Wed, 08 Sep 2021 13:08:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145013#145013</guid>
   <title>Furnace Yellow Flame : You have done everything right...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145004#145004</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 08 Sep 2021 at 11:28am<br /><br /><div>You have done everything right as far as I know yet when I look at my flame there is a tint of yellow but the flame is mainly blue.&nbsp; <br></div><div><br></div><div>The only additional item I can add with my limited knowledge is to check both your regulator and the hose that goes from the regulator and screws into the propane line in the front of your 177.&nbsp; I have a 2011 177 so we have the same setup.&nbsp; What I found out (I had a problem with yellow flame on my fridge and HW heater) was a lack of oxygen.&nbsp; When I took the regulator off a thick black gooey substance came out, the hose leaving the regulator had the same thing come out of it.&nbsp; At the time my 177 was 9 years old.&nbsp; For a total of $25 I purchased a new regulator and got a hose made at a local propane business that sells bulk propane to homeowners.&nbsp; Took care of the yellow flame problem for me.<br></div>]]>
   <pubDate>Wed, 08 Sep 2021 11:28:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145004#145004</guid>
   <title>Furnace Yellow Flame : Hello All,I have a Suburban NT-20SEQ...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145001#145001</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11567" rel="nofollow">ERS1977</a><br /><strong>Subject:</strong> 14918<br /><strong>Posted:</strong> 08 Sep 2021 at 10:32am<br /><br />Hello All,<div><br></div><div>I have a Suburban NT-20SEQ furnace in my 2012 Pod 177 and except for the approx 2-3" high yellow flame, runs well (I've just bought the pod). I only have limited experience with a furnace (in a previous pup but don't thing the flame was like this.</div><div><br></div><div>What I've done:</div><div><ol><li>Inspected the intake and output ports for debris (none found)</li><li>Inspected both ports as well and the main chamber for soot (none found)</li><li>Blew air into both ports using my small compressor.</li><li>Removed the flame element and though no holes were plugged, I cleaned it with a toothbrush and CLR and blew air into the chamber.</li><li>Re-inserted the element and no change to the yellow flame.</li><li>Verified that both lines of blue flames are well defined and about 1/2 inch or so.</li></ol></div><div><br></div><div>Would you be so kind as to review the 3 attached photos and pass along suggestions or just confirm the pics look normal? Maybe what I have is normal for this furnace???</div><div><br></div><div>Pics:</div><div><img src="uploads/11567/Flame500.jpg" height="375" width="500" border="0" /><br></div><div><br></div><div><img src="uploads/11567/Element500.jpg" height="1187" width="500" border="0" /><br></div><div><br></div><div><img src="uploads/11567/Chamber500.jpg" height="667" width="500" border="0" /><br></div>]]>
   <pubDate>Wed, 08 Sep 2021 10:32:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14918&amp;PID=145001#145001</guid>
