  <title>R-pod Owners Forum : lower propane hose</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : lower propane hose</description>
  <pubDate>Mon, 26 Oct 2026 05:30:45 +0000</pubDate>
  <lastBuildDate>Fri, 03 Sep 2021 20:05:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14912</WebWizForums:feedURL>
   <title>lower propane hose : When I got my hose I went to a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144947#144947</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 8:05pm<br /><br />When I got my hose I went to a local propane dealer who sells bulk propane to homeowners.&nbsp; They can make any length hose and fittings you desire.<br>]]>
   <pubDate>Fri, 03 Sep 2021 20:05:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144947#144947</guid>
   <title>lower propane hose : No problem, just glad we got it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144945#144945</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 5:59pm<br /><br />No problem, just glad we got it figured out correctly.<div>I ordered the correct one from a..zon because etrailer is back ordered until March,2022! I don’t like the one I ordered because it is not heavy duty.</div><div>I will continue to look for one, but the availability seems limited so far.</div><div>At least now I know I am looking for a 3’ hose with 3/8” male npt and 1/2” female flair fitting.</div><div>Thanks for the info</div><div>Travel safe</div><div>Vann</div>]]>
   <pubDate>Fri, 03 Sep 2021 17:59:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144945#144945</guid>
   <title>lower propane hose : I owe you an apology. Just went...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144942#144942</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 5:40pm<br /><br />I owe you an apology.&nbsp; Just went out and removed the line which I thought was SAE, it is not, both ends are NPT.&nbsp; Out in the barn where my 177 is currently sitting I had a couple hoses laying on top of my propane tank and I thought one of them (being a 1/2" line) was an extra for the pod; it wasn't.&nbsp; Actually they both belong to my log splitter.&nbsp; So brain fart on my end, please accept my apology.<br>]]>
   <pubDate>Fri, 03 Sep 2021 17:40:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144942#144942</guid>
   <title>lower propane hose : I looked at my fittings-neither...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144941#144941</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 4:44pm<br /><br /><div>I looked at my fittings-neither the hose end nor the pod end had O rings-both had teflon tape. so, I think mine (2015 179) must be the swivel fitting and NOT SAE since there was no o ring on either piece.</div><div><br></div><div>So, does yours definitely have an O ring? if so, is it on the end of the 1/2" hose fitting or on the male end at the pod main line?</div><div>thanks again<br></div><div>Vann<br></div>]]>
   <pubDate>Fri, 03 Sep 2021 16:44:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144941#144941</guid>
   <title>lower propane hose :   Originally posted by Pod PeopleI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144938#144938</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 3:18pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Pod People</strong></em><br /><br /><div>I just found this:</div><div><div ="mt-1"=""><div ="flex="" flex-col"=""><div ="markdownstyles="" undefined"=""><p>"NPT is a standard for threaded pipe and fittings. NPT stands fornational pipe thread. NPT fittings are tapered thread fitting andusually rely on mechanical deformation in between the male andfemale fittings to create a seal in addition with <a href="https://www.answers.com/t/tefl&#111;n" target="_blank">Teflon</a> tape. Overtighteting may result in a leakage</p><p>SAE O-ring fittings are straight fittings and rely on the O-ringto create the seal rather than deformation as in NPT fittings.Since these fittings do not depend on deformation chances of abroken fitting are virtually eliminated."</p><p><br></p><p>so, I guess the easiest way to determine which type of fitting is appropriate is to see if there is an O ring or not. If there is an O ring, it is SAE, if no O ring and teflon(yellow) tape is present, then it is NPT.</p><p>the journey continues..............</p><p>Vann<br></p></div></div></div></div><div></td></tr></table> <br></div><div><br></div><div>Yes, you are spot on.&nbsp; HOWEVER, hopefully FR stayed with a winner with the SAE fitting on your hose.&nbsp; Golf course equipment years ago 1970's - 1980's were almost always NPT with the flared ends, it also resulted in a LOT of hydraulic leaks where you didn't want them, greens, tees, and fairways.&nbsp; Toro started using SAE exclusively on their turf equipment during the mid 1990's - vast improvement.&nbsp; As you stated 'virtually eliminating' broken fittings/leaks.</div><div><br></div><div>Too bad FR didn't do the same here, having SAE fittings on both ends of the hose.&nbsp; But I suppose that would add a couple bucks to the bottom line and Warren Buffet wouldn't like that!<br></div>]]>
   <pubDate>Fri, 03 Sep 2021 15:18:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144938#144938</guid>
   <title>lower propane hose : I just found this:&amp;#034;NPT is...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144937#144937</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 3:08pm<br /><br /><div>I just found this:</div><div><div ="mt-1"><div ="flex flex-col"><div ="markdownStyles undefined"><p>"NPT is a standard for threaded pipe and fittings. NPT stands fornational pipe thread. NPT fittings are tapered thread fitting andusually rely on mechanical deformation in between the male andfemale fittings to create a seal in addition with <a href="https://www.answers.com/t/tefl&#111;n" target="_blank">Teflon</a> tape. Overtighteting may result in a leakage</p><p>SAE O-ring fittings are straight fittings and rely on the O-ringto create the seal rather than deformation as in NPT fittings.Since these fittings do not depend on deformation chances of abroken fitting are virtually eliminated."</p><p><br></p><p>so, I guess the easiest way to determine which type of fitting is appropriate is to see if there is an O ring or not. If there is an O ring, it is SAE, if no O ring and teflon(yellow) tape is present, then it is NPT.</p><p>the journey continues..............</p><p>Vann<br></p></div></div></div></div>]]>
   <pubDate>Fri, 03 Sep 2021 15:08:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144937#144937</guid>
   <title>lower propane hose : Thanks JATOthat is exactly what...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144936#144936</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 3:00pm<br /><br /><div>Thanks JATO</div><div>that is exactly what I am doing-replacing and cleaning both lines. The upper hose is easy-Acme nut x 1/4"npt male. The lower hose is the question.<br></div><div>Our pod is a 2015 179, but I would assume(bad ) that they are the same. I have removed the lines, but wasn't sure about the 1/2" female swivel-it is flared, but is it NPT or SAE .&nbsp; ETrailer shows both, so I was hoping to know for sure prior to ordering-saves a return and lost time.</div><div>I guess that I will have to order one and see what fits. I don't know how much difference there is between the&nbsp; SAE vs NPT thread, but it will become clear when the correct thread fits and has no leaks.</div><div>thaks for your advice</div><div>travel safe</div><div>Vann<br></div>]]>
   <pubDate>Fri, 03 Sep 2021 15:00:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144936#144936</guid>
   <title>lower propane hose :  Hi Vann,I just checked my hose...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144935#144935</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 1:51pm<br /><br /><div>Hi Vann,</div><div><br></div><div>I just checked my hose that is on a January built 2011 177.&nbsp; The regulator output side is 3/8" male NPT and the other end is&nbsp;<u> 1/2" female SAE with a swivel fitting</u>.&nbsp; Have you pulled off your line to verify?</div><div><br></div><div>*****updated !!&nbsp; other end is 1/2" female <b>NPT</b> with swivel fitting.&nbsp; Sorry for the confusion. *****<br></div><div><br></div><div>I just changed this line out 2 years ago as my fridge wouldn't work.&nbsp; Found out both the regulator and this line were full of a black oily gooey substance.&nbsp; Replaced both and was back in business.<br></div>]]>
   <pubDate>Fri, 03 Sep 2021 13:51:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144935#144935</guid>
   <title>lower propane hose : I am trying to replace the lower...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144933#144933</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 10:40am<br /><br /><div>I am trying to replace the lower propane hose from the regulator output to the main propane line under the pod.</div><div>The regulator output end is a 3/8" male NPT thread. the other end appears to be 1/2" female fitting. Etrailer lists&nbsp; similar hoses with a 1/2"&nbsp; female SAE&nbsp; swivel fitting and 1/2"female flare swivel thread.</div><div><br></div><div>does anyone know which thread is correct?</div><div>Thanks</div><div>Vann<br></div>]]>
   <pubDate>Fri, 03 Sep 2021 10:40:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144933#144933</guid>
   <title>lower propane hose :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144932#144932</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14912<br /><strong>Posted:</strong> 03 Sep 2021 at 10:31am<br /><br />]]>
   <pubDate>Fri, 03 Sep 2021 10:31:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14912&amp;PID=144932#144932</guid>
