  <title>R-pod Owners Forum : Wheel Bearing</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Wheel Bearing</description>
  <pubDate>Fri, 23 Oct 2026 07:24:54 +0000</pubDate>
  <lastBuildDate>Tue, 20 Jul 2021 08:59:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14806</WebWizForums:feedURL>
   <title>Wheel Bearing : I believe you asked this in another...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144188#144188</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 20 Jul 2021 at 8:59am<br /><br />I believe you asked this in another topic, which I answered. For my axle reinforcement and pictures, see my mods (link in signature). Be aware that you cannot weld anything to the axle tube. It would immediately void any warranty and probably destroy the rubber inside that provides the torsion. My welding was to the angle and to the brackets I made.]]>
   <pubDate>Tue, 20 Jul 2021 08:59:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144188#144188</guid>
   <title>Wheel Bearing : Would anyone know where I can...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144184#144184</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 20 Jul 2021 at 8:20am<br /><br />Would anyone know where I can get an axel for my rpod 179]]>
   <pubDate>Tue, 20 Jul 2021 08:20:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144184#144184</guid>
   <title>Wheel Bearing : No special tools are needed to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144182#144182</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 20 Jul 2021 at 6:24am<br /><br />No special tools are needed to replace an axle its just bolted to the frame or riser kit. If you buy a bare axle you will need to swap your brake plate assemblies to the new axle, also not difficult.  <br /><br />But first you need to determine whether it's the axle tube that is bent (more common) or the spindle. If it's the spindle then you'll need to replace the axle, you can't remove the spindle/torsion arms from  the axle because theyre embedded in rubber. If it's the axle tube a good trailer shop should be able to bend it back.<br /><br />You can tell it it's the axle because it will lose some or all of its "crown" in the center. Run a stringline along the bottom of the axle tube from end to end, there should be around 3/16 of an inch gap in the center. <br /><br />Of course, you could conceivably have both a bent spindle and a bent axle....<br /><br />The 179 and similar size rpods are prone to bent axle tubes because they are relatively heavy trailers and the axle tubes aren't attached to the trailer frame at the ends,  they attachments are inboard, which puts much greater bending force on them.<br /><br />Whether you get a new axle or bend the existing one back you should reinforce it or youre likely to get the same problem again. To reinforce it get a piece of 2x2 steel angle cut to length so it just clears the torsion arms at each end. Have it bent in the center about 3/16 inch by putting it in a hydraulic press with the angle resting on the legs and the corner up. Then get 4 square ubolts and bolt it to the bottom of the axle and the ends. If you do a search a couple of years back I have some photos and the name of a place to get the ubolts made up.<br /><br /><br /><br /><br /><br />]]>
   <pubDate>Tue, 20 Jul 2021 06:24:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144182#144182</guid>
   <title>Wheel Bearing : I believe your correct...I&amp;#039;m...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144174#144174</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 19 Jul 2021 at 4:25pm<br /><br />I believe your correct...I'm back in RI, left trailer in NJ. <br />Mechanic will take drum off and let me know if it's the axel...this is a family business, 50 years in business 5 star rating...I'm not sure if he can change the axel but can recommend someone..time will tell<br />Do you need special equipment to change an axel?]]>
   <pubDate>Mon, 19 Jul 2021 16:25:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144174#144174</guid>
   <title>Wheel Bearing : You could DIY it. It&amp;#039;s not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144163#144163</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 19 Jul 2021 at 9:06am<br /><br />You could DIY it. It's not really a difficult install, but you can't rush it because the brakes and bearings need to be properly adjusted. After more than one similar frustrating experience with mechanics either doing a poor job or ripping me off I just plan on fixing anything short of a major trans or engine rebuild myself and carry a fairly hefty toolbox to do it with.<br /><br />In your case I think you have more than just a bearing/brake problem.  You are reporting a camber problem too, right? Top of wheel tilted in? Unless the bearings are totally destroyed causing the wheel to be floppy when jacked up you either have a bent spindle or a bent axle. Can you confirm? ]]>
   <pubDate>Mon, 19 Jul 2021 09:06:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144163#144163</guid>
   <title>Wheel Bearing : Possibly, was traveling from Nashville...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144162#144162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 19 Jul 2021 at 8:09am<br /><br />Possibly, was traveling from Nashville broke down in PA on a Sat around noon Was recommended a heavy dutytruck repair company...Got the mechanic on call, what else could I do?!! in this situation]]>
   <pubDate>Mon, 19 Jul 2021 08:09:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144162#144162</guid>
   <title>Wheel Bearing :   Originally posted by Vector1952The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144161#144161</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 19 Jul 2021 at 7:28am<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Vector1952</strong></em><br /><br />The wheel didn't turn freely said would be fine after tire was on</td></tr></table> <br></div><div><br></div><div>Either the bearing was over tightened, the brake assembly was too tight, or a combination of both.&nbsp; Also a lack of adequate grease on the bearing/cup assembly would speed up the process as well.</div><div><br></div><div>Hopefully next time you will have a qualified mechanic who is knowledgeable and will do the job correctly.<br></div>]]>
   <pubDate>Mon, 19 Jul 2021 07:28:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144161#144161</guid>
   <title>Wheel Bearing : The wheel didn&amp;#039;t turn freely...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144157#144157</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 9:05pm<br /><br />The wheel didn't turn freely said would be fine after tire was on]]>
   <pubDate>Sun, 18 Jul 2021 21:05:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144157#144157</guid>
   <title>Wheel Bearing : Unlikely but it is possible the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144156#144156</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 8:37pm<br /><br />Unlikely but it is possible the bearing was set too tight, causing the wheel not to turn freely even though there would be no side to side endplay.&nbsp; Proper bearing tightness is just enough to take the end play out and no more.<br>]]>
   <pubDate>Sun, 18 Jul 2021 20:37:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144156#144156</guid>
   <title>Wheel Bearing : Believe the spindle had mark from...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144152#144152</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 4:16pm<br /><br />Believe the spindle had mark from bearing, he used a small grind wheel on it]]>
   <pubDate>Sun, 18 Jul 2021 16:16:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144152#144152</guid>
   <title>Wheel Bearing : Stuck brakes could overheat the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144150#144150</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 3:47pm<br /><br />Stuck brakes could overheat the whole drum including the bearings. Does the wheel turn freely? <br /><br />Does the wheel have a lot of play when you push and pull on it with that side of the trailer lifted? If yes then you have a bad bearing. <br /><br />If not and you have significant negative camber (top of wheel slanted inward) then most likely you do have a bent axle or spindle. Hit any curbs or big potholes? How much weight do you have on that axle? <br /><br />Not likely though that a bent axle or spindle would destroy a bearing quickly like that. 0Was the spindle badly scored or damaged the first round? p<br /><br />When I bought a couple of Lippert drum kits (brake issues in my case) the outer bearings were just loose in the box and none of the bearings were what I would call properly greased. I ended up cleaning up and repacking the bearings before I installed them. <br /><br />By all means get a new dust cover too....]]>
   <pubDate>Sun, 18 Jul 2021 15:47:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144150#144150</guid>
   <title>Wheel Bearing : You could see the bearing there...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144147#144147</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 3:17pm<br /><br />You could see the bearing there was no dust cover on outside hub lost it the first time Tire is slanted. ]]>
   <pubDate>Sun, 18 Jul 2021 15:17:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144147#144147</guid>
   <title>Wheel Bearing : You sure it&amp;#039;s the bearing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144146#144146</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 3:05pm<br /><br />You sure it's the bearing smoking and not the brakes on the new assembly? They could have been over tightened.<div><br></div><div>fred</div>]]>
   <pubDate>Sun, 18 Jul 2021 15:05:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144146#144146</guid>
   <title>Wheel Bearing : Had an issue with my 2017 rpod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144145#144145</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6127" rel="nofollow">Vector1952</a><br /><strong>Subject:</strong> 14806<br /><strong>Posted:</strong> 18 Jul 2021 at 2:56pm<br /><br />Had an issue with my 2017 rpod 179 wheel bearing, started smoking..bought a drum kit had a mechanic put it on..200 miles later that drunk kit started smoking. Now stuck in NJ...possibly an axel? Which one?]]>
   <pubDate>Sun, 18 Jul 2021 14:56:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14806&amp;PID=144145#144145</guid>
