  <title>R-pod Owners Forum : Exterior dome light</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : Exterior dome light</description>
  <pubDate>Wed, 23 Sep 2026 20:11:08 +0000</pubDate>
  <lastBuildDate>Fri, 25 Jun 2021 15:43:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14762</WebWizForums:feedURL>
   <title>Exterior dome light : Thank  you </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143654#143654</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11550" rel="nofollow">kcbean</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 3:43pm<br /><br />Thank  you]]>
   <pubDate>Fri, 25 Jun 2021 15:43:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143654#143654</guid>
   <title>Exterior dome light : The switch on the same light on...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143653#143653</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 3:16pm<br /><br />The switch on the same light on my 179 is flakey. I have to rock it back and forth until it finally maintains contact. I don't think those switches are very well designed.]]>
   <pubDate>Fri, 25 Jun 2021 15:16:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143653#143653</guid>
   <title>Exterior dome light : Must be the switch new lid does...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143649#143649</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11550" rel="nofollow">kcbean</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 1:55pm<br /><br />Must be the switch new lid does not work<br />]]>
   <pubDate>Fri, 25 Jun 2021 13:55:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143649#143649</guid>
   <title>Exterior dome light : THANK YOU I WILL .. APPRECITE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143644#143644</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11550" rel="nofollow">kcbean</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 10:46am<br /><br />THANK YOU&nbsp; I WILL .. APPRECITE IT<div><br></div>]]>
   <pubDate>Fri, 25 Jun 2021 10:46:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143644#143644</guid>
   <title>Exterior dome light : I&amp;#039;d suggest taking it to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143643#143643</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5021" rel="nofollow">TheBum</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 9:27am<br /><br />I'd suggest taking it to an auto parts store and they should be able to help you figure it out. It's just an automotive bulb.]]>
   <pubDate>Fri, 25 Jun 2021 09:27:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143643#143643</guid>
   <title>Exterior dome light :   If it&amp;#039;s not working the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143642#143642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 9:15am<br /><br />If it's not working the cause is probably a wiring, grounding, or 12v supply issue, maybe a bad switch.&nbsp;&nbsp;]]>
   <pubDate>Fri, 25 Jun 2021 09:15:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143642#143642</guid>
   <title>Exterior dome light : We just got a 2016 our pod and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143641#143641</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11550" rel="nofollow">kcbean</a><br /><strong>Subject:</strong> 14762<br /><strong>Posted:</strong> 25 Jun 2021 at 8:50am<br /><br />We just got a 2016 our pod and I’m trying to replace the domelight that’s an LED light in the front near the propane bottle anybody know what size LED light that is I take it off and I don’t see numbers thank you]]>
   <pubDate>Fri, 25 Jun 2021 08:50:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14762&amp;PID=143641#143641</guid>
