  <title>R-pod Owners Forum : Generator</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Generator</description>
  <pubDate>Mon, 26 Oct 2026 02:33:08 +0000</pubDate>
  <lastBuildDate>Sun, 27 Jun 2021 15:51:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14756</WebWizForums:feedURL>
   <title>Generator : Next step is to find out what...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143688#143688</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 27 Jun 2021 at 3:51pm<br /><br />Next step is to find out what other ac loads are left on. I would suspect the water heater element or the fridge might be on ac rather than propane. Turn on one breaker at a time and listen for the generator loading up. If it's the water heater just leave that breaker off unless you are on shore power, or you can shut it off using the little partially hidden switch inside the water heater external cover. <br /><br />You quite likely do not need a second generator as long as you manage your loads carefully. Especially you can't run the micro and a/c simultaneously, but that's really not much of a hardship. That's the way several of use do it here.<br /><br />You will need an Easystart soft starter for the a/c. A 2kw generator can run the a/c but does not provide enough current for compressor startup. Lots of posts here on the Easystart. Cost is about $300, install is pretty easy but you do need to get on the roof to do it. <br /><br />]]>
   <pubDate>Sun, 27 Jun 2021 15:51:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143688#143688</guid>
   <title>Generator : Good to hear your generator can...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143684#143684</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11254" rel="nofollow">campman</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 27 Jun 2021 at 11:44am<br /><br />  Good to hear your generator can work if you load manage!  A 2nd Yamaha generator to parallel if/when needed is a good idea as they are easier to handle individually rather then one larger generator.<br /><br />  Only downside is the extra cost to get another genny as well as now having 2 generators to fuel up and maintain...also takes up a bit more of your storage space.<br /><br />  All in all a successful resolution.  Have a great day.<br /><br />  Andy<br />]]>
   <pubDate>Sun, 27 Jun 2021 11:44:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143684#143684</guid>
   <title>Generator : Thank you for the feedback. I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143683#143683</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11024" rel="nofollow">Rodg Pod</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 27 Jun 2021 at 10:45am<br /><br />Thank you for the feedback. I shut all the breakers, but the main, and the generator ran the microwave. when plugged into the POD. I guess I'll need another 2000w generator to run in parallel when necessary. I typically never run 120v items, but it is nice to have the option.&nbsp;&nbsp;]]>
   <pubDate>Sun, 27 Jun 2021 10:45:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143683#143683</guid>
   <title>Generator : I tested my micro and it was around...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143621#143621</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 24 Jun 2021 at 12:07pm<br /><br />I tested my micro and it was around 1300 watts IIRC, less than the a/c. My 2kw Honda will run either one, but of course not both simultaneously.]]>
   <pubDate>Thu, 24 Jun 2021 12:07:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143621#143621</guid>
   <title>Generator : A typical 1000 watt micro draws...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143618#143618</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9899" rel="nofollow">Colt</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 24 Jun 2021 at 11:30am<br /><br />A typical 1000 watt micro draws over 1800 watts.  Mine at home pulls 1835 watts continuously.  I haven't tested the 'Pod micro because the plug is hard to get to.  <br /><br />You prolly need more generator.  ]]>
   <pubDate>Thu, 24 Jun 2021 11:30:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143618#143618</guid>
   <title>Generator : 2 kw peak, 1600w continuous should...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143598#143598</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 23 Jun 2021 at 5:47pm<br /><br />2 kw peak, 1600w continuous should run the microwave. It might not run anything else with significant demand (fridge, water heater element, a/c, or converter if the battery is low)  at the same time. My 2kw Honda will run everything in the trailer but not all at once.<br /><br />Try shutting off all the breakers except the micro and see if that works. Or run the micro directly as others have suggested. ]]>
   <pubDate>Wed, 23 Jun 2021 17:47:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143598#143598</guid>
   <title>Generator : Hello Rodger.  Sorry to hear you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143595#143595</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11254" rel="nofollow">campman</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 23 Jun 2021 at 4:38pm<br /><br />  Hello Rodger.  Sorry to hear you are having a problem with your genny.<br /><br />  I think it won't help you to try keeping your generator at max speed when turning on your microwave (turn off your eco mode), but you could give it a shot.  <br /><br />  On another recent "generator not big enough" thread "Johninidaho" mentioned that if your TT battery(s) are low, your converter in your trailer will suck a lot of energy from your genny as it tries to charge them.  This can also be contributing to overloading your Yamaha when you try using your microwave.<br /><br />  You should have an overload light on your genset that comes on if it senses an overload condition...if the overload condition continues for too long, power is cut off via a cb as it tries to protect itself.  If your loads are too large, a bigger generator would be needed.<br /><br />  You could try running an extension cord directly to your microwave to see if it indeed overloads your genny as it would take all other loads out of the equation.  I think it will still not be enough generator, but that is just me.<br /><br />  Your generator sounds like it is too small for what you are demanding from it and this could damage your Yamaha genset if you keep overloading it.  I would keep that in mind as well.<br /><br />  I have a 3300i (3300 watts surge, 3000 watts continuous) I will be using for our trailer.  A bit extra capacity you may wish to consider.  Mine is a FIRMAN from Costco, great little unit, super price.  I also use it at home during power outages.  I did swap out the spark plug when I got it as the one provided was cracked.<br /><br />  There you go, hope this helps you out!<br /><br />  Andy <br /><br />  ]]>
   <pubDate>Wed, 23 Jun 2021 16:38:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143595#143595</guid>
   <title>Generator :  Give us a bit more info and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143594#143594</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 23 Jun 2021 at 4:37pm<br /><br /><div>Give us a bit more info and we wont have to make it a guessing game.&nbsp;</div><div><br></div><div>Are you plugging a microwave directly into the generator? And it shuts off? If so, it may be defective, or maybe you are at high altitude and the generator output ratings have to be de-rated.<div><br></div><div>Or are you trying to operate the convection/microwave installed in your r-pod, and the r-pod is plugged into the generator? And it shuts off? If that is the case you will have to turn off ALL other items such as the 120-12v converter/charger and the water heater 120v switch and the roof A/C.&nbsp;</div><div><br></div><div><br></div></div>]]>
   <pubDate>Wed, 23 Jun 2021 16:37:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143594#143594</guid>
   <title>Generator : Hello all,I have aA-iPower Powered...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143593#143593</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11024" rel="nofollow">Rodg Pod</a><br /><strong>Subject:</strong> 14756<br /><strong>Posted:</strong> 23 Jun 2021 at 4:11pm<br /><br />Hello all,<div><br></div><div>I have a&nbsp;</div><h1 itemprop="name" style="-sizing: border-; font-size: 20px; margin-right: 0px; margin-bottom: 10px; margin-left: 0px; font-family: Arial, Helvetica, &quot;Helvetica Neue&quot;, Roboto, sans-serif; font-weight: 400; line-height: 1.1; color: rgb51, 51, 51;">A-iPower Powered by Yamaha Inverter Generator that I got from costco.</h1><div><br></div><div>2000w/1600w</div><div><br></div><div>I can't get it to run the microwave even though nothing else is running. It runs for about 20 seconds then the microwave quits.&nbsp;</div><div><br></div><div>Does anyone have an idea how to get this to run the microwave, or is it just not a powerful enough generator.</div><div><br></div><div>Any suggestions would be appreciated.</div><div><br></div><div>Thank you</div>]]>
   <pubDate>Wed, 23 Jun 2021 16:11:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14756&amp;PID=143593#143593</guid>
