  <title>R-pod Owners Forum : Grey tank not draining, please help!</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Grey tank not draining, please help!</description>
  <pubDate>Mon, 26 Oct 2026 04:37:43 +0000</pubDate>
  <lastBuildDate>Sun, 06 Jun 2021 11:52:44 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14703</WebWizForums:feedURL>
   <title>Grey tank not draining, please help! : Sounds like you did everything...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143169#143169</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9509" rel="nofollow">ReluctantTraveler</a><br /><strong>Subject:</strong> 14703<br /><strong>Posted:</strong> 06 Jun 2021 at 11:52am<br /><br />Sounds like you did everything that I would have tried. Really seemed like there was some sort of blockage that came loose, but the snake should have shown something. Plumbing clogs can be a real mystery. If pressure lock between black and gray tanks was the case, I wonder if Forest River can provide any more info on the causes. Glad you got it to drain; this sounds like a big headache for anyone. Keep us posted if you learn anything new and if it happens again.<br>]]>
   <pubDate>Sun, 06 Jun 2021 11:52:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143169#143169</guid>
   <title>Grey tank not draining, please help! : OK, so we rode around and sloshed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143149#143149</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10509" rel="nofollow">CameronPod</a><br /><strong>Subject:</strong> 14703<br /><strong>Posted:</strong> 05 Jun 2021 at 4:45pm<br /><br />OK, so we rode around and sloshed the tanks as much as we could. We dumped the black, flushed the black really good, then went to go dump the grey. AND...it worked! yippee!! When I searched a zillion sites last week looking for a fix someone wrote about the tank dump like a pressure issue can form between the black and grey. I'm glad it worked, but really have no idea why, and maybe we knocked a clog loose. Anyway, if anyone has any input on anything we did, please let me know. Hope this helps someone else some day.&nbsp;<div><br></div><div>Camerons</div>]]>
   <pubDate>Sat, 05 Jun 2021 16:45:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143149#143149</guid>
   <title>Grey tank not draining, please help! : Hello, we have a 2017 RP 178,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143147#143147</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10509" rel="nofollow">CameronPod</a><br /><strong>Subject:</strong> 14703<br /><strong>Posted:</strong> 05 Jun 2021 at 3:19pm<br /><br />Hello, we have a 2017 RP 178, used but new to us, and this is our second season. Bought it from friends that I know are pretty careful and we are also about what goes down the drains. The grey tank will not drain and water is backed up in the shower pan. If we run water in the kitchen sink, it backs up more in the shower pan. This is what we have tried:&nbsp;<div><br></div><div>Ran HOT water in the sink and shower.&nbsp;</div><div>Plunged kitchen sink and shower.&nbsp;</div><div>Manually snaked the shower, kitchen sink, roof vent, and up the main dump valve. Snake comes out clean and seems to get to the grey tank each time.&nbsp;</div><div>One at a time we put compressed air in both sinks, the shower, the roof vent. We blocked all other outlets while putting in the air trying to build a little bit of pressure.&nbsp;</div><div><br></div><div>We have not tried soap or the vinegar/baking soda in the drains yet. There doesn't seem to be any residue or a clog we can find with the snake. We thought it was maybe an air lock. We just filled the black tank 2/3 and are going to take a rowdy ride around the neighborhood and go dump the black, flush the black, and try to dump the grey. Will go for the soap, or baking soda vinegar next if that doesn't do it. What the heck else? Thanks in advance for your help!</div><div><br></div><div>Camerons</div><div><br></div><div><br></div>]]>
   <pubDate>Sat, 05 Jun 2021 15:19:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14703&amp;PID=143147#143147</guid>
