  <title>R-pod Owners Forum : Seam Seperation, any ideas??</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Seam Seperation, any ideas??</description>
  <pubDate>Thu, 29 Oct 2026 11:46:15 +0000</pubDate>
  <lastBuildDate>Fri, 28 May 2021 15:20:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14672</WebWizForums:feedURL>
   <title>Seam Seperation, any ideas?? : Take a look at the construction...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142917#142917</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14672<br /><strong>Posted:</strong> 28 May 2021 at 3:20pm<br /><br />Take a look at the construction video so you know what is and isn't in there before you make any repairs. Also, be sure it's dried out before you do anything else. Get a wood moisture meter (about $35 on Amazon) so you know what you have <br /><br /><a href="https://youtu.be/QXNYA73rCNE" target="_blank">rpod construction</a>]]>
   <pubDate>Fri, 28 May 2021 15:20:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142917#142917</guid>
   <title>Seam Seperation, any ideas?? :  Been there, done that. Not nearly...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142914#142914</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=2297" rel="nofollow">fwunder</a><br /><strong>Subject:</strong> 14672<br /><strong>Posted:</strong> 28 May 2021 at 2:52pm<br /><br />Been there, done that. Not nearly as bad what you are showing from the outside. Mine manifested itself inside front passenger side locker:<div><br></div><div><a href="http://www.rpod-owners.com/forum_posts.asp?TID=7904&amp;KW=wall+repair&amp;PID=90257&amp;title=outer-side-seams#90257" target="_blank">http://www.rpod-owners.com/forum_posts.asp?TID=7904&amp;KW=wall+repair&amp;PID=90257&amp;title=outer-side-seams#90257</a></div><div><br></div><div>I have since replaced all screws along seams (sides and bottom) with stainless and taped along bottom front edge with eternabond.&nbsp;</div><div><br></div><div>I figure with that repair I could put an outboard mount instead of the spare tire, put some rod holders on the back and go fishing!!&nbsp;</div><div><br></div><div>fred</div>]]>
   <pubDate>Fri, 28 May 2021 14:52:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142914#142914</guid>
   <title>Seam Seperation, any ideas?? : Our 2016 RPOD 171 seems to be...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142913#142913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10360" rel="nofollow">awags</a><br /><strong>Subject:</strong> 14672<br /><strong>Posted:</strong> 28 May 2021 at 2:22pm<br /><br />Our 2016 RPOD 171 seems to be splitting at the seams, tried to screw it back in but the screws popped out and I can see some water damage. &nbsp;this is both sides of the seams on the propane side where the rock guard is. &nbsp;It also seems like the top has some type of breakage going on like it ran into something. &nbsp;We bought is used and I never noticed it before. &nbsp;Does anyone have any ideas how to repair?<img src="uploads/10360/20210528_130602.jpg" height="1024" width="576" border="0" /><img src="uploads/10360/20210528_130623.jpg" height="1024" width="576" border="0" /><img src="uploads/10360/20210528_130700.jpg" height="720" width="1280" border="0" />]]>
   <pubDate>Fri, 28 May 2021 14:22:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14672&amp;PID=142913#142913</guid>
