  <title>R-pod Owners Forum : Jacking Up Rpod 179</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Jacking Up Rpod 179</description>
  <pubDate>Thu, 29 Oct 2026 12:39:25 +0000</pubDate>
  <lastBuildDate>Sun, 23 May 2021 17:23:52 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14654</WebWizForums:feedURL>
   <title>Jacking Up Rpod 179 : Thanks kindly </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142779#142779</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8538" rel="nofollow">MikeP</a><br /><strong>Subject:</strong> 14654<br /><strong>Posted:</strong> 23 May 2021 at 5:23pm<br /><br />Thanks kindly<br>]]>
   <pubDate>Sun, 23 May 2021 17:23:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142779#142779</guid>
   <title>Jacking Up Rpod 179 : The frame is only 0.1 in thick....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142750#142750</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14654<br /><strong>Posted:</strong> 22 May 2021 at 7:10pm<br /><br />The frame is only 0.1 in thick. I wouldn't jack where you marked. See the vertical flanges where the axle it attached to the riser? Those vertical flanges are really strong because there is a lot of steel I'm the direction of the jack lifting force. That's where I lift mine.<br /><br />In case it's not obvious  leave the trailer attached to the tow vehicle eth the TV in gear and brake set. ]]>
   <pubDate>Sat, 22 May 2021 19:10:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142750#142750</guid>
   <title>Jacking Up Rpod 179 : Hi folks. Does this pic raise...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142737#142737</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8538" rel="nofollow">MikeP</a><br /><strong>Subject:</strong> 14654<br /><strong>Posted:</strong> 22 May 2021 at 1:17pm<br /><br />Hi folks. Does this pic raise any flags to anyone?&nbsp; I've read through the many posts on this subject, but still would appreciate comments.&nbsp; I'm planning on lifting by frame, and a couple vids I saw suggests lifting on the frame just "behind" the axle bracket. But I can't make that work on the one side because the steps are in the way.&nbsp; So, anyone foresee issues lifting just in front of the back tire at where I put the red marks on the picture? Any red flags on the jack I using ?&nbsp; Totally overthinking this I'm sure but first time you know.&nbsp; Thanks for the thoughts<img src="uploads/8538/Jackep%20Up.jpg" height="1124" width="828" border="0" /><br>]]>
   <pubDate>Sat, 22 May 2021 13:17:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14654&amp;PID=142737#142737</guid>
