  <title>R-pod Owners Forum : Roof Construction</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Podmods, Maintenance, Tips and Tricks : Roof Construction</description>
  <pubDate>Wed, 28 Oct 2026 07:31:22 +0000</pubDate>
  <lastBuildDate>Fri, 15 Oct 2010 22:21:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=1462</WebWizForums:feedURL>
   <title>Roof Construction : I have lots of finished projects...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12335#12335</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 10:21pm<br /><br />I have lots of finished projects in my head - they all look great, better than professional quality and 1/4 the cost.  <img src="https://www.rpod-owners.com/smileys/smiley33.gif" border="0" alt="Ying Yang" title="Ying Yang" />]]>
   <pubDate>Fri, 15 Oct 2010 22:21:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12335#12335</guid>
   <title>Roof Construction : This is what I want to figure...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12328#12328</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=550" rel="nofollow">Gerald</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 1:50pm<br /><br />This is what I want to figure out. My winter project is to build some cabinets over the bed and over the dinette on our 177. Still in the planning stages to see if it is feasable. First have to locate the inside studs and roof rafters. Have not tried the stud finder yet but I doubt if it will work because of the solid insulation. By doing the old fashioned knocking on the wall I have been able to locate the approximate location of the wall studs. The ceiling is a lot easier as the studs seem to be located at the ceiling panel joins. Lots of planning still to do and will publish pictures as I go. I can see the finished project in my mind (looks great and is going to be very practical). It's going to be a long winter.]]>
   <pubDate>Fri, 15 Oct 2010 13:50:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12328#12328</guid>
   <title>Roof Construction : Hmmm, now to figure out how to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12326#12326</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 1:10pm<br /><br />Hmmm, now to figure out how to do the same on the inside (to add shelves, etc).&nbsp; I guess it needs to be cold outside and warm and humid inside.&nbsp; Has anyone tried to use a stud finder?]]>
   <pubDate>Fri, 15 Oct 2010 13:10:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12326#12326</guid>
   <title>Roof Construction : Fantastic idea. I am going to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12325#12325</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=550" rel="nofollow">Gerald</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 10:23am<br /><br />Fantastic idea. I am going to keep an eye on my pod. With the frosty mornings now I should be able to see the outlines of the roof rafters and sides. That is what I am looking for&nbsp;when I do future mods.]]>
   <pubDate>Fri, 15 Oct 2010 10:23:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12325#12325</guid>
   <title>Roof Construction : Its good to know the roof has...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12323#12323</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=428" rel="nofollow">David and Danette</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 9:55am<br /><br />&nbsp;&nbsp; Its good to know the roof has aluminum rafters. This morning I noticed something I've never noticed before. There was condensation on the sides of the trailer and I noticed a pattern of lines up and down. Then I realized the lines were the outline of the aluminum frame behind the fiberglass. I&nbsp;used a pencil and marked where I was able to see the paterns from the condensation. It may be usefull for possible future mods.&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; David and Danette]]>
   <pubDate>Fri, 15 Oct 2010 09:55:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12323#12323</guid>
   <title>Roof Construction : Good to know, thanks. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12322#12322</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=217" rel="nofollow">techntrek</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 15 Oct 2010 at 9:49am<br /><br />Good to know, thanks.]]>
   <pubDate>Fri, 15 Oct 2010 09:49:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12322#12322</guid>
   <title>Roof Construction : Should have posted a new topic...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12315#12315</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=550" rel="nofollow">Gerald</a><br /><strong>Subject:</strong> 1462<br /><strong>Posted:</strong> 14 Oct 2010 at 3:18pm<br /><br />Should have posted a new topic for this in the first place to get it off the "Gas Mileage" posts. Forest River said that the roof rafters were not in the correct position to screw the spoiler on to and additional rafters would have to be inserted, I wanted to know if the rafters were wood or aluminum? I emailed Forest River and was impressed with their response time.....15 minutes.<DIV>&nbsp;</DIV><DIV>Here is their response:</DIV><DIV><FONT color=navy size=2 face=Arial><SPAN style="FONT-FAMILY: Arial; COLOR: navy; FONT-SIZE: 10pt"></SPAN></FONT>&nbsp;</DIV><DIV><FONT color=navy size=2 face=Arial><SPAN style="FONT-FAMILY: Arial; COLOR: navy; FONT-SIZE: 10pt">Hi Gerald,</SPAN></FONT></DIV><DIV><P =Ms&#111;normal><FONT color=navy size=2 face=Arial><SPAN style="FONT-FAMILY: Arial; COLOR: navy; FONT-SIZE: 10pt">The Roof itself is a laminated structure, constructed the same way the walls are, aluminum.&nbsp; The radius portion of the front/back walls have wood rafters.</SPAN></FONT></P><P =Ms&#111;normal><FONT color=navy size=2 face=Arial><SPAN style="FONT-FAMILY: Arial; COLOR: navy; FONT-SIZE: 10pt">&nbsp;</SPAN></FONT><FONT color=navy size=3 face="Lucida Handwriting"><SPAN style="FONT-FAMILY: 'Lucida Handwriting'; COLOR: navy; FONT-SIZE: 12pt">Kristin Griffin</SPAN></FONT><FONT color=navy><SPAN style="COLOR: navy"> </SPAN></FONT></P></DIV>]]>
   <pubDate>Thu, 14 Oct 2010 15:18:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=1462&amp;PID=12315#12315</guid>
