  <title>R-pod Owners Forum : 2020 rPod 196 Vinyl Roof Failure</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : 2020 rPod 196 Vinyl Roof Failure</description>
  <pubDate>Mon, 26 Oct 2026 03:47:49 +0000</pubDate>
  <lastBuildDate>Sun, 25 Apr 2021 11:08:53 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14587</WebWizForums:feedURL>
   <title>2020 rPod 196 Vinyl Roof Failure : I just pulled off the RV-grade...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14587&amp;PID=142060#142060</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11301" rel="nofollow">dasbryant</a><br /><strong>Subject:</strong> 14587<br /><strong>Posted:</strong> 25 Apr 2021 at 11:08am<br /><br />I just pulled off the RV-grade cover off of our 2020 R-pod 196 and I noticed that the factory caulk that seals the vinyl roof sheet to the front sheet that curves down the front of the vehicle has separated.&nbsp; It's almost as if the vinyl roof sheet shrunk about 1'4" and pulled away from the caulk for approximately 24".&nbsp; The sides and back all appear to be OK, as well as the caulk around all the roof vents, AC, etc.&nbsp;<div>I can see what appears to be plywood? or particle board? under the vinyl roof sheet where it pulled away.&nbsp;&nbsp;</div><div>Hopefully since it was covered all winter, it wasn't exposed to too much water and hasn't started to rot the sub-roof material.</div><div><br></div><div>I could go re-caulk it myself, but I'm going to call the dealer tomorrow and have them take a look.&nbsp; We bought the full warranty, so the fix will be on their dime.&nbsp; I assume the roof material under the vinyl needs to dry out before re-caulking.&nbsp; Until I get it in, I'll keep an eye on the weather.&nbsp; If it looks like rain, I'll put a sheet of plastic over the separation to protect it.&nbsp;</div><div><br></div><div>Anyone else had this happen before, and if so, was it serious enough to require major roof repairs?</div><div><br></div><div>Thanks</div>]]>
   <pubDate>Sun, 25 Apr 2021 11:08:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14587&amp;PID=142060#142060</guid>
