  <title>R-pod Owners Forum : Starting fridge on propane</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Starting fridge on propane</description>
  <pubDate>Mon, 26 Oct 2026 03:44:15 +0000</pubDate>
  <lastBuildDate>Mon, 19 Apr 2021 18:18:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14568</WebWizForums:feedURL>
   <title>Starting fridge on propane : It should work ok to install the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141915#141915</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 6:18pm<br /><br />It should work ok to install the battery in the morning. Then start the fridge on propane so it cools down as fast as possible. Not on 12v which provides much less cooling effectiveness. There is very little thermal mass in the fridge box and components, it's mostly in the food and liquids so if you put those in cold you should be ok. Might want to put in the battery temporarily a couple days before for a half hour or so to be sure the fridge and everything else is working as it should.<br /><br />When I had my airplane I used to keep an rv in at a mountain airport and flew in, turned on the fridge, went to the store, put in cold drinks and groceries, and went camping. Worked fine and saved many hours of tedious driving. ]]>
   <pubDate>Mon, 19 Apr 2021 18:18:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141915#141915</guid>
   <title>Starting fridge on propane : The purpose of a lock is not to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141914#141914</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 6:18pm<br /><br />The purpose of a lock is not to make it impossible for someone to steal the battery, but to make it inconvenient enough that the thief decides to look elsewhere.]]>
   <pubDate>Mon, 19 Apr 2021 18:18:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141914#141914</guid>
   <title>Starting fridge on propane : I had a feeling it would be a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141913#141913</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 6:10pm<br /><br />I had a feeling it would be a bad idea to leave the cover on.<br /><br />I can’t really take the trailer to a friends house because that’s not an option. I do have the battery in a case and I have a locking cable on it but it won’t hold up the ball cutters. I put it together that way basically to keep someone from taking it while in route.]]>
   <pubDate>Mon, 19 Apr 2021 18:10:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141913#141913</guid>
   <title>Starting fridge on propane : It would be a bad idea to start...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141911#141911</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 6:00pm<br /><br />It would be a bad idea to start the refrigerator with the cover on because it would block the needed airflow. You could put a chain around the battery with a lock. That would help. Is the battery bare or in a case? You could check out version 1 and version 2 of the battery lock-down system I made. Now I don't use it because the LiFePO4 battery I installed is inside and out of sight.]]>
   <pubDate>Mon, 19 Apr 2021 18:00:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141911#141911</guid>
   <title>Starting fridge on propane : Could you safely leave your R-Pod...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141910#141910</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 5:55pm<br /><br /><div>Could you safely leave your R-Pod at a friends house for a day or two before you leave?&nbsp; At least that way you could run the fridge off your new battery and make sure everything is working satisfactory before leaving.&nbsp; Sorry to hear about the thievery going on - a sign of our society unfortunately.</div><div><br></div><div>Not a good idea to block the airflow from your vents, after ignition/firing of gas at the combustion chamber, heat goes up through your chimney, air temp increases behind the fridge, your bi-metal switch engages causing your muffin fan (s) to kick on and commence the cooling process.&nbsp; If vents are covered, the above will still happen but the fans will not be allowed to bring in cool air from below and expel the hot air from above causing the cooling ability to be severely restricted. <br></div>]]>
   <pubDate>Mon, 19 Apr 2021 17:55:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141910#141910</guid>
   <title>Starting fridge on propane : Haven&#226;&#8364;&#8482;t put any screens in,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141909#141909</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 5:21pm<br /><br />Haven’t put any screens in, but that’s a good idea. I’ll get the compressed air and try that. I’m sure there’s bugs up in there. They’re everywhere.<br /><br />Kind of hesitant to install the battery on Sunday, the day before the trip, because the storage yard is fairly dark and there have been problems with theft. Just last week I came over and found the both my storage compartment doors had been opened and some of my stuff thrown on the ground and everything rifled through. Doesn’t look like they stole anything, but I’m having a locksmith come out today to replace the universal locks with better key locks including replacing the thumb locks with key locks.<br /><br />The last thing I want to do is install a $130 battery and then have it stolen that night! I might just do it Monday morning and put all of our food into an ice chest in the back of the truck until we get up into the redwoods.<br /><br />I have a cover over the trailer, but I’m thinking I should remove that before I start the fridge because I don’t want to block airflow. It would hide the battery on the tongue though. Can I start the fridge on propane first and then remove the cover of the following day? Or is that a bad idea?]]>
   <pubDate>Mon, 19 Apr 2021 17:21:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141909#141909</guid>
   <title>Starting fridge on propane : Have you installed screens over...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141908#141908</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 5:09pm<br /><br /><div>Have you installed screens over your two vents on the rear side of your fridge?&nbsp; If not it would be highly recommended to purchase a can of compressed air and blow out the spot around the combustion area as well as up the cooling stack, from below, as well as from the top of the cooling stack, shooting air down.&nbsp; It only takes a small spider web or bee nest or other debris to cause the fridge to perform less than optimal or not at all.</div><div><br></div><div>If things look pretty clean behind your fridge then try to light it with your new group size 27 battery and make sure you have some propane in your tank and that it is turned on as well.&nbsp; If it lights after one or a few attempts, you should be good to go.<br></div>]]>
   <pubDate>Mon, 19 Apr 2021 17:09:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141908#141908</guid>
   <title>Starting fridge on propane : Thanks all. I need to buy a new...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141902#141902</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 4:32pm<br /><br />Thanks all. I need to buy a new battery because even though I’ve been putting the trickle charger on my original deep cycle battery it no longer holds a charge anymore. I noticed that last year when I tried to move the trailer and the battery wouldn’t operate the power lift. So I need to get a new battery at work. Luckily we are an AC Delco distributor and I can get an M 27 Marine battery at cost. I guess I will install a battery this coming weekend and start the fridge. I know some people have had maintenance issues when their pods have sat for a long time and the fridge won’t light. Is there anything I should clean or look at before hand? Thanks all.]]>
   <pubDate>Mon, 19 Apr 2021 16:32:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141902#141902</guid>
   <title>Starting fridge on propane : I always start my &amp;#039;fridge...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141900#141900</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9899" rel="nofollow">Colt</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 4:28pm<br /><br /><div>I always start my 'fridge on gas the day before I leave and switch to battery on the road.&nbsp; I believe the owner's manual (such as it is) tells you to do that.&nbsp; There is enough power available through my 7 circuit trailer wiring to maintain the battery.&nbsp; This works quite well.&nbsp; <br></div><div><br></div><div>I use a simple solar panel/controller to maintain my battery in storage.&nbsp; <br></div><div><br></div><div>Controller<br></div><div>https://smile.amazon.com/gp/product/B004Q820UK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1</div><div><br></div><div>Panel<br></div><div>https://smile.amazon.com/gp/product/B01IFJ73X4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&amp;psc=1</div><div><br></div><div>i have a battery disconnect.&nbsp; A larger panel, or a sunnier location and this system would keep the battery up without a disconnect.&nbsp; <br></div>]]>
   <pubDate>Mon, 19 Apr 2021 16:28:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141900#141900</guid>
   <title>Starting fridge on propane : Good to hear you are all vaccinated...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141898#141898</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11254" rel="nofollow">campman</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 3:50pm<br /><br />Good to hear you are all vaccinated up and ready to begin to pod!  Now I can't answer your question directly as we are awaiting our 192.  But, from what I have noted as I have perused many of the discussions here I will try to touch on some important points to help you out. <br /><br />  First, is your trailer level?  It must be less than 3 degrees away from level for the propane flame to operate the system properly...damage can quickly occur to your trailer fridge cooling system if it is at more of a tilt than that (damage may occur in as quickly as 15 or 20 minutes from what I have researched).<br /><br />  2nd, is your TT battery(s) fully charged?  If it doesn't have a solar panel and charge controller on it and you haven't brought your battery(s) home to charge for an extended period of time (or even a few days if you have no battery isolation switch on your TT), your battery(s) may be low or discharged.  And you need battery power to operate your fridge on propane and for it to last until you hook up to leave.<br /><br />  So, if all is good so far I would say you would be able to use your propane to precool your fridge, as long as you don't precool it for a week, and I don't think that is your plan.<br /><br />  From prior experience and also again from other posts her on the forum, make sure you are only putting things in your fridge/freezer that are already cool/frozen.  Don't try to use the trailer fridge/freezer  to cool or freeze items, you may be asking too much from it!  Make sure it is all cold before putting it in before you go.<br /><br />  Hope this has helped and you have a great trip!<br /><br />ANDY<br /><br />  ]]>
   <pubDate>Mon, 19 Apr 2021 15:50:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141898#141898</guid>
   <title>Starting fridge on propane :  Remember that the 120V AC shore...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141895#141895</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 3:41pm<br /><br />Remember that the 120V AC shore power is being converted to 12V DC power which the refrigerator and other things like the water heater need to work. So, it will work if shore power is available. However, the OP said that shore power was not available in the storage lot.]]>
   <pubDate>Mon, 19 Apr 2021 15:41:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141895#141895</guid>
   <title>Starting fridge on propane :   Originally posted by StephenHOne...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141893#141893</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 3:37pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br />One caveat though. Make sure you have a fully charged battery. If it has been sitting unused (unless you have a battery disconnect or you removed a terminal) the battery is likely discharged. The refrigerator needs 12V power to run the electronics and to light the flame (no pilot light, but electric ignition). If the battery is charged, then you will be okay for a few days if the battery is fully charged to start.</td></tr></table> <br></div><div><br></div><div>Didn't think of this until now I guess because we usually boondock.&nbsp; Does the electric ignition of the RM 8501 fridge only work off the 12v battery or would it also function off 120v shore power?<br></div>]]>
   <pubDate>Mon, 19 Apr 2021 15:37:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141893#141893</guid>
   <title>Starting fridge on propane : One caveat though. Make sure you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141892#141892</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 3:33pm<br /><br />One caveat though. Make sure you have a fully charged battery. If it has been sitting unused (unless you have a battery disconnect or you removed a terminal) the battery is likely discharged. The refrigerator needs 12V power to run the electronics and to light the flame (no pilot light, but electric ignition). If the battery is charged, then you will be okay for a few days if the battery is fully charged to start.]]>
   <pubDate>Mon, 19 Apr 2021 15:33:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141892#141892</guid>
   <title>Starting fridge on propane :  What you propose is an excellent...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141891#141891</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 3:29pm<br /><br /><div>What you propose is an excellent idea.&nbsp; Actually the fridge will cool down quicker using propane vs. shore power.&nbsp; We normally allow 24 hours to totally cool the fridge down but have cut that in 1/2 by adding a few ice blocks (or similar) when cooling down.&nbsp; Put in both freezer and fridge.&nbsp; Also when adding your food make sure it is already cooled down from your fridge at home (but you likely already knew that).&nbsp; Just covering the bases.</div><div><br></div><div>Also, check your 12v battery and make sure it is at least 12.72v to begin with.&nbsp; The fridge uses very little 12v power but it is necessary to power the mother board/display panel.<br></div>]]>
   <pubDate>Mon, 19 Apr 2021 15:29:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141891#141891</guid>
   <title>Starting fridge on propane : Hey all, we have since moved to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141889#141889</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8361" rel="nofollow">OldNeumanntapr</a><br /><strong>Subject:</strong> 14568<br /><strong>Posted:</strong> 19 Apr 2021 at 2:52pm<br /><br />Hey all, we have since moved to a mobile home park and we are going to be taking our RPOD 180 out for the first time in over a year, now that both my wife and I are fully vaccinated against Covid. The trailer is stored in the storage lot of the mobile home park and there is no electricity available there.<br /><br />I really don’t want to pull it in front of my mobile home to plug-in because I don’t want a big red flag that says ‘I’m going on vacation!’ Question: can I start the fridge on propane to cool it down and leave it sit in the storage lot and then load up and hitch up from there?<br /><br />Will it take any longer to cool down on propane vs 110?]]>
   <pubDate>Mon, 19 Apr 2021 14:52:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14568&amp;PID=141889#141889</guid>
