  <title>R-pod Owners Forum : Small Running light out?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Small Running light out?</description>
  <pubDate>Sun, 25 Oct 2026 21:46:50 +0000</pubDate>
  <lastBuildDate>Sat, 06 Mar 2021 09:10:42 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14434</WebWizForums:feedURL>
   <title>Small Running light out? : Normally these lights will have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140526#140526</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14434<br /><strong>Posted:</strong> 06 Mar 2021 at 9:10am<br /><br />Normally these lights will have a wiring problem, they are LED and bulb is not replaceable.&nbsp; Truck Lite and GloLight are a couple makers.&nbsp; Your issue is a front one I take it, yellow or orange and there are two on the front of the trailer, correct?&nbsp; They pop into a 3/4" hole&nbsp; They are mini lights.&nbsp; You may have to call FR to get PT #, I have seen them but can't recall the brand.&nbsp; Amazon, Etrailer, Camping World are sources if you need the light.&nbsp; They light from the same source, so issue will be light or wiring to the faulty light.]]>
   <pubDate>Sat, 06 Mar 2021 09:10:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140526#140526</guid>
   <title>Small Running light out? : Here are a previous thread with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140519#140519</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10066" rel="nofollow">RoverPod</a><br /><strong>Subject:</strong> 14434<br /><strong>Posted:</strong> 05 Mar 2021 at 5:12pm<br /><br /><div>Here are a previous thread with part numbers.</div><div><br></div><div>http://rpod-owners.com/forum_posts.asp?TID=10329&amp;OB=DESC<br></div>]]>
   <pubDate>Fri, 05 Mar 2021 17:12:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140519#140519</guid>
   <title>Small Running light out? : Has anyone had one of the small...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140512#140512</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10237" rel="nofollow">BMJ</a><br /><strong>Subject:</strong> 14434<br /><strong>Posted:</strong> 04 Mar 2021 at 5:35pm<br /><br />Has anyone had one of the small running lights on the upper front of their R-pod not light?<br />Is there a replacement?, if so how do you do this? I’ll be checking to  make sure that it’s not a pinched wire somewhere but it appears very difficult to get too. Not sure how to attach a picture on this forum , it’s a 1” round amber light on the top front curve of a 195.<br />Thanks!<br />Any suggestions welcomed <br /><br /><br />]]>
   <pubDate>Thu, 04 Mar 2021 17:35:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14434&amp;PID=140512#140512</guid>
