  <title>R-pod Owners Forum : TPS monitors</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : TPS monitors</description>
  <pubDate>Sun, 25 Oct 2026 21:46:48 +0000</pubDate>
  <lastBuildDate>Mon, 01 Mar 2021 08:01:55 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14427</WebWizForums:feedURL>
   <title>TPS monitors : Thanks! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140438#140438</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11053" rel="nofollow">Sauble</a><br /><strong>Subject:</strong> 14427<br /><strong>Posted:</strong> 01 Mar 2021 at 8:01am<br /><br />Thanks!]]>
   <pubDate>Mon, 01 Mar 2021 08:01:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140438#140438</guid>
   <title>TPS monitors :  I bought some Tymate TPMS for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140431#140431</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10795" rel="nofollow">pedwards2932</a><br /><strong>Subject:</strong> 14427<br /><strong>Posted:</strong> 28 Feb 2021 at 8:20pm<br /><br />I bought some Tymate TPMS for my 189 and they seem to work fine for me.&nbsp; The screen you have to get in the right position so there is no glare.<div><a href="https://www.amaz&#111;n.com/Tymate-Tire-Pressure-M&#111;nitoring-System/dp/B085C2HMQP/ref=sr_1_4?crid=JJMI0M592PDS&amp;dchild=1&amp;keywords=tymate+tire+pressure+m&#111;nitoring+system+for+rv+trailer&amp;qid=1614565292&amp;sprefix=Tymate%2Caps%2C200&amp;sr=8-4" target="_blank">Amazon.com: Tymate Tire Pressure Monitoring System-Solar Charge, 5 Alarm Modes, Auto Backlight ＆ Smart LCD Display, Auto Sleep Mode, with 4 External Tpms Sensor (0-87 PSI): Automotive</a></div>]]>
   <pubDate>Sun, 28 Feb 2021 20:20:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140431#140431</guid>
   <title>TPS monitors : +1 mcarter. Same here, many long...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140427#140427</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5324" rel="nofollow">PilotPodder</a><br /><strong>Subject:</strong> 14427<br /><strong>Posted:</strong> 28 Feb 2021 at 6:23pm<br /><br />+1 mcarter. Same here, many long trips over a few years, great battery life on the EEZ. I also use it on two trailers. ~PP]]>
   <pubDate>Sun, 28 Feb 2021 18:23:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140427#140427</guid>
   <title>TPS monitors : I have used the EEZ TMPS on my...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140425#140425</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14427<br /><strong>Posted:</strong> 28 Feb 2021 at 6:10pm<br /><br />I have used the EEZ TMPS on my Pod for several years, easy set up, works fine.&nbsp; I use it to monitor two trailer tires.]]>
   <pubDate>Sun, 28 Feb 2021 18:10:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140425#140425</guid>
   <title>TPS monitors : This spring is new tire time....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140422#140422</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11053" rel="nofollow">Sauble</a><br /><strong>Subject:</strong> 14427<br /><strong>Posted:</strong> 28 Feb 2021 at 6:02pm<br /><br />This spring is new tire time. &nbsp;Tire pressure and temperature on a single axle trailer has been a concern. &nbsp;We would be interested to hear what remote TPS monitors you are using. &nbsp;Pros and cons. &nbsp;Thanks!]]>
   <pubDate>Sun, 28 Feb 2021 18:02:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14427&amp;PID=140422#140422</guid>
