  <title>R-pod Owners Forum : Rpod196 Opinions</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Miscellaneous / Off-topic : Rpod196 Opinions</description>
  <pubDate>Sat, 24 Oct 2026 12:16:54 +0000</pubDate>
  <lastBuildDate>Mon, 18 Jan 2021 18:45:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14329</WebWizForums:feedURL>
   <title>Rpod196 Opinions :  Originally posted by Pod_Geek Hey,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139554#139554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 6:45pm<br /><br /> <table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Pod_Geek</strong></em><br /><br /><br />Hey, we have the Hood River Edition...it's supposed to be the tough R-Pod!</div><br /></td></tr></table> <br />😂😂😂]]>
   <pubDate>Mon, 18 Jan 2021 18:45:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139554#139554</guid>
   <title>Rpod196 Opinions :    Originally posted by BounderLast...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139553#139553</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 6:16pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Bounder</strong></em><br /><br /><div>Last time I checked, the door has not been changed. The key to preserving it is to make sure, ABSOLUTELY SURE, that you use the retaining strap to keep the door restrained during travel. Ours has done fine - till the day it was left unclipped. That led to the door tearing the screws out from those hangers.</div><div><br></div><div>Fortunately, if this does happen, you can flip the door 180 degrees and re-attach the brackets to the new 'top' edge. I suspect that the factory, to make manufacturing and assembly easier, makes it so the door can be installed with either edge up.</div><div><br></div><div>I may re-inforce the set-up over time, but for now simply double-checking the restraining strap has prevented further issues.<br></div></td></tr></table><div><br></div><div>We never drove with the strap unattached.&nbsp; The door broke initially when we drove over about 15 miles of washboard gravel in south-central Colorado.&nbsp; The roller disintegrated several months later during "normal" driving on pavement.&nbsp; It's a design flaw.</div><div><br></div><div>Hey, we have the Hood River Edition...it's supposed to be the tough R-Pod!</div>]]>
   <pubDate>Mon, 18 Jan 2021 18:16:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139553#139553</guid>
   <title>Rpod196 Opinions :   Originally posted by Pete...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139552#139552</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10556" rel="nofollow">Bounder</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 6:00pm<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Pete Brayton</strong></em><br /><br />Thanks, that's what I've been looking for!</td></tr></table> <br></div><div><br></div><div>The current version of the product is on Amazon at this link:</div><div><br></div><div><a href="https://www.amaz&#111;n.com/Vertical-Mountable-Portable-Bluetooth-Headph&#111;ne/dp/B08PYH5LMV" target="_blank">https://www.amazon.com/Vertical-Mountable-Portable-Bluetooth-Headphone/dp/B08PYH5LMV</a><br></div><div><br></div><div>It looks like the new version may have a slightly higher power demand, since it's supplied with a 2 amp USB power supply adapter, but there are similar units on the market.<br></div>]]>
   <pubDate>Mon, 18 Jan 2021 18:00:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139552#139552</guid>
   <title>Rpod196 Opinions : Last time I checked, the door...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139551#139551</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10556" rel="nofollow">Bounder</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 5:55pm<br /><br /><div>Last time I checked, the door has not been changed. The key to preserving it is to make sure, ABSOLUTELY SURE, that you use the retaining strap to keep the door restrained during travel. Ours has done fine - till the day it was left unclipped. That led to the door tearing the screws out from those hangers.</div><div><br></div><div>Fortunately, if this does happen, you can flip the door 180 degrees and re-attach the brackets to the new 'top' edge. I suspect that the factory, to make manufacturing and assembly easier, makes it so the door can be installed with either edge up.</div><div><br></div><div>I may re-inforce the set-up over time, but for now simply double-checking the restraining strap has prevented further issues.<br></div>]]>
   <pubDate>Mon, 18 Jan 2021 17:55:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139551#139551</guid>
   <title>Rpod196 Opinions : We are putting a full queen mattress...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139550#139550</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10813" rel="nofollow">Ricktoon</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 4:39pm<br /><br /><div>We are putting a full queen mattress in our R-pod 196 to replace the short queen. It will be tight getting around the side of the bed near the TV, but want the longer bed. Do you think we need to extend the platform under the bed to support the extra 5 inches of bed hanging off the end. Thinking of making a narrow box that taper down near the floor and using it for shoes or other items at the foot of the bed. Has anyone done this?</div><div><br></div>]]>
   <pubDate>Mon, 18 Jan 2021 16:39:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139550#139550</guid>
   <title>Rpod196 Opinions : I used these (link below). I added...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139548#139548</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 3:07pm<br /><br />I used these (link below). I added a piece of 3/4 x 2 on each side of the storage box. Right next to the small 3/4 x 3/4 support they put in. The lift arm pushes straight down on the support I added. Then I attached a small block (maybe 4 inches square) to the door/under layment for bed. It works great.<div>&nbsp;<div>https://www.amazon.com/gp/product/B00KPR2DBC/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&amp;psc=1</div></div>]]>
   <pubDate>Mon, 18 Jan 2021 15:07:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139548#139548</guid>
   <title>Rpod196 Opinions : Are they still equipping the 2021s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139547#139547</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 2:55pm<br /><br />Are they still equipping the 2021s with a bathroom pocket door that has the small attachments to the rollers in the overlying rail?&nbsp; Mine eventually pulled out of the door and then after I replaced the attachment plates with more robust ones the roller assembly disintegrated.&nbsp; Going forward (after fixing this) I'm going to figure out how to support the door at it's base during transport.]]>
   <pubDate>Mon, 18 Jan 2021 14:55:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139547#139547</guid>
   <title>Rpod196 Opinions : What lift arms did you use. Looking...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139546#139546</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10813" rel="nofollow">Ricktoon</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 2:19pm<br /><br /><div>What lift arms did you use. Looking for what weight level I need to lift cover and mattress. Putting a 10" memory foam mattress on in place of thin short queen.</div><div><br></div><div><br></div>]]>
   <pubDate>Mon, 18 Jan 2021 14:19:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139546#139546</guid>
   <title>Rpod196 Opinions : The under bed storage lift arms...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139543#139543</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 11:52am<br /><br />The under bed storage lift arms make that space so much more usable. Mine now lifts with one finger, infact, it almost wants to lift up by itself. The other thing you might want to do, is replace the adjustable side racks in the pantry. I tend to put a lot of weight in there (canned goods etc) and on my last trip of&nbsp; season 1, it collapsed. It's made of cheap plastic. I replaced mine with some nice steel rails I got on amazon, with adjustable clips. After season 2, it's still perfect.&nbsp;]]>
   <pubDate>Mon, 18 Jan 2021 11:52:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139543#139543</guid>
   <title>Rpod196 Opinions : Thanks, that&amp;#039;s what I&amp;#039;ve...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139534#139534</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 18 Jan 2021 at 7:19am<br /><br />Thanks, that's what I've been looking for!]]>
   <pubDate>Mon, 18 Jan 2021 07:19:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139534#139534</guid>
   <title>Rpod196 Opinions : Adding a player is easy. I bought...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139523#139523</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10556" rel="nofollow">Bounder</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 17 Jan 2021 at 7:01pm<br /><br /><div>Adding a player is easy. I bought a DVD/CD player on Amazon that is powered through a USB connection - the one on the sound system control unit is able to supply the power, and that cleans up the number of cables.</div><div><br></div><div>The HDMI connection feeds through to the existing TV connection from the control unit, or can go directly to the TV if preferred. The one time I tried the CD player function, it played through as well. Light and easy to mount on the wall, affordably priced.</div><div><br></div><div><img src="uploads/10556/Player%201.jpg" height="819" width="614" border="0" /><br></div><div><br></div><div><img src="uploads/10556/Player%202.jpg" height="819" width="614" border="0" /><br></div>]]>
   <pubDate>Sun, 17 Jan 2021 19:01:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139523#139523</guid>
   <title>Rpod196 Opinions : Love it! Need to add some lifts...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139521#139521</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 17 Jan 2021 at 1:29pm<br /><br />Love it! Need to add some lifts to the under bed storage lid and maybe some shelves to the bedside cabinets. I wish it had a cd/dvd player built in but I know that is so "old school".&nbsp;&nbsp;&nbsp;]]>
   <pubDate>Sun, 17 Jan 2021 13:29:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139521#139521</guid>
   <title>Rpod196 Opinions : Whatta ya think? Roomy? dry bath,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139519#139519</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 17 Jan 2021 at 10:42am<br /><br />Whatta ya think? Roomy? dry bath, etc..&nbsp;]]>
   <pubDate>Sun, 17 Jan 2021 10:42:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139519#139519</guid>
   <title>Rpod196 Opinions : I took the Rpod 196 out for it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139511#139511</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 16 Jan 2021 at 3:14pm<br /><br />I took the Rpod 196 out for it's maiden voyage to Cheyenne Mountain State Park at the south end of Colorado Springs. It's a great campground with full hookups and right up against the foothills.<div><img src="uploads/4397/Rpod196.2small.jpg" height="600" width="800" border="0" /><br></div>]]>
   <pubDate>Sat, 16 Jan 2021 15:14:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139511#139511</guid>
   <title>Rpod196 Opinions : I think almost all of the original...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139355#139355</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 08 Jan 2021 at 4:40pm<br /><br />I think almost all of the original pods had separate discharge tubes for gray and black.&nbsp; I've had a 173 and now a 179 and both have separate tubes.&nbsp; It is not a big deal.&nbsp; dump the black tank first and then the gray water ( a little cleaner)&nbsp; can start the washout the hose phase.<br>]]>
   <pubDate>Fri, 08 Jan 2021 16:40:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139355#139355</guid>
   <title>Rpod196 Opinions : Congrats, you will love it. The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139352#139352</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 08 Jan 2021 at 2:37pm<br /><br />Congrats, you will love it. The 4 extra feet, large fridge, huge pantry, dry bath, and north and south bed are going to be great. A lot more storage than your used to also. The one drawback, separate discharge tubes for black and grey water. There's always something.&nbsp;<div><br></div>]]>
   <pubDate>Fri, 08 Jan 2021 14:37:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139352#139352</guid>
   <title>Rpod196 Opinions : Thanks for all of the information...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139350#139350</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 08 Jan 2021 at 2:13pm<br /><br />Thanks for all of the information everyone, I just put a deposit on a 2021 Rpod196 and hope to pick it up next week. Trading in my 2010 172 and definitely going to like the extra room.]]>
   <pubDate>Fri, 08 Jan 2021 14:13:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139350#139350</guid>
   <title>Rpod196 Opinions : We are down to considering the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139238#139238</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11014" rel="nofollow">NewEnglandah</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 03 Jan 2021 at 2:28pm<br /><br />We are down to considering the 195 and 196, and feel the 195 might be a better choice for teleworking if we need to do any from the road, but both the dinette and the sofa seem comfortable enough.]]>
   <pubDate>Sun, 03 Jan 2021 14:28:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139238#139238</guid>
   <title>Rpod196 Opinions : I went from a 172 to a 195 and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139237#139237</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 03 Jan 2021 at 12:28pm<br /><br />I went from a 172 to a 195 and it was amazing. At times I wish I had the couch instead of the dinette, but, I like having the dinette set as a bed, and my wife and I play games if it's raining or windy outside. The couch wouldn't work as good for that. I don't think you'll be unhappy either way.&nbsp;]]>
   <pubDate>Sun, 03 Jan 2021 12:28:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139237#139237</guid>
   <title>Rpod196 Opinions : Thanks, that&amp;#039;s what I was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139233#139233</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 03 Jan 2021 at 7:53am<br /><br />Thanks, that's what I was hoping to hear.]]>
   <pubDate>Sun, 03 Jan 2021 07:53:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139233#139233</guid>
   <title>Rpod196 Opinions : We have a 2021R-pod 196. We specifically...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139228#139228</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10813" rel="nofollow">Ricktoon</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 02 Jan 2021 at 10:47pm<br /><br /><div>We have a 2021R-pod 196. We specifically picked it for the sofa. Looking at the bathroom wall is a little strange, but we close the bathroom door and it works. The TV swings around so you can see it easily from the sofa. The two dump locations is no big deal. Dump the black, run the black tank flush until you see clear water, move the drain hose to the grey and on you go. <br></div><div><br></div>]]>
   <pubDate>Sat, 02 Jan 2021 22:47:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139228#139228</guid>
   <title>Rpod196 Opinions :  For those of you that actually...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139225#139225</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4397" rel="nofollow">Pete Brayton</a><br /><strong>Subject:</strong> 14329<br /><strong>Posted:</strong> 02 Jan 2021 at 8:22pm<br /><br />For those of you that actually own one, do you like it? Specifically, how do you like the sofa version and is it weird to be looking at the bathroom wall?&nbsp; How is viewing the television from the sofa? What about having two different grey and black water dump areas? Thanks for your input. I currently have a 172.]]>
   <pubDate>Sat, 02 Jan 2021 20:22:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14329&amp;PID=139225#139225</guid>
