  <title>R-pod Owners Forum : Broken fresh water tank</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Broken fresh water tank</description>
  <pubDate>Sun, 25 Oct 2026 18:24:53 +0000</pubDate>
  <lastBuildDate>Sat, 26 Dec 2020 14:42:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14317</WebWizForums:feedURL>
   <title>Broken fresh water tank : If it is the tank to fitting joint...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139148#139148</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14317<br /><strong>Posted:</strong> 26 Dec 2020 at 2:42pm<br /><br />If it is the tank to fitting joint that has been torn loose, and not the fitting itself (which could be easier to repair), then you could try West Systems gflex epoxy. I did this to repair a polyethylene kayak and it worked, but it will take some luck.&nbsp; You need to flame treat the polyethylene surface first to get decent adhesion. See attached for adhesion data. Also, any cracks need to be stop drilled first.&nbsp;<div><br></div><div>&nbsp;https://www.westsystem.com/specialty-epoxies/gflex-epoxy-adhesion-data/</div><div><br></div><div>You could also try carefully drilling out a nice clean hole and using a rubber expansion plug to seal it. Another long shot but it might work.&nbsp; You don't need the drain to be there, you can use the pump suction fitting to drain the tank. Something like this:</div><div><br></div><div><div>https://www.envirodesignproducts.com/products/cherne-1-1-2-sure-grip-plug?variant=12330564518006</div><div><br></div><div>What year is your rPod and is it an East Coast or West Coast version? The earlier Eastern ones were pretty low to the ground. If you have one of those I'd suggest getting a riser kit for the trailer so you don't have the problem again.&nbsp;</div><div><br></div></div>]]>
   <pubDate>Sat, 26 Dec 2020 14:42:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139148#139148</guid>
   <title>Broken fresh water tank :  Polyethylene is normally heat...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139147#139147</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9899" rel="nofollow">Colt</a><br /><strong>Subject:</strong> 14317<br /><strong>Posted:</strong> 26 Dec 2020 at 2:00pm<br /><br /><div>Polyethylene is normally heat welded. &nbsp; You might find someone who could weld it ultrasonically.&nbsp; <br></div><div><br></div><div>Amazon would make you think a new tank might not be expensive, but contact Forest River or your dealer first.&nbsp; <br></div><div><br></div><div>At least in concept, you could *soften* both the tank and the drain surfaces at the break with 2 heat guns or propane torches and force them back together while they are very soft.&nbsp; Be sure the force is even and a little poly extrused from the weld surface.&nbsp; Hold in place until it cools a little.&nbsp; Don't set anything on fire!&nbsp; This is how polyethylene pipe is welded.&nbsp; <br></div><div><br></div><div><img src="https://www.twi-global.com/images/00014/9683.jpg" border="0" /></div><div><br></div><div>At this point you don't have much to lose.&nbsp; <br></div>]]>
   <pubDate>Sat, 26 Dec 2020 14:00:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139147#139147</guid>
   <title>Broken fresh water tank : Did it rip the drain out of the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139146#139146</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14317<br /><strong>Posted:</strong> 26 Dec 2020 at 12:46pm<br /><br />Did it rip the drain out of the tank itself or shear it off? Its difficult to get anything to adhere well to the tank material which is low density polyethylene. Maybe if you took a picture or two and posted them it would if anyone has any ideas.&nbsp;]]>
   <pubDate>Sat, 26 Dec 2020 12:46:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139146#139146</guid>
   <title>Broken fresh water tank : It looks like I went over a speed...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139145#139145</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8972" rel="nofollow">Psychokitsune</a><br /><strong>Subject:</strong> 14317<br /><strong>Posted:</strong> 26 Dec 2020 at 11:24am<br /><br />It looks like I went over a speed bump that was just a little too high. It ripped off the drain point of my fresh water tank. I still have the piece that got taken off but I have no idea how to re-attach it and still maintain the integrity of the tank so it doesn't leak water.<br /><br />Any ideas?]]>
   <pubDate>Sat, 26 Dec 2020 11:24:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14317&amp;PID=139145#139145</guid>
