  <title>R-pod Owners Forum : E2 trunnion vs round bar</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : E2 trunnion vs round bar</description>
  <pubDate>Thu, 29 Oct 2026 12:40:29 +0000</pubDate>
  <lastBuildDate>Sat, 26 Dec 2020 11:20:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14314</WebWizForums:feedURL>
   <title>E2 trunnion vs round bar : We have the round bar version....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139144#139144</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 14314<br /><strong>Posted:</strong> 26 Dec 2020 at 11:20am<br /><br />We have the round bar version. It works well on our F150, but the extra inch or so of clearance would be nice when you're on rough terrain.<div><br></div>]]>
   <pubDate>Sat, 26 Dec 2020 11:20:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139144#139144</guid>
   <title>E2 trunnion vs round bar : I have the E2 trunnion style and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139138#139138</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 14314<br /><strong>Posted:</strong> 26 Dec 2020 at 8:20am<br /><br />I have the E2 trunnion style and like it.&nbsp; The sway control works well and the system is easy to hookup.&nbsp; I am pulling a 179 with a Pathfinder so your set up with a F150 will give you more than enough capabilities.&nbsp; The ground clearance is less with the round bar system and it depends on just where you plan on going (off road in BLMs).&nbsp; But with the hitch being the limiting factor you are giving yourself a prewarning of ground clearance problems with the trailer like black and gray water tank lines and the stabilizing jacks.<div><br></div><div>Hope this helps and have fun with your 180.</div>]]>
   <pubDate>Sat, 26 Dec 2020 08:20:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139138#139138</guid>
   <title>E2 trunnion vs round bar : Not new to towing ( goose neck/...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139130#139130</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=11038" rel="nofollow">deanj</a><br /><strong>Subject:</strong> 14314<br /><strong>Posted:</strong> 25 Dec 2020 at 1:50pm<br /><br />Not new to towing ( goose neck/ 5th wheel ) but new to bumper pull travel trailers. Just ordered a 180. The tow vehicle will be a 2019 F150, V8 tow package. I think I will be using the E2 wdh 6000/600. My question is what is preferable trunnion or round bar? I understand the clearance is better with the trunnion style but is it necessary with my set up? Thanks in advance]]>
   <pubDate>Fri, 25 Dec 2020 13:50:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14314&amp;PID=139130#139130</guid>
