  <title>R-pod Owners Forum : Rpod wall material</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Reviews and General Information : Rpod wall material</description>
  <pubDate>Fri, 23 Oct 2026 04:54:19 +0000</pubDate>
  <lastBuildDate>Sat, 05 Dec 2020 09:05:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14257</WebWizForums:feedURL>
   <title>Rpod wall material :   Originally posted by rpod190 i...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138721#138721</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14257<br /><strong>Posted:</strong> 05 Dec 2020 at 9:05am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by rpod190</strong></em><br /><br /><div>i added a deck access hatch to reach the water pump and I hd to cut a hole. Looks like the walls and steel frame and foam composite. No wood found although the Styrofoam can mold if it gets wet so stay up on your lap sealant checks. If your adding a cover access the wall size is 1.25inches.</div><div><br></div></td></tr></table><div>Some misinformation here. The inner layer of the outer walls is plywood and the structure is aluminum, not steel. The foam is closed cell so it won't absorb water, but water can saturate the plywood and compromise the adhesion of the wall lamination. Here is a construction video to showing the wall assembly.</div><div><br></div><div><a href="https://www.youtube.com/watch?v=vMXneKc_fDo" target="_blank">https://www.youtube.com/watch?v=vMXneKc_fDo</a><br></div>]]>
   <pubDate>Sat, 05 Dec 2020 09:05:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138721#138721</guid>
   <title>Rpod wall material : Thanks for the info. How are you...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138698#138698</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9043" rel="nofollow">Dirt Sifter</a><br /><strong>Subject:</strong> 14257<br /><strong>Posted:</strong> 03 Dec 2020 at 5:36pm<br /><br />Thanks for the info. How are you covering the access hatch? (Pictures please)<br>]]>
   <pubDate>Thu, 03 Dec 2020 17:36:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138698#138698</guid>
   <title>Rpod wall material :  i added a deck access hatch...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138692#138692</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9268" rel="nofollow">rpod190</a><br /><strong>Subject:</strong> 14257<br /><strong>Posted:</strong> 03 Dec 2020 at 2:54pm<br /><br /><div>i added a deck access hatch to reach the water pump and I hd to cut a hole. Looks like the walls and steel frame and foam composite. No wood found although the Styrofoam can mold if it gets wet so stay up on your lap sealant checks. If your adding a cover access the wall size is 1.25inches.<br></div><div><br></div><div><img src="uploads/9268/IMG_3430.JPG" height="300" width="300" border="0" /><br></div><div><img src="uploads/9268/IMG_3431.JPG" height="300" width="300" border="0" /><br></div><div><img src="uploads/9268/IMG_3366.JPG" height="300" width="300" border="0" /><br></div><div><br></div>]]>
   <pubDate>Thu, 03 Dec 2020 14:54:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14257&amp;PID=138692#138692</guid>
