  <title>R-pod Owners Forum : Castle Rock ST 225/75/15 replacement</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Castle Rock ST 225/75/15 replacement</description>
  <pubDate>Sun, 25 Oct 2026 17:03:09 +0000</pubDate>
  <lastBuildDate>Wed, 11 Nov 2020 15:51:42 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14204</WebWizForums:feedURL>
   <title>Castle Rock ST 225/75/15 replacement : The wheels can handle the tire...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138222#138222</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 3:51pm<br /><br />The wheels can handle the tire pressures of any of the load ranges.<div><br></div><div>&nbsp;I suggest taking a look at the actual load weight specs on the tires you're thinking about getting. Multiply by 2 to get the axle total. Divide by the axle rating (3500 lbs for the mid size rpods, 4400 lbs for the bigger ones). That number should be around 1.25 to 1.5 or so, giving your tires a 25-50% safety factor. A low safety factor will increase the risk of tire failure, too high will increase stiffness too much and result in excessive shaking and vibration.&nbsp;</div><div><br></div><div>And keep the tires inflated to specs, if they are underinflated they flex more and get hotter.&nbsp; Trailer tires have thicker sidewalls than car or truck tires, so they dissipate heat more slowly, so they are more prone to failure if underinflated than car or truck tires. But, because they flex less they have less rolling resistance so you'll get better fuel economy.&nbsp;</div><div><br></div><div>Many complaints about "Chinese tires" are really incorrect user maintenance resulting in underinflation, combined with marginally spec'd OEM tires to begin with</div>]]>
   <pubDate>Wed, 11 Nov 2020 15:51:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138222#138222</guid>
   <title>Castle Rock ST 225/75/15 replacement : +1 - the new Pod, the big ones...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138206#138206</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 10:38am<br /><br />+1 - the new Pod, the big ones can handle E rates.]]>
   <pubDate>Wed, 11 Nov 2020 10:38:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138206#138206</guid>
   <title>Castle Rock ST 225/75/15 replacement : I have Load range E Carlisle tires....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138202#138202</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 10:05am<br /><br />I have Load range E Carlisle tires. There is a wide margin of difference between the smallest, and the largest pod&nbsp; model. To make a blanket statement of what should be used is inaccurate.&nbsp; The bigger pods (195,196,192,193) should probably have load range E tires. They do call for 80 psi and I have had nothing but carlisle tires over the last 5 years, with zero issues.&nbsp;]]>
   <pubDate>Wed, 11 Nov 2020 10:05:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138202#138202</guid>
   <title>Castle Rock ST 225/75/15 replacement : The D load range tires have a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138200#138200</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 7:37am<br /><br />The D load range tires have a cold 65 psi requirement and the trailer's rims will handle those tires/pressure, the E load range tires have a 80 ish psi requirement.&nbsp; I think that the load range E tires are overkill for the Pods]]>
   <pubDate>Wed, 11 Nov 2020 07:37:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138200#138200</guid>
   <title>Castle Rock ST 225/75/15 replacement : This may be a dumb question? But...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138198#138198</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10816" rel="nofollow">Colonel Podder</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 6:12am<br /><br />This may be a dumb question? But will the r-pod wheels handle the D rated tires that run at higher pressure? I believe they run at 80psi cold?<div><br></div><div>I like the idea of having the additional weight handling capability for more of a safety margin.&nbsp;</div>]]>
   <pubDate>Wed, 11 Nov 2020 06:12:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138198#138198</guid>
   <title>Castle Rock ST 225/75/15 replacement : Looking forward to that day. Our...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138197#138197</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 11 Nov 2020 at 5:18am<br /><br />Looking forward to that day.&nbsp; Our original set were "Tire King" (china) on our 177 that was purchased January 2011.&nbsp; Never checked to see how new the tires were, found out when they were replaced in 2015 that they were built early 2009 which made them 7 years old!&nbsp; Purchased a set of Hartland's from Tire Factory (also china) then and although they have performed well over the past 5.5 years have noted that there is a lot of "bounce" as we travel, especially on back unpaved roads or poorly paved, bumpy roads.&nbsp; They both were "C" rated.&nbsp; Next spring the change will be to go with Carlisle "D".<br>]]>
   <pubDate>Wed, 11 Nov 2020 05:18:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138197#138197</guid>
   <title>Castle Rock ST 225/75/15 replacement : We originally replaced our tires...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138194#138194</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 10 Nov 2020 at 10:02pm<br /><br /><div>We originally replaced our tires with Maxxiis 8008. Later, we found Goodyear Endurance.&nbsp; We love the Endurance tires. they seem much stiffer so the trailer does not bounce as much.&nbsp; They do not leak-I check the pressures frequently and seldom need to add any air.&nbsp; <br></div><div>&nbsp;a lot of podders like Carlisle.&nbsp; I can't speak from personal experience.</div><div>whatever tires you get&nbsp; is your choice.&nbsp; However, in any event you should get them balanced. it makes a lot of difference. Agree with McCarter-get the load range D<br></div><div>Vann<br></div>]]>
   <pubDate>Tue, 10 Nov 2020 22:02:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138194#138194</guid>
   <title>Castle Rock ST 225/75/15 replacement : Go with the load rate D. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138183#138183</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 10 Nov 2020 at 4:34pm<br /><br />Go with the load rate D.]]>
   <pubDate>Tue, 10 Nov 2020 16:34:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138183#138183</guid>
   <title>Castle Rock ST 225/75/15 replacement : THE Carlisle STs and the Goodyear...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138182#138182</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 10 Nov 2020 at 4:19pm<br /><br />THE Carlisle STs and the Goodyear Endurance are very popular replacement tires.]]>
   <pubDate>Tue, 10 Nov 2020 16:19:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138182#138182</guid>
   <title>Castle Rock ST 225/75/15 replacement : Had a tire separate with less...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138175#138175</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10689" rel="nofollow">Austinrpod</a><br /><strong>Subject:</strong> 14204<br /><strong>Posted:</strong> 10 Nov 2020 at 2:22pm<br /><br />Had a tire separate with less than 10K miles.&nbsp; Has anyone replaced with Goodyear Endurance tires?<div>Thanks</div>]]>
   <pubDate>Tue, 10 Nov 2020 14:22:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14204&amp;PID=138175#138175</guid>
