  <title>R-pod Owners Forum : First time R-Pod owner needing some help</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Introduce Yourself : First time R-Pod owner needing some help</description>
  <pubDate>Wed, 23 Sep 2026 21:22:30 +0000</pubDate>
  <lastBuildDate>Fri, 11 Dec 2020 21:18:47 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14171</WebWizForums:feedURL>
   <title>First time R-Pod owner needing some help : +1 to mjlrpodgrease the hitch/bar...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138880#138880</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 9:18pm<br /><br /><div>+1 to mjlrpod</div><div>grease the hitch/bar connection but not the bar to l bracket connection</div><div>making noise lets you know it is working properly<br></div><div>Vann</div><div>note-I also use a lithium spray lube on the trailer ball prior to hooking up<br></div>]]>
   <pubDate>Fri, 11 Dec 2020 21:18:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138880#138880</guid>
   <title>First time R-Pod owner needing some help : I grease the hitch connections,...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138868#138868</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 2:37pm<br /><br />I grease the hitch connections, but never the the slide plates that the spring bars ride on. Greasing that would defeat the sway control. Not very many things are recommended that you let dry metal rub together, but the spring bars are one thing that is.&nbsp;<div><br></div>]]>
   <pubDate>Fri, 11 Dec 2020 14:37:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138868#138868</guid>
   <title>First time R-Pod owner needing some help : Quick question. When my WDH was...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138866#138866</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10813" rel="nofollow">Ricktoon</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 12:34pm<br /><br />Quick question. When my WDH was installed the dealer said not to lubricate the joints, particularly where the bars attach to the trailer frame. However, the manual says to put grease on the joints where the bars connect to the hitch itself. This would allow them to move freely in and out when attaching and detaching. What do you recommend for lubricating the WDH.<br>]]>
   <pubDate>Fri, 11 Dec 2020 12:34:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138866#138866</guid>
   <title>First time R-Pod owner needing some help : +1That&amp;#039;s the way we do it....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138865#138865</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 11:37am<br /><br />+1<div>That's the way we do it. Crank up the connected combo far enough, and the spring bars just swing into position. No pry bar needed. We do the same thing when we disconnect.</div>]]>
   <pubDate>Fri, 11 Dec 2020 11:37:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138865#138865</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by offgridReleasing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138862#138862</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 10:38am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />Releasing the energy stored in the wdh bar tension can be intimidating, there is of necessity hundreds of lbs of force there. Best thing is to reverse the hitching up process, first crank up the Jack with the ball still in to relieve most of the tension, release the bars, then crank down, release the hitch, then back up to pull away.  Takes slightly longer but it’s safer and less stressful.</td></tr></table><div><br></div><div>And the opposite way to hitch up. First lower onto the ball and lock it on, then raise the jack a few inches, lifting the back end of the tow vehicle. Installing the spring bars will require no effort at all if you raised it enough.&nbsp; This also proves that you are completely connected to the tow vehicle as well. Don't want to find out the hard way you weren't actually clamped to the ball.&nbsp;</div>]]>
   <pubDate>Fri, 11 Dec 2020 10:38:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138862#138862</guid>
   <title>First time R-Pod owner needing some help : Releasing the energy stored in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138853#138853</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 11 Dec 2020 at 8:27am<br /><br />Releasing the energy stored in the wdh bar tension can be intimidating, there is of necessity hundreds of lbs of force there. Best thing is to reverse the hitching up process, first crank up the Jack with the ball still in to relieve most of the tension, release the bars, then crank down, release the hitch, then back up to pull away.  Takes slightly longer but it’s safer and less stressful. ]]>
   <pubDate>Fri, 11 Dec 2020 08:27:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138853#138853</guid>
   <title>First time R-Pod owner needing some help : Thank you EchoGale for your response...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138845#138845</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 12:13pm<br /><br />Thank you EchoGale for your response and the link to the You-Tube video.&nbsp; I appreciate it! As I said to offgrid....I can't wait until I have done it enough times that I am not intimidated by it.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Thu, 10 Dec 2020 12:13:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138845#138845</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by EchoGaleLike...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138844#138844</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 12:10pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by EchoGale</strong></em><br /><br />Like you, I've been the beneficiary of offgrid's wisdom many times here.&nbsp; :)&nbsp;&nbsp;<div><br></div><div>In the meantime, I've also learned a lot on youtube (and often its helpful too see the explanation.) Here's one video, I think, on your WDH&nbsp;&nbsp;https://youtu.be/d8ZRiJ-8i7w</div><div><br></div><div><br></div></td></tr></table>]]>
   <pubDate>Thu, 10 Dec 2020 12:10:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138844#138844</guid>
   <title>First time R-Pod owner needing some help : Thank you so much offgrid for...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138843#138843</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 12:09pm<br /><br />Thank you so much offgrid for taking the time to reply!!&nbsp; I can't wait until I have done this enough times that it doesn't seem intimidating.&nbsp;&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Thu, 10 Dec 2020 12:09:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138843#138843</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by offgridI...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138842#138842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 12:07pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />I think I have the same hitch. Anyhow here’s what I do <br>Get your hitch parts out, clean off any grit form the mating surfaces and apply some grease.<br>Jack the trailer, back the TV, drop the hitch in the ball and connect. <br>Jack up again which will lift the Highlander and trailer a little. That will reduce the tension when you install the wdh bars.<br>Install a bar on the hitch. That seems a little awkward the first time, you have to start with the bar out about 90 degrees and rotated so the bottom of the bar hitch end drops into the hole, then the top, then swung the bar in. <br>Hook up the chain at the link you want to use (you’ll need to memorize and count links from now on).<br>Use the levering tube to rotate the chain attachment up and slide in the retaining clip.<br>Be sure that the loose chain is not blocking the chain from moving around in the chain attachment, which it will do when you turn.<br>Repeat for the other side.<br>Lower and stow jack. <br>Now attach the friction bar or bars. Thy can only go on one way, Pop the clips in and adjust the amount of friction you want with the levers.<br>Attach safety chains crisscrossed.<br>Attach breakaway cable, making sure it doesn’t drag and will pull the pin before the safety chains reach their full length.<br>Connect the 7 way making sure it doesn’t drag and doesn’t get hung up. Pull on it a bit to be sure it is properly latched in.<br>Done,<br><br></td></tr></table>]]>
   <pubDate>Thu, 10 Dec 2020 12:07:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138842#138842</guid>
   <title>First time R-Pod owner needing some help : Like you, I&amp;#039;ve been the beneficiary...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138837#138837</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9176" rel="nofollow">EchoGale</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 9:17am<br /><br />Like you, I've been the beneficiary of offgrid's wisdom many times here.&nbsp; :)&nbsp;&nbsp;<div><br></div><div>In the meantime, I've also learned a lot on youtube (and often its helpful too see the explanation.) Here's one video, I think, on your WDH&nbsp;&nbsp;https://youtu.be/d8ZRiJ-8i7w</div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 10 Dec 2020 09:17:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138837#138837</guid>
   <title>First time R-Pod owner needing some help : I think I have the same hitch....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138836#138836</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 9:12am<br /><br />I think I have the same hitch. Anyhow here’s what I do <br />Get your hitch parts out, clean off any grit form the mating surfaces and apply some grease.<br />Jack the trailer, back the TV, drop the hitch in the ball and connect. <br />Jack up again which will lift the Highlander and trailer a little. That will reduce the tension when you install the wdh bars.<br />Install a bar on the hitch. That seems a little awkward the first time, you have to start with the bar out about 90 degrees and rotated so the bottom of the bar hitch end drops into the hole, then the top, then swung the bar in. <br />Hook up the chain at the link you want to use (you’ll need to memorize and count links from now on).<br />Use the levering tube to rotate the chain attachment up and slide in the retaining clip.<br />Be sure that the loose chain is not blocking the chain from moving around in the chain attachment, which it will do when you turn.<br />Repeat for the other side.<br />Lower and stow jack. <br />Now attach the friction bar or bars. Thy can only go on one way, Pop the clips in and adjust the amount of friction you want with the levers.<br />Attach safety chains crisscrossed.<br />Attach breakaway cable, making sure it doesn’t drag and will pull the pin before the safety chains reach their full length.<br />Connect the 7 way making sure it doesn’t drag and doesn’t get hung up. Pull on it a bit to be sure it is properly latched in.<br />Done,<br /><br />]]>
   <pubDate>Thu, 10 Dec 2020 09:12:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138836#138836</guid>
   <title>First time R-Pod owner needing some help : Hi offgrid You gave me such helpful...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138832#138832</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 1:03am<br /><br />Hi offgrid&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />&nbsp; You gave me such helpful advice a month or so ago.&nbsp; I was wondering if you might be able to help me with connecting the WDH. You and I have the same tow vehicle (Highlander) and I believe you said that you also have the Pro Series WDH with sway control (49904?).&nbsp; I picked up my used R-Pod in Idaho and a very nice man at an RV place connected everything for me for my long 9 hour drive home.&nbsp; I haven't hooked up the R-Pod since I brought it home. I need to take it to the DMV to have the VIN verified.&nbsp; Would you be able to give me step-by-step instructions on how to connect everything so that I don't forget something?&nbsp; I would be so grateful!&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Thu, 10 Dec 2020 01:03:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138832#138832</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by offgrid  Originally...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138831#138831</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 10 Dec 2020 at 12:56am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by sbeninga</strong></em><br /><br />Thanks for the welcome!&nbsp;<div>When I purchased the R-Pod from a private party it came with the Pro Series weight distribution/sway bar hitch.&nbsp; I had a long drive home from central Idaho to northern California and it really made it feel more secure to tow.&nbsp; I rented an R-Pod 190 this summer to get a feel for it and the owner did not set me up with a weight distribution/anti-sway bar.&nbsp; I could tell the difference.&nbsp;&nbsp;<div>I pulled the mattress out and pulled the plywood up to look underneath.&nbsp; I got the pull-out outdoor kitchen removed.&nbsp; I just want to be able to put some clear tubs with extra clothes, shoes, lawn chair, etc. and other light items in this area.&nbsp;</div></div><div>I slept in the R-Pod during our PG&amp;E Public Safety Power Shutoff.&nbsp; It was handy to have for heat and also a shower in the morning.&nbsp; I notice a "creak?" in the plywood below while I slept.&nbsp; After pulling the mattress out above I now know where the creak came from.&nbsp; The larger piece of plywood is warped.&nbsp; I imagine I can get a new piece from Home Depot that is not warped and replace it.</div><div>Thanks for mentioning about the tires.&nbsp; I have done a lot of reading on this forum and I have seen that mentioned before.&nbsp; I just went out and took a picture of the tires.&nbsp; They are Westlake tires ST235/75R15, load range C&nbsp; 6PR CR857+.</div><div>Thanks again for your help!</div></td></tr></table><div><br></div><div>I have the same weight distribution hitch, works fine with my Highlander.</div><div><br></div><div>Yep, just get a replacement piece of plywood the same thickness, you might even just flip it over (if its symmetrical) and see if that works.&nbsp;&nbsp;</div><div><br></div><div>Re your tires, that is an oddball size not readily available, I think came on the west coast (HRE) version. I think one of our members was able to determine it is rated at 2340 lbs, which is not bad. So I think you can keep them for awhile, others might disagree. Do keep them inflated to the pressure listed on them, measured when cold. Check the pressure daily when travelling.&nbsp;</div><div><br></div><div>You might want to get an IR thermometer like this one, check the tire temps whenever you stop for gas, if one is getting a lot hotter than another that would be an early warming of possible tire failure. You can use it to be sure your trailer brakes are working evenly too if you check it after a few stops using your brake controller manual slide lever. If one brake is much cooler then its not doing its job.&nbsp;</div><div><br></div><div>https://www.amazon.com/Etekcity-Lasergrip-1080-Non-Contact-Thermometer/dp/B00DMI632G/ref=sr_1_5?dchild=1&amp;gclid=Cj0KCQjwreT8BRDTARIsAJLI0KKqfe9OP6TSPv5TF208b-kCFq5FlQLKWy-h3oiZryLYsIHxBCcaPtEaAjNWEALw_wcB&amp;hvadid=326607819484&amp;hvdev=c&amp;hvlocphy=9008704&amp;hvnetw=g&amp;hvqmt=b&amp;hvrand=9295544025922241191&amp;hvtargid=kwd-325254504195&amp;hydadcr=28545_10017593&amp;keywords=infrared+thermometer&amp;qid=1603930454&amp;sr=8-5&amp;tag=googhydr-20</div><div><br></div></td></tr></table>]]>
   <pubDate>Thu, 10 Dec 2020 00:56:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=138831#138831</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by offgridFor...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137880#137880</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 8:48pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by offgrid</strong></em><br /><br />For sure you should get the weight on each of the 3 axles. You can do that either by subtracting total rig weight having already got the weight on the TV’s axles or separately, your choice depending on how cooperative the person running the scale is.</td></tr></table><div><br></div><div>Thanks Offgrid for your additional comments!!&nbsp;</div>]]>
   <pubDate>Fri, 30 Oct 2020 20:48:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137880#137880</guid>
   <title>First time R-Pod owner needing some help : Thank you JR!! I appreciate your...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137879#137879</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 8:46pm<br /><br />Thank you JR!!&nbsp; I appreciate your comment!]]>
   <pubDate>Fri, 30 Oct 2020 20:46:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137879#137879</guid>
   <title>First time R-Pod owner needing some help : Awesome advice Vann!! Thanks so...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137878#137878</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 8:45pm<br /><br />Awesome advice Vann!! Thanks so much for that great information!!&nbsp; I appreciate it.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" />]]>
   <pubDate>Fri, 30 Oct 2020 20:45:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137878#137878</guid>
   <title>First time R-Pod owner needing some help : For sure you should get the weight...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137873#137873</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 6:29pm<br /><br />For sure you should get the weight on each of the 3 axles. You can do that either by subtracting total rig weight having already got the weight on the TV’s axles or separately, your choice depending on how cooperative the person running the scale is.]]>
   <pubDate>Fri, 30 Oct 2020 18:29:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137873#137873</guid>
   <title>First time R-Pod owner needing some help : I find it helpful to stop with...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137871#137871</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 6:22pm<br /><br />I find it helpful to stop with only the Pod's tires on the scale and get a 4th weight.&nbsp; Then you know just how much weight is on the Pod's axel.&nbsp; There has been a lot of concern talked about on the forum about overloading the Pod's axel.&nbsp; Each to their own though.]]>
   <pubDate>Fri, 30 Oct 2020 18:22:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137871#137871</guid>
   <title>First time R-Pod owner needing some help : +1 to Pod People.   You local...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137870#137870</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 6:20pm<br /><br />+1 to Pod People. <br /><br />You local waste transfer station is a great option. Go at a quiet time and ask nice, you can often get weighed for free especially if it’s county run not private. If you roll on the front axle and then the rear of the Highlander you can also check those loads too, the axle max loads should be on the door sticker.<br /><br />One other thing to check is the hitch weight as a percent of the total trailer weight. That should be 10% at the bare minimum to reduce sway risk, I try to keep mine around 12-14%, it varies with trailer loading, especially if you fill your water tank.,<br /><br />Leveling jacks are optional. If I’m just stopping for the night somewhere and want to get an early start I don’t use them. <br /><br />I have the same brake controller in my Highlander. You have to set the max braking level first using the parking lot brake method I described. Mine is set at max and I can’t lock my brakes up. Assuming it’s the same for you then boost level 2 is probably right for normal use, that’s what I generally use and it keeps the brake heat buildup about the same on all the wheels on a typical 8-10% mountain grade. If I have a really steep grade I sometimes use boost setting 3. ]]>
   <pubDate>Fri, 30 Oct 2020 18:20:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137870#137870</guid>
   <title>First time R-Pod owner needing some help : Welcome to the forum. Here are...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137863#137863</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 3:22pm<br /><br /><div>Welcome to the forum. Here are a couple of things to consider-</div><div>1-you do not have to use a CAT scale-it is usually at truck stops and a fee is charged.&nbsp; I used a free scale at our local land fill. you just need to load your pod and tow vehicle as you as going on a trip.&nbsp; start with the weight distribution hitch bars loosened and the pod hitched to the tow vehicle. Drive the tow vehicle with all 4 wheels onto the scale and note the weight of the tow vehicle.&nbsp; this is weight #1. then drive forward so that&nbsp; both the tow vehicle and pod are on the scale and note the weight. this is weight #2. then go somewhere close and drop off the pod. Return to the scale and weigh just the tow vehicle again. Note the weight.&nbsp; this is weight #3.<br></div><div>You have just weighed your rig.&nbsp; the first weight is the tow vehicle and tongue weight combined.&nbsp; the second weight is the combined gross combination weight of the tow vehicle and pod. The third weight is the tow vehicle itself without the pod or tongue weight of the pod.&nbsp; subtract the last weight(tow vehicle only) from the first weight(tow vehicle with tongue weight) and you will have the pod's tongue weight.&nbsp; subtract the last weight(tow vehicle alone) from the second weight(tow vehicle and pod) and you will have the pod weight.</div><div>2-you may or may not put down the stabilizers when stopping for a quick overnighter. the pod is still connected to the tow vehicle.&nbsp; If you don't put down the stabilizers, there will be some bouncing and swaying as you walk around inside the pod, but nothing bad will happen.&nbsp; Usually, I disconnect the power cord from the vehicle so as to not drain the tow vehicle battery. Otherwise, the pod is functional with it's own battery power and everything works except the AC and microwave.</div><div>good luck and safe travels</div><div>Vann<br></div><div><br></div>]]>
   <pubDate>Fri, 30 Oct 2020 15:22:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137863#137863</guid>
   <title>First time R-Pod owner needing some help : Thank you Offgrid for your great...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137860#137860</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 30 Oct 2020 at 1:41pm<br /><br />Thank you Offgrid for your great advice!!&nbsp; I appreciate it!&nbsp; Good to know that you think that the tires that are currently on my R-Pod are going to be ok.&nbsp; When I purchased the R-Pod in Idaho the weight distribution hitch needed to be adjusted one notch for my Highlander.&nbsp; Before leaving Idaho I found an RV place that adjusted the weight distribution/sway hitch for my vehicle.&nbsp; The gentleman that helped me used the 3rd link on the chain for my Highlander.<div>I like your explanation of measuring the height at the front axle.&nbsp; My driveway is gravel and it is not level where the trailer is parked.&nbsp; (I am going to try to get some work done on the driveway so that it is closer to level.&nbsp; I want to get some bamboo removed anyway so that I can move the R-Pod over further so that I can get my Highlander back under my carport style garage.) I also like the benefit of getting the weight distribution/sway hitch just right so that I can pull in somewhere for the night and not have to unhitch to sleep comfortably.&nbsp; I would imagine it would be good to put the stabilization jacks down too or not necessary??</div><div>I have a Tekonsha Prodigy P2 brake control on the Highlander. I believe it is currently set on "2" from when I rented an R-Pod a couple of months ago.&nbsp; The braking seemed fine on that level when I drove home from Idaho but perhaps I should have it at a different level?? I have used the sport mode to select a lower gear.&nbsp; Is using the cruise control while towing an absolute no-no?</div><div>I recently watched a John Marucci You-tube video about weighing my Highlander and R-Pod.&nbsp; Is it necessary and/or better to have it weighed at a CAT scale?&nbsp; The nearest CAT scale near me is quite a ways away.&nbsp; There is a local concrete/rental equipment business not far away that has a scale I could use but not sure how it compares to a "CAT" scale.&nbsp; I do want to have this all figured out before I travel again.</div><div>Thanks again!</div>]]>
   <pubDate>Fri, 30 Oct 2020 13:41:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137860#137860</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by sbeningait...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137794#137794</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 29 Oct 2020 at 5:23am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by sbeninga</strong></em><br /><br />it says on the tire "Load single 2340 lbs at 350 kPa (50 PSI) COLD" and&nbsp;"Load dual 2040 lbs at 350 kPa (50 PSI) COLD". I am thinking that means single axle vs dual axle??&nbsp;<div><span style=": rgb251, 251, 253;">&nbsp;</span></div></td></tr></table><div><br></div><div>A dual axle is one with 4 wheels on it. A tandem axle is two axles one right behind the other. Tires are derated for dual axle use because they run hotter and its not possible to keep the load on them exactly the same. In your case the 2340 lbs applies. Since you have a 3500 lb rated axle (1750 per wheel) your tires have a safety factor of 2340/1750=1.34 or 34%, which should be OK, just keep them inflated to 50 psi cold (meaning after the trailer has been sitting for a couple of hours). My original 14 inch tires were only rated for 1750 lbs, giving me no safety factor at all. not good.&nbsp;</div><div><br></div><div>You should take the time to learn and set up the weight distribution hitch yourself if you haven't done so. That's because they are often set up wrong for the way you end up loading the trailer.&nbsp; When you hang the trailer on the tow vehicle it lifts the front axle up. Read the instructions and you'll see that the purpose of the wdh is to return the load on the front axle of the TV back to where it was before hitching up the trailer. Its not to make the tow vehicle "look level" as some folks seem to think.&nbsp;</div><div><br></div><div>So, get the trailer and TV loaded up, find a perfectly level parking lot, bring some painter's tape and a tape measure. Give yourself a couple of hours the first time so you're not feeling rushed.&nbsp; Put a little strip of painter's tape on your front fenders right above the front axle so you have a nice line to measure to. Unhitch the trailer and measure the height at the front axle. Then hitch up and adjust the wdh bar tension so that you get back to the same height you started with, or as close as you can. The Highlander will still be sitting lower in the rear than without the trailer, that's OK.&nbsp;</div><div><br></div><div>The trailer should also be level at that point, you might need to adjust the hitch height and/or angle to achieve that, then redo the tension adjustment. Getting the trailer level is important both for towing but also so you can pull in somewhere for the night and not have to unhitch to sleep comfortably. Once you have things set up you shouldn't need to do it again unless you change your loading significantly.</div><div><br></div><div>While you're loaded up in the nice big parking lot check your brake controller adjustment too. The controller max braking level should be set so that when you stop from 15-20 mph using just the trailer brakes (use you manual control on full) the trailer wheels almost lock up, but not quite. If they lock up then your emergency braking action is actually reduced. Many of us find that the rPod brakes are pretty weak and won't lock up even at full controller output, in which case you can leave the controller set on full.&nbsp;</div><div><br></div><div>Your trailer brakes are now set to give you max effectiveness in an emergency stop. The second adjustment (called boost level on my controller) sets how much braking they do under normal conditions. That is a personal choice. What I do is drive down a winding grade using mostly engine braking (I use sport mode to select a lower gear) but some wheel braking too. Then I use my trusty ir thermometer and check the temps of all 6 brakes.&nbsp; If the Highlander brakes are a lot hotter than the trailer brakes then I increase the boost, if cooler than I decrease the boost. I'm trying to get all the brakes sharing the job as equally as I can.&nbsp;</div><div><br></div><div>One more thing I highly recommend you do is weigh your rig fully loaded for travel. Most everyone is surprised how heavy things get, especially the tongue weight. You can do that at a public scale. If you roll one axle at a time on the scale you can get the weight on each axle by subtraction. Leave the wdh untensioned when you weigh so it doesn't throw off the numbers.&nbsp;</div><div><br></div><div>If you then drop the trailer off and weigh the TV by itself you can get the trailer weight by subtracting the second from the first weighing, and the tongue weight by subtracting to weight of the TV by itself from the weight of the TV's 2 axles from the first weighing. Then you can compare all the weights against the TV specs in the manual, the driver's door sill, and the trailer weight sticker to be sure you're within safe limits. In my case I had to readjust to get the tongue weight down to 500 lbs which is the Highlander's max. Like with the brake controller and wdh, you only need to do this once unless you make major changes, but its well worth it to understand and know that everything is safe and working as it should.&nbsp;</div><div><br></div><div><br></div><div><br></div>]]>
   <pubDate>Thu, 29 Oct 2020 05:23:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137794#137794</guid>
   <title>First time R-Pod owner needing some help : Thanks Offgrid......Glad to hear...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137793#137793</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 11:52pm<br /><br />Thanks Offgrid......Glad to hear that you&nbsp;<span style=": rgb251, 251, 253;">have the same weight distribution hitch and that it works fine with your Highlander.&nbsp;</span><div><span style=": rgb251, 251, 253;">The R-Pod that I bought is the HRE Hood River Edition. I'm certainly not as knowledgeable as I should be on tires......it says on the tire "Load single 2340 lbs at 350 kPa (50 PSI) COLD" and&nbsp;</span><span style=": rgb251, 251, 253;">"Load dual 2040 lbs at 350 kPa (50 PSI) COLD". I am thinking that means single axle vs dual axle?? Thanks for your comments regarding the tires.</span></div><div><span style=": rgb251, 251, 253;">Thanks also for your suggestion about getting the IR thermometer.&nbsp; I appreciate any advice!</span></div><div><span style=": rgb251, 251, 253;">&nbsp;</span></div>]]>
   <pubDate>Wed, 28 Oct 2020 23:52:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137793#137793</guid>
   <title>First time R-Pod owner needing some help :   Originally posted by sbeningaThanks...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137788#137788</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 7:19pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by sbeninga</strong></em><br /><br />Thanks for the welcome!&nbsp;<div>When I purchased the R-Pod from a private party it came with the Pro Series weight distribution/sway bar hitch.&nbsp; I had a long drive home from central Idaho to northern California and it really made it feel more secure to tow.&nbsp; I rented an R-Pod 190 this summer to get a feel for it and the owner did not set me up with a weight distribution/anti-sway bar.&nbsp; I could tell the difference.&nbsp;&nbsp;<div>I pulled the mattress out and pulled the plywood up to look underneath.&nbsp; I got the pull-out outdoor kitchen removed.&nbsp; I just want to be able to put some clear tubs with extra clothes, shoes, lawn chair, etc. and other light items in this area.&nbsp;</div></div><div>I slept in the R-Pod during our PG&amp;E Public Safety Power Shutoff.&nbsp; It was handy to have for heat and also a shower in the morning.&nbsp; I notice a "creak?" in the plywood below while I slept.&nbsp; After pulling the mattress out above I now know where the creak came from.&nbsp; The larger piece of plywood is warped.&nbsp; I imagine I can get a new piece from Home Depot that is not warped and replace it.</div><div>Thanks for mentioning about the tires.&nbsp; I have done a lot of reading on this forum and I have seen that mentioned before.&nbsp; I just went out and took a picture of the tires.&nbsp; They are Westlake tires ST235/75R15, load range C&nbsp; 6PR CR857+.</div><div>Thanks again for your help!</div></td></tr></table><div><br></div><div>I have the same weight distribution hitch, works fine with my Highlander.</div><div><br></div><div>Yep, just get a replacement piece of plywood the same thickness, you might even just flip it over (if its symmetrical) and see if that works.&nbsp;&nbsp;</div><div><br></div><div>Re your tires, that is an oddball size not readily available, I think came on the west coast (HRE) version. I think one of our members was able to determine it is rated at 2340 lbs, which is not bad. So I think you can keep them for awhile, others might disagree. Do keep them inflated to the pressure listed on them, measured when cold. Check the pressure daily when travelling.&nbsp;</div><div><br></div><div>You might want to get an IR thermometer like this one, check the tire temps whenever you stop for gas, if one is getting a lot hotter than another that would be an early warming of possible tire failure. You can use it to be sure your trailer brakes are working evenly too if you check it after a few stops using your brake controller manual slide lever. If one brake is much cooler then its not doing its job.&nbsp;</div><div><br></div><div>https://www.amazon.com/Etekcity-Lasergrip-1080-Non-Contact-Thermometer/dp/B00DMI632G/ref=sr_1_5?dchild=1&amp;gclid=Cj0KCQjwreT8BRDTARIsAJLI0KKqfe9OP6TSPv5TF208b-kCFq5FlQLKWy-h3oiZryLYsIHxBCcaPtEaAjNWEALw_wcB&amp;hvadid=326607819484&amp;hvdev=c&amp;hvlocphy=9008704&amp;hvnetw=g&amp;hvqmt=b&amp;hvrand=9295544025922241191&amp;hvtargid=kwd-325254504195&amp;hydadcr=28545_10017593&amp;keywords=infrared+thermometer&amp;qid=1603930454&amp;sr=8-5&amp;tag=googhydr-20</div><div><br></div>]]>
   <pubDate>Wed, 28 Oct 2020 19:19:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137788#137788</guid>
   <title>First time R-Pod owner needing some help : Thanks for the welcome!When I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137781#137781</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 6:45pm<br /><br />Thanks for the welcome!&nbsp;<div>When I purchased the R-Pod from a private party it came with the Pro Series weight distribution/sway bar hitch.&nbsp; I had a long drive home from central Idaho to northern California and it really made it feel more secure to tow.&nbsp; I rented an R-Pod 190 this summer to get a feel for it and the owner did not set me up with a weight distribution/anti-sway bar.&nbsp; I could tell the difference.&nbsp;&nbsp;<div>I pulled the mattress out and pulled the plywood up to look underneath.&nbsp; I got the pull-out outdoor kitchen removed.&nbsp; I just want to be able to put some clear tubs with extra clothes, shoes, lawn chair, etc. and other light items in this area.&nbsp;</div></div><div>I slept in the R-Pod during our PG&amp;E Public Safety Power Shutoff.&nbsp; It was handy to have for heat and also a shower in the morning.&nbsp; I notice a "creak?" in the plywood below while I slept.&nbsp; After pulling the mattress out above I now know where the creak came from.&nbsp; The larger piece of plywood is warped.&nbsp; I imagine I can get a new piece from Home Depot that is not warped and replace it.</div><div>Thanks for mentioning about the tires.&nbsp; I have done a lot of reading on this forum and I have seen that mentioned before.&nbsp; I just went out and took a picture of the tires.&nbsp; They are Westlake tires ST235/75R15, load range C&nbsp; 6PR CR857+.</div><div>Thanks again for your help!</div>]]>
   <pubDate>Wed, 28 Oct 2020 18:45:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137781#137781</guid>
   <title>First time R-Pod owner needing some help : If it&amp;#039;s like mine, it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137774#137774</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 4:21pm<br /><br />If it's like mine, it's simple to remove. There is a slide bolt, like on a closet door, that you unlock, and then just pull it out.]]>
   <pubDate>Wed, 28 Oct 2020 16:21:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137774#137774</guid>
   <title>First time R-Pod owner needing some help : Welcome! Don&amp;#039;t know about...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137773#137773</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 4:15pm<br /><br />Welcome!&nbsp; Don't know about the outdoor kitchen but since we have basically the same tow vehicles, my recommendation&nbsp; is that you get a weight distribution hitch and sway control for your Highlander if you haven't already, You will find the towing much more enjoyable for a long trip like that.&nbsp;&nbsp;<div><br></div><div>I know you want more storage but you would be better off placing anything heavy in the Highlander, as far forward as possible. Just behind the front seats is ideal. The lighter you travel the more pleasant and safer the drive will be.&nbsp;<br><div><br></div><div>You also might want to consider getting upgraded tires, the OEM ones are pretty marginal. Trailer tires have load ranges, most folks here would probably recommend load range D tires for that trailer. The OEM ones are generally load range C, check the tire labels to be sure what you have.&nbsp;</div><div><br></div><div>Enjoy your trip!</div></div>]]>
   <pubDate>Wed, 28 Oct 2020 16:15:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137773#137773</guid>
   <title>First time R-Pod owner needing some help :  Hi everyoneI just purchased...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137772#137772</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9957" rel="nofollow">sbeninga</a><br /><strong>Subject:</strong> 14171<br /><strong>Posted:</strong> 28 Oct 2020 at 3:54pm<br /><br /><span style=": rgb251, 251, 253;">Hi everyone&nbsp;</span><img src="http://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><span style=": rgb251, 251, 253;">&nbsp;I just purchased a barely used 2019 R-Pod 190.&nbsp; I am towing it with a 2017 Toyota Highlander V6 AWD with the tow package.&nbsp; My plans are to travel&nbsp;from northern California down to Arizona (probably in mid-February) and meet up with a good friend of mine.&nbsp; She sold her house in this area a year ago and bought a brand new 24 foot RV.&nbsp; I plan to follow her to the southern coast and probably to Florida for a few months.&nbsp; Since I plan on traveling away from home for long periods of time and exploring the country I really need all the storage I can get.&nbsp; Because of that need for storage I want to temporarily remove the outdoor kitchen.&nbsp; It probably isn't that hard but does anyone have any tips on removing the outdoor kitchen on this model?</span><div style=": rgb251, 251, 253;">Thanks for any help!</div><div style=": rgb251, 251, 253;"><br></div>]]>
   <pubDate>Wed, 28 Oct 2020 15:54:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14171&amp;PID=137772#137772</guid>
