  <title>R-pod Owners Forum : RP189 Leak in closet</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : RP189 Leak in closet</description>
  <pubDate>Sun, 25 Oct 2026 17:00:16 +0000</pubDate>
  <lastBuildDate>Tue, 27 Oct 2020 17:06:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14166</WebWizForums:feedURL>
   <title>RP189 Leak in closet : To my knowledge there is no eternabond...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137730#137730</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14166<br /><strong>Posted:</strong> 27 Oct 2020 at 5:06pm<br /><br />To my knowledge there is no eternabond tape on a trailer from OEM.]]>
   <pubDate>Tue, 27 Oct 2020 17:06:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137730#137730</guid>
   <title>RP189 Leak in closet : I looked at the top of the slide...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137720#137720</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10795" rel="nofollow">pedwards2932</a><br /><strong>Subject:</strong> 14166<br /><strong>Posted:</strong> 27 Oct 2020 at 11:44am<br /><br />I looked at the top of the slide out and it looks like they used eternabond tape along the top outer edge.&nbsp; Where the screws are the tape isn't bonded tightly.&nbsp; I am guessing I need to get some 2" eternabond and reseal?&nbsp; Is that the original factory method for sealing the top outer edge?]]>
   <pubDate>Tue, 27 Oct 2020 11:44:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137720#137720</guid>
   <title>RP189 Leak in closet : The closet that is in the slide...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137719#137719</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10795" rel="nofollow">pedwards2932</a><br /><strong>Subject:</strong> 14166<br /><strong>Posted:</strong> 27 Oct 2020 at 11:30am<br /><br />The closet that is in the slide out has a water leak that has damaged the wood trim at the bottom edge.&nbsp; I am guessing that I need to reseal the top portion of the pull out?&nbsp; Has anyone run into this issue?&nbsp; I only noticed it while I was making a shelf for the closet so I don't know how long it has been going on.&nbsp; The damaged trim appears to be some sort of manufactored wood so it doesn't take much water to make it go soft.]]>
   <pubDate>Tue, 27 Oct 2020 11:30:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14166&amp;PID=137719#137719</guid>
