  <title>R-pod Owners Forum : RPod 178 Mystery Button - Second Owner</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : RPod 178 Mystery Button - Second Owner</description>
  <pubDate>Sun, 25 Oct 2026 18:24:37 +0000</pubDate>
  <lastBuildDate>Tue, 24 Nov 2020 16:48:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14106</WebWizForums:feedURL>
   <title>RPod 178 Mystery Button - Second Owner : Put a LED bulb in it. </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138504#138504</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 24 Nov 2020 at 4:48pm<br /><br />Put a LED bulb in it.]]>
   <pubDate>Tue, 24 Nov 2020 16:48:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138504#138504</guid>
   <title>RPod 178 Mystery Button - Second Owner : It feels like you&amp;#039;re going...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138495#138495</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9176" rel="nofollow">EchoGale</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 24 Nov 2020 at 9:15am<br /><br />It feels like you're going to break it but it does pop off.&nbsp;]]>
   <pubDate>Tue, 24 Nov 2020 09:15:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138495#138495</guid>
   <title>RPod 178 Mystery Button - Second Owner : Thanks! </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138494#138494</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10935" rel="nofollow">Ctvmotors</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 24 Nov 2020 at 8:45am<br /><br />Thanks!&nbsp;]]>
   <pubDate>Tue, 24 Nov 2020 08:45:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138494#138494</guid>
   <title>RPod 178 Mystery Button - Second Owner : Should be quite simple with a...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138490#138490</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1146" rel="nofollow">jato</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 24 Nov 2020 at 6:45am<br /><br />Should be quite simple with a flat screwdriver put the blade in at the bottom of the lens, slightly twist the blade and the lens will pop off.<br>]]>
   <pubDate>Tue, 24 Nov 2020 06:45:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138490#138490</guid>
   <title>RPod 178 Mystery Button - Second Owner : Hi all, been lurking awhile after...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138488#138488</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10935" rel="nofollow">Ctvmotors</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 23 Nov 2020 at 8:22pm<br /><br />Hi all, been lurking awhile after buying a one owner 2016 rp179, and I appreciate the intel here... re this outside light, how do I replace the bulb?&nbsp; On my first and only trip out, in figuring out switches, I found this switch, and light, which worked for several minutes, then went out.&nbsp; I presume the bulb is bad, but couldn't easily pop off the orange cover?&nbsp; Any tricks?&nbsp; Thanks, in advance, ddc]]>
   <pubDate>Mon, 23 Nov 2020 20:22:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=138488#138488</guid>
   <title>RPod 178 Mystery Button - Second Owner : +1 to Furpod, I have a 178, it&amp;#039;s...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137180#137180</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 12 Oct 2020 at 3:19pm<br /><br />+1 to Furpod, I have a 178, it's the porch light.]]>
   <pubDate>Mon, 12 Oct 2020 15:19:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137180#137180</guid>
   <title>RPod 178 Mystery Button - Second Owner : Bulbs must be out then, i&amp;#039;ll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137168#137168</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10872" rel="nofollow">Sgardner</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 12 Oct 2020 at 11:20am<br /><br />Bulbs must be out then, i'll check light outside the door.<div><br></div><div>Thank you.</div>]]>
   <pubDate>Mon, 12 Oct 2020 11:20:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137168#137168</guid>
   <title>RPod 178 Mystery Button - Second Owner : Porch light.   </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137167#137167</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=936" rel="nofollow">furpod</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 12 Oct 2020 at 11:18am<br /><br />Porch light.]]>
   <pubDate>Mon, 12 Oct 2020 11:18:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137167#137167</guid>
   <title>RPod 178 Mystery Button - Second Owner : Second owner of an RPod 178, Just...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137162#137162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10872" rel="nofollow">Sgardner</a><br /><strong>Subject:</strong> 14106<br /><strong>Posted:</strong> 12 Oct 2020 at 10:31am<br /><br />Second owner of an RPod 178, Just inside the door on the left, above the television.<div>We have a button set which indicates battery / grey water / clean water / blackwater.</div><div>We have the slide button which moves the slide in / out.</div><div><br></div><div>There is also a black on/off toggle button on the left, no idea what it is for and cannot figure it out, any ideas?</div><div><br></div><div>It does not toggle a light inside or out, nor does it turn on/off the external speakers. Highlighted in red below.</div><div><br></div><div><img src="uploads/10872/RPodSwitch.jpg" height="449" width="355" border="0" /><br></div>]]>
   <pubDate>Mon, 12 Oct 2020 10:31:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14106&amp;PID=137162#137162</guid>
