  <title>R-pod Owners Forum : black water flush</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : black water flush</description>
  <pubDate>Sun, 25 Oct 2026 10:47:22 +0000</pubDate>
  <lastBuildDate>Sun, 11 Oct 2020 10:57:11 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14102</WebWizForums:feedURL>
   <title>black water flush : There are a ton of posts on here...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137124#137124</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 14102<br /><strong>Posted:</strong> 11 Oct 2020 at 10:57am<br /><br />There are a ton of posts on here about back flush valves installed backwards.  While back it seemed common, then not and now back again.  Fixing it, to me is a matter of ease of access to the valve.  If you are still under warranty, return to dealer.]]>
   <pubDate>Sun, 11 Oct 2020 10:57:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137124#137124</guid>
   <title>black water flush :  No I don&amp;#039;t and I don&amp;#039;t...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137112#137112</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8869" rel="nofollow">mhfnet</a><br /><strong>Subject:</strong> 14102<br /><strong>Posted:</strong> 11 Oct 2020 at 8:06am<br /><br />No I don't and I don't think it is common. If no water is coming out of the drain when the flush hose is turned on or can't hear it filling the tank then yes you have a problem with the flush valve or the spray head in the tank. Here is a video on someone that replaced the flush valve on a 178 and there is a lot of videos on replacing the spray head but if you not comfortable doing it yourself you'll have to take it to a dealer and wouldn't doubt it will cost around $200 but that's just a guess?<br>https://www.youtube.com/watch?v=utltujsIvrw<br>https://www.youtube.com/results?search_query=replace+black+tank+flush+head]]>
   <pubDate>Sun, 11 Oct 2020 08:06:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137112#137112</guid>
   <title>black water flush : I recently bought an RPod 192...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137111#137111</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10692" rel="nofollow">PaulP</a><br /><strong>Subject:</strong> 14102<br /><strong>Posted:</strong> 11 Oct 2020 at 6:10am<br /><br />I recently bought an RPod 192 and as part of storing for winter wanted to flush my black water tank. I hooked up the hose however it is not flushing the tank--almost seems to be blocked somehow. Does anyone have this problem??<div><br></div><div><br></div>]]>
   <pubDate>Sun, 11 Oct 2020 06:10:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14102&amp;PID=137111#137111</guid>
