  <title>R-pod Owners Forum : Battery replacemnet help</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Battery replacemnet help</description>
  <pubDate>Sun, 25 Oct 2026 10:46:47 +0000</pubDate>
  <lastBuildDate>Wed, 30 Sep 2020 10:50:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14072</WebWizForums:feedURL>
   <title>Battery replacemnet help : You might want to find a 12v flooded...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136770#136770</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 14072<br /><strong>Posted:</strong> 30 Sep 2020 at 10:50am<br /><br />You might want to find a 12v flooded golf cart battery rather than a marine deep cycle battery. Marine batteries are a compromise between a deep cycle and a starting battery because they need to perform both functions, so they aren’t generally able to handle as many deep cycles as a golf cart battery will. I think Trojan makes a line of 12V golf cart batteries, among other brands. ]]>
   <pubDate>Wed, 30 Sep 2020 10:50:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136770#136770</guid>
   <title>Battery replacemnet help : +1The batteries needed for an...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136767#136767</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 14072<br /><strong>Posted:</strong> 30 Sep 2020 at 10:11am<br /><br />+1<div>The batteries needed for an RV should be deep cycle batteries, and the comparisons will be in 20 (or 24) hour amp-hour ratings.</div>]]>
   <pubDate>Wed, 30 Sep 2020 10:11:52 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136767#136767</guid>
   <title>Battery replacemnet help : Cold Cranking amps is not the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136758#136758</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 14072<br /><strong>Posted:</strong> 29 Sep 2020 at 10:44pm<br /><br /><div>Cold Cranking amps is not the figure to look at. That is a measure of how fast a battery can put out power. What is needed is a 20 hour rating. That is a better measure of how much power a battery can store and release. Here is a link to batteries she could consider:</div><div><a href="https://www.batteriesplus.com/battery/rv/deep-cycle/12" target="_blank">https://www.batteriesplus.com/battery/rv/deep-cycle/12</a><br></div>]]>
   <pubDate>Tue, 29 Sep 2020 22:44:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136758#136758</guid>
   <title>Battery replacemnet help : I need help for a friend that...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136756#136756</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=1008" rel="nofollow">Pod People</a><br /><strong>Subject:</strong> 14072<br /><strong>Posted:</strong> 29 Sep 2020 at 9:47pm<br /><br /><div>I need help for a friend that has a tab320.&nbsp; she has a single 12v battery that needs to be replaced.&nbsp; since I have 2 GC-6volts, I'm not current on which is the best 12v&nbsp; battery .&nbsp; She does about 1/2-1/2 powered campgrounds and boondocking for a couple of nights. she has a 30 amp service, a Renogy 100 watt suitcase and is not a power hog and currently has an Interstate 550 cranking amp battery that is dying. <br></div><div>thanks for your help</div><div>Vann<br></div>]]>
   <pubDate>Tue, 29 Sep 2020 21:47:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14072&amp;PID=136756#136756</guid>
