  <title>R-pod Owners Forum : Water Pump Disconnected Hose</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Water Pump Disconnected Hose</description>
  <pubDate>Sun, 25 Oct 2026 09:41:43 +0000</pubDate>
  <lastBuildDate>Tue, 29 Sep 2020 19:15:17 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=14068</WebWizForums:feedURL>
   <title>Water Pump Disconnected Hose : Also you may want to check the...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136750#136750</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8731" rel="nofollow">JR</a><br /><strong>Subject:</strong> 14068<br /><strong>Posted:</strong> 29 Sep 2020 at 7:15pm<br /><br />Also you may want to check the outside shower for a possible leak running down the outside of the trailer.&nbsp; I am not sure if the 178 has an outdoor shower??]]>
   <pubDate>Tue, 29 Sep 2020 19:15:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136750#136750</guid>
   <title>Water Pump Disconnected Hose :  Don&amp;#039;t forget to check OUTSIDE...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136717#136717</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10082" rel="nofollow">Grant177</a><br /><strong>Subject:</strong> 14068<br /><strong>Posted:</strong> 29 Sep 2020 at 11:43am<br /><br />Don't forget to check OUTSIDE as well...should have added that in the note:<div><br></div><div>1) The hot water tank area behind the access panel on the outside&nbsp; also has locations (hot water tank pressure release valve, anode rod, heating element area) that can leak.</div><div><br></div><div>2) Low Point Drains.&nbsp; If there are not sealed, water could be dripping from the low point drains underneath as well.</div>]]>
   <pubDate>Tue, 29 Sep 2020 11:43:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136717#136717</guid>
   <title>Water Pump Disconnected Hose : Grant, I appreciate all the great...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136716#136716</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10677" rel="nofollow">shirlgirl</a><br /><strong>Subject:</strong> 14068<br /><strong>Posted:</strong> 29 Sep 2020 at 11:39am<br /><br />Grant, I appreciate all the great info you provided. Obviously I have a lot to learn. I'll start checking for leaks.&nbsp;<div>Thank you!</div>]]>
   <pubDate>Tue, 29 Sep 2020 11:39:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136716#136716</guid>
   <title>Water Pump Disconnected Hose :                    That...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136711#136711</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10082" rel="nofollow">Grant177</a><br /><strong>Subject:</strong> 14068<br /><strong>Posted:</strong> 29 Sep 2020 at 11:06am<br /><br />That is your alternate intake hose for winterizing (sucking in anti-freeze).&nbsp; You insert that into a bottle of RV antifreeze (IMPORTANT - USE ONLY non-toxic RV anti-freeze!!)&nbsp; Edit:&nbsp; Just noticed you are in AZ, so perhaps you never need to winterize...I'm jealous if that is the case...then again...I rarely have to use AC here...(cold, chilly Canada).<div><br></div><div>Notice how it connects to a valve (the circular shaped white piece directly beside the blue colored connector) - there is a little lever under there&nbsp; you can flip 90 degrees (when you need to winterize etc).&nbsp; It is currently in the "tank" position...which lets water flow from the fresh water tank into the pump.&nbsp; By flipping that valve (pointing towards the short hose) the pump will now pull from the open end and the pump no longer draws from the water tank.</div><div><br></div><div>If you find it is running often, you may have a leak somewhere.&nbsp; Turn on the pump and just check everywhere possible - hot water tank area, toilet, shower (and the valves behind the shower controls), under the sink etc.&nbsp; Any slow leak (a dripping faucet or shower head, or a little dribble of water into the toilet etc.) will cause the pressure to drop and then eventually the pump ramps up the pressure again.</div><div><br></div><div>That said, I had the same problem and I could find nowhere it was leaking.&nbsp; I eventually removed the pump (thinking it was faulty) and completely disassembled it (it is pretty easy....just carefully note where all the wires and screws go) and cleaned/checked the rubber diaphragm inside (I found nothing obviously wrong) but after re-assembling it all the problem went away...&nbsp; I assume there was maybe some debris or something not sealed correctly.</div><div><br></div><div>Hard to tell from the picture, but you might even be able to disassemble the pump right there without disconnecting any hoses or removing the pump at all.&nbsp; All the screws seem to be accessible.&nbsp; Someone more knowledgeable here may have some advice.</div><div><br></div><div>Here is a video that goes over some disassembly....</div><div><br></div><div>https://youtu.be/XaJjU09ygmU</div><div><br></div><div><br></div>]]>
   <pubDate>Tue, 29 Sep 2020 11:06:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136711#136711</guid>
   <title>Water Pump Disconnected Hose : Hi Everyone!I&amp;#039;m a new owner...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136710#136710</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10677" rel="nofollow">shirlgirl</a><br /><strong>Subject:</strong> 14068<br /><strong>Posted:</strong> 29 Sep 2020 at 10:51am<br /><br />Hi Everyone!<div>I'm a new owner of a used 2015 178 r-pod and have a question about the water pump constantly running. I use it off battery and propane, pressurized the water system, but the pump keeps running every few minutes. So I turned it off unless using water. I checked the water filter but it looks clean and undamaged. Then I noticed a disconnected hose but I couldn't see any place to connect it. I drove on a rocky dirt road so maybe it vibrated loose but I can't find anyplace to re-attach it.&nbsp;<img src="uploads/10677/water%20pump%20hose.jpg" height="1224" width="1632" border="0" />I included a photo and noted hose with yellow. Is this normal?</div><div>Thank you!</div><div>-shirley</div>]]>
   <pubDate>Tue, 29 Sep 2020 10:51:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=14068&amp;PID=136710#136710</guid>
