  <title>R-pod Owners Forum : Winterizing a R-pod 195</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Winterizing a R-pod 195</description>
  <pubDate>Fri, 23 Oct 2026 08:07:10 +0000</pubDate>
  <lastBuildDate>Fri, 01 Jan 2021 15:41:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13993</WebWizForums:feedURL>
   <title>Winterizing a R-pod 195 : My 2020 195 does not have a vacuum....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=139206#139206</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10338" rel="nofollow">mmulroy</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 01 Jan 2021 at 3:41pm<br /><br />My 2020 195 does not have a vacuum. &nbsp;There is a panel below the fridge. &nbsp;Needed to remove 4 screws, plus the bungee netting.&nbsp;<div><br></div><div>The first time I tried to remove the panel it was fitted too tight and would not come out. &nbsp;I needed to remove the inverter (kill the battery before doing this) and push the panel from behind. &nbsp;Sanded the panel so it is now easy to remove.&nbsp;</div><div><br></div><div>Instructions are on the water line for how to position for winterizing. &nbsp;</div>]]>
   <pubDate>Fri, 01 Jan 2021 15:41:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=139206#139206</guid>
   <title>Winterizing a R-pod 195 :    Originally posted by ArenaBlanca...They...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138204#138204</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 11 Nov 2020 at 10:25am<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by ArenaBlanca</strong></em><br /><br />...They believe that there are hoses and plumbing issues associated with removing the vacuum, therefore, they recommend removing the converter....</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>No issues for me.&nbsp; As I mentioned, only had to get in there one time to open them up (took delivery of a winterized unit 11/2019) and now it's all about the compressed air!</div><div><br></div><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by mjlrpod</strong></em><br /><br />Well I don't know about all 195's, but mine was super simple to get to the H/W tank valve. 4 screws and the cover came right off....</td></tr></table></div><div><br></div><div>I suspect that you have a 195 that includes an access panel that I don't have.&nbsp; You can see it here at about 8:50 around the corner from the vacuum:</div><div><br></div><div>youtube.com/watch?v=xA1Ycl3alQI</div>]]>
   <pubDate>Wed, 11 Nov 2020 10:25:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138204#138204</guid>
   <title>Winterizing a R-pod 195 : Well I don&amp;#039;t know about all...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138203#138203</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 11 Nov 2020 at 10:16am<br /><br />Well I don't know about all 195's, but mine was super simple to get to the H/W tank valve. 4 screws and the cover came right off. They even had a tag on the water line showing how to set the valve for winter or summer. Was a pleasant surprise to see that they cared enough to do that. Not that it's hard to figure out, but it's about the fact someone cared.&nbsp;]]>
   <pubDate>Wed, 11 Nov 2020 10:16:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138203#138203</guid>
   <title>Winterizing a R-pod 195 : This is just for the record and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138165#138165</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6047" rel="nofollow">ArenaBlanca</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 10 Nov 2020 at 10:13am<br /><br />This is just for the record and I wanted to close out the discussion.&nbsp; I finally got an answer from Forest River on accessing the water heater by-pass valves. They believe that there are hoses and plumbing issues associated with removing the vacuum, therefore, they recommend removing the converter.&nbsp; But they caution to be careful of all the wiring behind it.<div><br></div><div>I'm with Pod_Geek on this issue.&nbsp; I drain the water heater and&nbsp; use compressed air to blow out the water lines. But I wanted to know where the valves were located as I'd never seen them on this model.</div>]]>
   <pubDate>Tue, 10 Nov 2020 10:13:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=138165#138165</guid>
   <title>Winterizing a R-pod 195 : Winterize the 195 in a jiffy......</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=137892#137892</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10237" rel="nofollow">BMJ</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 31 Oct 2020 at 10:06am<br /><br />Winterize the 195 in a jiffy... bypass to water heater behind vac...hose for winterize fluid is front compartment ( I replaced. the 4 screws with Velcro) takes about 1 1/2 gallons for complete&nbsp;&nbsp;&nbsp;.... they did a great job in engineering access for winterizing..: it’s just sad to have to end the travel session]]>
   <pubDate>Sat, 31 Oct 2020 10:06:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=137892#137892</guid>
   <title>Winterizing a R-pod 195 : You have to pull the vacuum in...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136188#136188</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 14 Sep 2020 at 3:42pm<br /><br />You have to pull the vacuum in the 2020.5 (which I have). Not a huge deal, but as I recall from last spring's dewinterization it is possible to screw up and lose one or more of the brackets that hold the vacuum's face plate on. I use compressed air so don't have to get at the water heater bypasses, which lowers my stress level.<div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div>]]>
   <pubDate>Mon, 14 Sep 2020 15:42:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136188#136188</guid>
   <title>Winterizing a R-pod 195 : Vaccum? In last years model? Not...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136047#136047</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6126" rel="nofollow">mjlrpod</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 08 Sep 2020 at 2:00pm<br /><br />Vaccum? In last years model? Not mine. Oh maybe the 2020.5 had it.&nbsp; But the hot water tank valves should be behind the bottom panel, under the fridge. Is it going to be above freezing in the daytime? If so I wouldn't worry about it yet.&nbsp;]]>
   <pubDate>Tue, 08 Sep 2020 14:00:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136047#136047</guid>
   <title>Winterizing a R-pod 195 : We traded in our 179 for the 195...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136046#136046</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6047" rel="nofollow">ArenaBlanca</a><br /><strong>Subject:</strong> 13993<br /><strong>Posted:</strong> 08 Sep 2020 at 12:40pm<br /><br />We traded in our 179 for the 195 last year.&nbsp; We also spent the winter at home where I could plug in.&nbsp; The forecast for tomorrow calls for overnight temps ins the 26-30 degree range.&nbsp; I drained the hot water heater and used the air method to blow out the lines and the toilet valve.&nbsp; So I should be okay to go.<div><br></div><div>But just for the record, are there shut off valves for the water heater? And how does one get to them in this model?&nbsp; It looks to me that one would need to pull out the converter or the vacuum but that seems like a lot of hassle.</div>]]>
   <pubDate>Tue, 08 Sep 2020 12:40:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13993&amp;PID=136046#136046</guid>
