  <title>R-pod Owners Forum : TV cable hook up</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : TV cable hook up</description>
  <pubDate>Sun, 25 Oct 2026 06:03:32 +0000</pubDate>
  <lastBuildDate>Wed, 02 Sep 2020 17:37:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13980</WebWizForums:feedURL>
   <title>TV cable hook up : Would it work to put a splitter...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135950#135950</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10066" rel="nofollow">RoverPod</a><br /><strong>Subject:</strong> 13980<br /><strong>Posted:</strong> 02 Sep 2020 at 5:37pm<br /><br />Would it work to put a splitter in?]]>
   <pubDate>Wed, 02 Sep 2020 17:37:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135950#135950</guid>
   <title>TV cable hook up :   Originally posted by Capt...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135944#135944</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9925" rel="nofollow">Pod_Geek</a><br /><strong>Subject:</strong> 13980<br /><strong>Posted:</strong> 02 Sep 2020 at 3:06pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Capt Kidd</strong></em><br /><br />...The problem is you have to undo and reconnect to change from one &#091;to&#093; the other.&nbsp; Has any one found a solution to this problem?...</td></tr></table><div id="UMS_TOOLTIP" style=": ; cursor: pointer; : 2147483647; : transparent; top: -100000px; left: -100000px;"></div><div><br></div><div>I would just keep a short run of coax attached to both and switch them on the TV as necessary (easier than reaching up to the ceiling I would think), perhaps using one of these:</div><div><br></div><div><a href="https://www.amaz&#111;n.com/cable-Coaxial-C&#111;nnect-Threaded-200-103/dp/B000I965YS" target="_blank">https://www.amazon.com/cable-Coaxial-Connect-Threaded-200-103/dp/B000I965YS</a>.</div>]]>
   <pubDate>Wed, 02 Sep 2020 15:06:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135944#135944</guid>
   <title>TV cable hook up : I have an 2020 196 and the hookup...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135938#135938</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4498" rel="nofollow">Capt Kidd</a><br /><strong>Subject:</strong> 13980<br /><strong>Posted:</strong> 02 Sep 2020 at 2:01pm<br /><br />I have an 2020 196 and the hookup for the TV antenna is confusing.&nbsp; There is one pot on the outside that says satellite/cable and on the inside there are two ports, depending on which one you hookup to you either get antenna or cable/sat.&nbsp; The problem is you have to undo and reconnect to change from one tom the other.&nbsp; Has any one found a solution to this problem?&nbsp; In my old 179 there was only one outlet inside and it worked for both cable and antenna.&nbsp; Its not that big of a deal just a pain having to switch back and forth]]>
   <pubDate>Wed, 02 Sep 2020 14:01:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13980&amp;PID=135938#135938</guid>
