  <title>R-pod Owners Forum : AC operation question</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : AC operation question</description>
  <pubDate>Sun, 25 Oct 2026 04:50:51 +0000</pubDate>
  <lastBuildDate>Thu, 27 Aug 2020 15:55:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13955</WebWizForums:feedURL>
   <title>AC operation question : thanks for the info. I&amp;#039;ll...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135730#135730</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10697" rel="nofollow">Leals</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 27 Aug 2020 at 3:55pm<br /><br />thanks for the info. I'll check out the stuff you posted. I appreciate it.]]>
   <pubDate>Thu, 27 Aug 2020 15:55:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135730#135730</guid>
   <title>AC operation question : Thanks for the information everyone....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135729#135729</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10697" rel="nofollow">Leals</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 27 Aug 2020 at 3:54pm<br /><br />Thanks for the information everyone. I appreciate it and will look at all the items you listed for troubleshooting. ]]>
   <pubDate>Thu, 27 Aug 2020 15:54:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135729#135729</guid>
   <title>AC operation question :      Originally posted by...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135723#135723</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 27 Aug 2020 at 8:13am<br /><br /><div><br></div><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Leals</strong></em><br /><br />It did cool it, nicely. Went to sleep and woke sweaty. Couldn't get it to turn back on regardless of changing temp on thermostat unless I shut it off completely and turn it back on.</td></tr></table></div><div><br></div>To answer your other question, that's not the way they normally work...as offgrid pointed out, the evaporator coils might be freezing up, and that is usually caused by one or a combination of 3 reasons:<div><br></div><div>High humidity and a too low setting on the thermostat</div><div><br></div><div>Low on refrigerant charge</div><div><br></div><div>Evaporator or condenser airflow restricted (look and see if the fins on the roof unit are all 'smushed' over, and check and/or clean the interior air filters in the ceiling unit)</div>]]>
   <pubDate>Thu, 27 Aug 2020 08:13:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135723#135723</guid>
   <title>AC operation question :  Are you in high humidity conditions?...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135721#135721</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 27 Aug 2020 at 7:23am<br /><br />Are you in high humidity conditions? There is a freeze sensor in the a/c which shuts it off if the evaporator freezes up. You have to recycle the a/c to get it to reset.&nbsp; If its cooling ok to begin with that might be your problem. You might be able to see if the evaporator is frozen up by removing the interior cover, not sure. Keeping the fan on high will reduce the likelihood of freeze up if you can stand the jet engine roar all night&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley2.gif" border="0" alt="Wink" title="Wink" /> &nbsp;]]>
   <pubDate>Thu, 27 Aug 2020 07:23:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135721#135721</guid>
   <title>AC operation question : It did cool it, nicely. Went to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135719#135719</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10697" rel="nofollow">Leals</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 26 Aug 2020 at 11:44pm<br /><br />It did cool it, nicely. Went to sleep and woke sweaty. Couldn't get it to turn back on regardless of changing temp on thermostat unless I shut it off completely and turn it back on. ]]>
   <pubDate>Wed, 26 Aug 2020 23:44:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135719#135719</guid>
   <title>AC operation question : Did it bring your camper down...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135718#135718</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9179" rel="nofollow">podwerkz</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 26 Aug 2020 at 10:33pm<br /><br /><div><br></div><div>Did it bring your camper down to the set temperature and then cycle on and off?</div>]]>
   <pubDate>Wed, 26 Aug 2020 22:33:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135718#135718</guid>
   <title>AC operation question : I am a new RPod owner. We have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135716#135716</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10697" rel="nofollow">Leals</a><br /><strong>Subject:</strong> 13955<br /><strong>Posted:</strong> 26 Aug 2020 at 9:18pm<br /><br />I am a new RPod owner. We have a 2016 179. We just got back from a week-long trip. At night, I'd set the thermostat at 68 (it was over 100° where we were). It would come on, cool for a bit, then shut off and come back on (low) for a few minutes, then shut off. But then it wouldn't come back on unless I shut it off completely, wait 10 or 15 seconds and turn it back on. <br />Can someone explain to me how the AC works so it will come on and off like a house AC....or do they not work that way?<br /><br />Thank You!]]>
   <pubDate>Wed, 26 Aug 2020 21:18:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13955&amp;PID=135716#135716</guid>
