  <title>R-pod Owners Forum : Weather</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : Weather</description>
  <pubDate>Sun, 25 Oct 2026 14:47:54 +0000</pubDate>
  <lastBuildDate>Tue, 25 Aug 2020 13:28:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13930</WebWizForums:feedURL>
   <title>Weather : Agree with ArenaBlanca. When camping...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135684#135684</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9043" rel="nofollow">Dirt Sifter</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 25 Aug 2020 at 1:28pm<br /><br />Agree with ArenaBlanca. When camping in the high desert or mountains the night temps can get into freezing range, but only for an hour or two, not enough to freeze warm water usually. Disconnecting the (city) water hose is good insurance just in case.]]>
   <pubDate>Tue, 25 Aug 2020 13:28:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135684#135684</guid>
   <title>Weather : It would take a lot to freeze...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135683#135683</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 25 Aug 2020 at 1:25pm<br /><br />It would take a lot to freeze the fresh water tank but the feed line from the tank to the pump is exposed so that would freeze about as soon as the city water line. You could enclose it in foam pipe insulation and run a little water through it a few times overnight, that would <i>probably</i> handle temps down into the high 20's.&nbsp;<div><br></div><div>If you want to be sure drain the tank, disconnect the city water, and use bottled water if you hit cold conditions.&nbsp;</div>]]>
   <pubDate>Tue, 25 Aug 2020 13:25:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135683#135683</guid>
   <title>Weather : Northern NM and southern CO have...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135679#135679</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=6047" rel="nofollow">ArenaBlanca</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 25 Aug 2020 at 12:28pm<br /><br />Northern NM and southern CO have already had one night of cold weather.&nbsp; But I don't think you will need to get a heated hose. Most campgrounds in the area have running water until they are closed.&nbsp; If you suspect freezing overnight temps, you have two options.&nbsp;&nbsp;<div><br></div><div>You can fill the fresh water tank and use that.&nbsp; The volume is such that it <font color="#cc0000">probably</font> will not freeze. The second option is to disconnect from city (campground) water for overnight. Drain the hose and reconnect in the morning.&nbsp;&nbsp;</div><div><br></div><div>You should be okay for this time of year.&nbsp; You might wish to call the campgrounds you plan to saty at and ask their advice.&nbsp;</div>]]>
   <pubDate>Tue, 25 Aug 2020 12:28:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135679#135679</guid>
   <title>Weather : Yes, there are close to a million...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135575#135575</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 23 Aug 2020 at 10:58am<br /><br />Yes, there are close to a million acres on fire at the moment, and the news I read this morning is that the smoke is reaching as far as Nebraska.]]>
   <pubDate>Sun, 23 Aug 2020 10:58:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135575#135575</guid>
   <title>Weather : Thank you. Just read an article...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135562#135562</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9084" rel="nofollow">Buckeye</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 23 Aug 2020 at 7:36am<br /><br />Thank you. Just read an article about the fires. We live in strange times. Be well and safe.]]>
   <pubDate>Sun, 23 Aug 2020 07:36:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135562#135562</guid>
   <title>Weather :      Originally posted by...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135557#135557</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10066" rel="nofollow">RoverPod</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 23 Aug 2020 at 5:47am<br /><br /><div><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by Buckeye</strong></em><br /><br />From?</td></tr></table></div><div><br></div><div>Yes, from the California wildfires. There are also fires in Colorado right now.<br></div><div><br></div><div><span>https://www.instagram.com/p/CEMqvKYFFsG/?hl=en</span></div><div><span><br></span></div><div><span><img src="uploads/10066/118154027_764326024393203_3466459405028519212_n.jpg" height="565" width="1080" border="0" /><br></span></div><div><span><br></span></div>]]>
   <pubDate>Sun, 23 Aug 2020 05:47:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135557#135557</guid>
   <title>Weather : The wildfires in California. I...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135539#135539</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 22 Aug 2020 at 2:55pm<br /><br />The wildfires in California. I don't know if there are any burning in the Yellowstone area, but the smoke from California is covering a rather large area.&nbsp;<a href="https://img.particlenews.com/img/id/0woXo0_0Wij3rov00?type=thumbnail_1024x576" target="_blank">https://img.particlenews.com/img/id/0woXo0_0Wij3rov00?type=thumbnail_1024x576</a>]]>
   <pubDate>Sat, 22 Aug 2020 14:55:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135539#135539</guid>
   <title>Weather : From? </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135537#135537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9084" rel="nofollow">Buckeye</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 22 Aug 2020 at 2:47pm<br /><br />From?]]>
   <pubDate>Sat, 22 Aug 2020 14:47:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135537#135537</guid>
   <title>Weather : Be prepared for heavy smoke, too....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135535#135535</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10066" rel="nofollow">RoverPod</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 22 Aug 2020 at 2:40pm<br /><br />Be prepared for heavy smoke, too.<br>]]>
   <pubDate>Sat, 22 Aug 2020 14:40:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135535#135535</guid>
   <title>Weather : Traveling to West Yellowstone...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135531#135531</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=9084" rel="nofollow">Buckeye</a><br /><strong>Subject:</strong> 13930<br /><strong>Posted:</strong> 22 Aug 2020 at 12:55pm<br /><br />Traveling to West Yellowstone and will be there for the first week of September, then on to Glacier for the second week, and down to Colorado for the third week by way of Idaho and Utah. Any weather preparation tips or thoughts from y'all? My concern is frigid mornings/water difficulties. Is it wise to invest in a water hose with the heat tape?<div>Thanks in advance.</div>]]>
   <pubDate>Sat, 22 Aug 2020 12:55:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13930&amp;PID=135531#135531</guid>
