  <title>R-pod Owners Forum : R-177 Slide Out Failure</title>
  <description>This is an XML content feed of; R-pod Owners Forum : I need HELP!!! : R-177 Slide Out Failure</description>
  <pubDate>Sun, 25 Oct 2026 16:57:46 +0000</pubDate>
  <lastBuildDate>Mon, 10 Aug 2020 07:43:31 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13885</WebWizForums:feedURL>
   <title>R-177 Slide Out Failure : Always glad to find a simple fix...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135087#135087</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 10 Aug 2020 at 7:43am<br /><br /><div>&nbsp;Always glad to find a simple fix and glad to share it with others that may have this same issue.</div><div><br></div><div>Ron<br></div>]]>
   <pubDate>Mon, 10 Aug 2020 07:43:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135087#135087</guid>
   <title>R-177 Slide Out Failure : I&amp;#039;m glad it ended up being...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135059#135059</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 5:03pm<br /><br />I'm glad it ended up being something simple. Thanks for saying what the problem was.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" />]]>
   <pubDate>Sun, 09 Aug 2020 17:03:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135059#135059</guid>
   <title>R-177 Slide Out Failure : Stephen,Found and Fixed My Slideout...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135058#135058</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 4:56pm<br /><br /><div>&nbsp;Stephen,</div><div><br></div><div>Found and Fixed My Slideout Failure.</div><div><br></div><div>The 40 amp <b>Fuse Holder</b> needed to be crimped down. The fuse barely made contact with it fuse holder. Gently crimped it down and slide failure was fixed. <img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /><br></div>]]>
   <pubDate>Sun, 09 Aug 2020 16:56:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135058#135058</guid>
   <title>R-177 Slide Out Failure : Found and Fixed My Slideout Failure.The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135057#135057</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 4:48pm<br /><br /><div><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /> Found and Fixed My Slideout Failure.</div><div><br></div><div>The 40 Amp slide out <b>fuse holder </b>needed to be crimped down. No blown fuse.&nbsp; Crimped it down gently and the slideout works perfectly.<br></div>]]>
   <pubDate>Sun, 09 Aug 2020 16:48:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135057#135057</guid>
   <title>R-177 Slide Out Failure :    </title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135056#135056</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 4:43pm<br /><br />]]>
   <pubDate>Sun, 09 Aug 2020 16:43:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135056#135056</guid>
   <title>R-177 Slide Out Failure : Thanks Stephan for your suggestions.The...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135049#135049</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 3:24pm<br /><br /><div><img src="https://www.rpod-owners.com/smileys/smiley1.gif" border="0" alt="Smile" title="Smile" /> Thanks Stephan for your suggestions.</div><div><br></div><div>The LED that illuminates is for the slide out.</div><div><br></div><div>I'll check the fuse(s) with my multimeter, good suggestion even though they they look OK.<br></div>]]>
   <pubDate>Sun, 09 Aug 2020 15:24:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135049#135049</guid>
   <title>R-177 Slide Out Failure : How did you check the fuse? A...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135046#135046</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 2:34pm<br /><br />How did you check the fuse? A light there would indicate a blown fuse. Did you pull the fuse out and physically check it, preferably with a multimeter, to make sure it is good? If you have an appropriate one, replace the fuse where the light is. It should go out. If it blows and lights up again, then it is likely that going down that bumpy road caused a wire somewhere to short out. You will need to do some tracing of wires to see where the wire might be damaged.]]>
   <pubDate>Sun, 09 Aug 2020 14:34:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135046#135046</guid>
   <title>R-177 Slide Out Failure : Mistake on the emoji. Should be...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135045#135045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4179" rel="nofollow">rawellman</a><br /><strong>Subject:</strong> 13885<br /><strong>Posted:</strong> 09 Aug 2020 at 2:29pm<br /><br /><div>&nbsp;Mistake on the emoji. Should be a frown.</div><div><br></div><div>The slide out worked as expected at home but after we pulled the RPod over a very bumpy gravel road the slide out failed to extend.&nbsp; At home plugged into line power same story.</div><div><br></div><div>There is a red light that illuminates on the fuse/breaker panel when we push the "out" button.</div><div><br></div><div>Checked the fuses and they are all OK.</div><div><br></div><div>Help please, I expect something became disconnected on the bumpy road.<br></div>]]>
   <pubDate>Sun, 09 Aug 2020 14:29:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13885&amp;PID=135045#135045</guid>
