  <title>R-pod Owners Forum : Larger Wheels On 178?</title>
  <description>This is an XML content feed of; R-pod Owners Forum : Mods, Maintenance, Tips and Tricks : Larger Wheels On 178?</description>
  <pubDate>Fri, 23 Oct 2026 09:54:39 +0000</pubDate>
  <lastBuildDate>Wed, 05 Aug 2020 17:25:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.rpod-owners.com/RSS_post_feed.asp?TID=13866</WebWizForums:feedURL>
   <title>Larger Wheels On 178? : Absolutely agree with your decision....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134947#134947</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 05 Aug 2020 at 5:25pm<br /><br />Absolutely agree with your decision.  I am not a boondocker, I went from bondocking to the Pod, I'm a full service camper:)]]>
   <pubDate>Wed, 05 Aug 2020 17:25:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134947#134947</guid>
   <title>Larger Wheels On 178? : Happy is good. As I&amp;#039;m boon...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134946#134946</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 05 Aug 2020 at 4:58pm<br /><br />Happy is good. <img src="https://www.rpod-owners.com/smileys/smiley20.gif" border="0" alt="Thumbs Up" title="Thumbs Up" /><div><br></div><div>As I'm boon docking I'm always dragging around more load than most, I'm within a couple hundred pounds on the 3500 lb axle rating, so I'll take any additional safety margin I can get...</div>]]>
   <pubDate>Wed, 05 Aug 2020 16:58:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134946#134946</guid>
   <title>Larger Wheels On 178? : Points well taken and considered....</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134941#134941</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 05 Aug 2020 at 3:55pm<br /><br />Points well taken and considered.  My Carlisles are rated at 2024, 81 MPH and 65 lbs.  Big improvement over the C rates.  They also run cooler.  So I'm happy.]]>
   <pubDate>Wed, 05 Aug 2020 15:55:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134941#134941</guid>
   <title>Larger Wheels On 178? : Its not the inch its the load...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134909#134909</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 6:56pm<br /><br />Its not the inch its the load rating. My 15 inch wheels and the LRD tires are both rated for 2540 lbs.&nbsp; I'll bet the 14 inch wheels FR puts on there are only rated to 1750. As I look at bit, you're only as good as the weakest link. What's the point in having high spec tires on low spec wheels? Just my opinion.&nbsp;<div><br></div><div>By buying already mounted tires with wheels I saved the mounting fee and was able to sell the old tires and wheels on CL, otherwise no one would have wanted the old tires because they weren't worth mounting. So I basically got the wheels for free, and just put them on myself. And yes, to me they do look better proportioned to the trailer.&nbsp;<div><br></div><div><br></div></div>]]>
   <pubDate>Tue, 04 Aug 2020 18:56:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134909#134909</guid>
   <title>Larger Wheels On 178? : The change for me was to go to...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134904#134904</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 4:23pm<br /><br />The change for me was to go to LRDs from LRCs.  Without the cost of wheels and another set of tires.  I agree the C rates my 178 came with seemed an issue.  I was never concerned about the inch from a 15" wheel and tire.]]>
   <pubDate>Tue, 04 Aug 2020 16:23:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134904#134904</guid>
   <title>Larger Wheels On 178? :   Thanks for the input! As it...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134898#134898</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10323" rel="nofollow">alandlearned</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 2:58pm<br /><br />Thanks for the input!&nbsp; As it turned out, I bought Maxxis steel-belted radials before we started out on our trip up the coast from Florida to Massachusetts last month. I based my purchase on really two factors - one, they were rated for 70 mph. That being admitted to, I set my cruise control to 65 for those nice straight and long stretches. 70 mph gives me peace of mind. Two, they appear to be a trustworthy ride according to a lot of tire reviewers. I also put two Michelin light truck tires on my Grand Caravan to give my tail end a bit of a lift. I really like the steady ride!&nbsp;<div><br></div>]]>
   <pubDate>Tue, 04 Aug 2020 14:58:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134898#134898</guid>
   <title>Larger Wheels On 178? : Okay. I was quoting from a Maxxis...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134897#134897</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 2:13pm<br /><br />Okay. I was quoting from a Maxxis tire site. Agreed that some brands are better and some worse than what I cited.]]>
   <pubDate>Tue, 04 Aug 2020 14:13:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134897#134897</guid>
   <title>Larger Wheels On 178? :   Originally posted by StephenH Moving...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134896#134896</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=7014" rel="nofollow">GlueGuy</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 2:03pm<br /><br /><table width="99%"><tr><td class="BBquote"><strong><em>Originally posted by StephenH</strong></em><br /><br /><div>Moving from a 14" LRC tire (1760 lb/tire at 50 psi) to 14@ LRD (2040 lb/tire at 65 psi) to 15" LRD tires (2150 lb/tire at 65 psi) does make sense. Even 15" LRC tires have a higher load rating (1820 lb/tire) compared to the 14" LRC tires that came standard on our 179. Since the 178 is about the same weight as the 179, moving to the 15" LRD tires begins to make a lot of sense. They have more weight capacity. They won't help with fuel mileage but I think they will be less likely to blow out than a 14" LRC tire.</td></tr></table></div><div>Not all LRC tires are created equal. The 15" LRC tires on our RP179 are rated at 2340 lbs (6-ply rated tires).</div>]]>
   <pubDate>Tue, 04 Aug 2020 14:03:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134896#134896</guid>
   <title>Larger Wheels On 178? :  Moving from a 14&amp;#034; LRC tire...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134895#134895</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 1:13pm<br /><br /><div>Moving from a 14" LRC tire (1760 lb/tire at 50 psi) to 14@ LRD (2040 lb/tire at 65 psi) to 15" LRD tires (2150 lb/tire at 65 psi) does make sense. Even 15" LRC tires have a higher load rating (1820 lb/tire) compared to the 14" LRC tires that came standard on our 179. Since the 178 is about the same weight as the 179, moving to the 15" LRD tires begins to make a lot of sense. They have more weight capacity. They won't help with fuel mileage but I think they will be less likely to blow out than a 14" LRC tire.</div><div><br></div><div>Source of information above:&nbsp; <a href="https://www.maxxis.com/trailer/trailer-tire-loadinflati&#111;n-chart" target="_blank">https://www.maxxis.com/trailer/trailer-tire-loadinflation-chart</a><br></div><div><br></div><div>This is not an endorsement of Maxxis tires, but the chart was the first one I came across that had the information in an easily readable format.<br></div>]]>
   <pubDate>Tue, 04 Aug 2020 13:13:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134895#134895</guid>
   <title>Larger Wheels On 178? : My 2015 178 has lift blocks and...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134893#134893</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=5187" rel="nofollow">mcarter</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 11:59am<br /><br />My 2015 178 has lift blocks and 15" tires will fit.  I considered this but the cost weighed against the benefits didn't seem to add up.  Personally I don't think you see the benefits you expect, you're talking about an inch.]]>
   <pubDate>Tue, 04 Aug 2020 11:59:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134893#134893</guid>
   <title>Larger Wheels On 178? : If you have a lift kit you can...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134892#134892</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=8600" rel="nofollow">offgrid</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 11:39am<br /><br />If you have a lift kit you can go to 15 inch wheels and tires. I did. As StephenH says be sure to get 5 lug wheels.&nbsp;]]>
   <pubDate>Tue, 04 Aug 2020 11:39:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134892#134892</guid>
   <title>Larger Wheels On 178? : I do recall some people doing...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134888#134888</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=4814" rel="nofollow">StephenH</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 10:24am<br /><br />I do recall some people doing so. The hard part would be matching the bolt pattern which is 5 on 4.5"]]>
   <pubDate>Tue, 04 Aug 2020 10:24:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134888#134888</guid>
   <title>Larger Wheels On 178? :   I have a 2015 Model 178. While...</title>
   <link>https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134886#134886</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.rpod-owners.com/member_profile.asp?PF=10323" rel="nofollow">alandlearned</a><br /><strong>Subject:</strong> 13866<br /><strong>Posted:</strong> 04 Aug 2020 at 10:05am<br /><br />I have a 2015 Model 178. While the 14-inch wheels are cute they seem dubiously adequate. Can larger wheels be utilized? I mean the fenders appear to be able to accommodate larger wheels. Wouldn't larger wheels and larger tires be safer, last longer, and provide better gas mileage? Has anyone else changed out to larger wheels? Thank y'all.&nbsp;<img src="https://www.rpod-owners.com/smileys/smiley33.gif" border="0" alt="Ying Yang" title="Ying Yang" />&nbsp;]]>
   <pubDate>Tue, 04 Aug 2020 10:05:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.rpod-owners.com/forum_posts.asp?TID=13866&amp;PID=134886#134886</guid>
